93 Chevy Transmission problem - JeepForum.com
post #1 of 6 Old 10-25-2005, 03:14 PM Thread Starter
Rusty Scupper
2016 JK Wrangler
Don't know where else to go so I thought I would throw it out here. I have a 93 chevy 2500 as a tow vehicle and having tranny problems. When accelerating it will shift from 1st to second fine but then in 3rd it will be like it is in nuetral. The fluid was burnt, changed it and new filter but still having problems. It is intermittent. Is there a electrical sensor for 2 & 3 that might be bad. I don't want to throw a bunch of money into it if I don't have to. It has 100K on it.
Rusty Scupper is offline
post #2 of 6 Old 10-25-2005, 09:41 PM
oct7brian
oct7brian's Avatar
Does it have a detent shift cable going from the trans to the throttle body?? I had a similar shift problem with my 86 S10 Plow truck and that was the problem the cable was broken
1998 Grand Cherokee 5.9 Limited Edition, Upcountry Suspension for Now, Infinity Sound, NP 242 Swap
2002 Jeep Liberty Sport 4x4 3.7L Auto
1998 TJ 4.0 Auto Sahara Package 4" Suspension Lift 33 BFG Hard & Soft Top
oct7brian is offline
post #3 of 6 Old 10-26-2005, 12:16 AM
rowdy1
rowdy1's Avatar
Dunno if these trannies still have a modulator valve or not,but you might look into it
rowdy1 02 GC Laredo
rowdy1 is offline
post #4 of 6 Old 10-26-2005, 12:47 AM
moriarty
if it is the 4l60e then no there is no sensor and this is a very common failure,
90 blazer 4.3/5spd
31 x 10.50 super sport ht's from walmart
cb
welded spidy gears
Snorkel from Lowes
moriarty is offline
post #5 of 6 Old 10-26-2005, 02:58 PM Thread Starter
Rusty Scupper
2016 JK Wrangler
Moriarity - Thats it, what is the fix.....rebuild?
post #6 of 6 Old 10-27-2005, 12:49 AM
moriarty
9 times out of 10 yes.....
in my case, if it was highway speeds then it would still try to go to od and for a while it would eventually you have 1-2 and reverse the 700r4 is the same trans with the same problem in stock form.........................i have killed one of each the 700r4 in my firebird just all of a sudden had no more 3-4 the 4l60e in my 93 jimmy gradually got worse
i paid $950 locally to get my 4l60e rebuilt and that included a supposed valvebody upgrade that fixes some of gm's mistakes btw i pulled and reinstalled the trans
there is a place online http://www.700r4l60e.com
they are some of the best out there if you don't mind the idea of ordering one online they have all sorts of upgrades for hi powered and towing applications
90 blazer 4.3/5spd
cb
welded spidy gears
Snorkel from Lowes
moriarty is offline
chevy transmission and transfer case on a jeep KGBnumber1 Jeep CJ Forum 44 04-30-2013 06:56 AM
Input needed: Chevy transmission shifting problems H3RTCH General Discussion 4 01-04-2010 11:48 PM
Chevy engine problem JeepNE General Discussion 33 11-25-2009 07:34 PM
Chevy guys... What transmission is this? Divinitous General Discussion 2 10-21-2009 07:35 PM
Need a chevy transmission... Otahyoni General Discussion 3 05-03-2007 10:04 PM
