70's enduros - JeepForum.com
Go Back JeepForum.com > General > General Discussion > 70's enduros
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 11-01-2013, 07:16 PM   #1
toates89
1989 XJ Cherokee
70's enduros
I am looking at a dt250 next weekend.its got 3000 miles on it, looks like a 7/10 on condition. been sitting for 15 years(heard that this is bad for 2 strokes).
Shes asking 2000. I think its too high. I am looking to pay 1200 but i would go 1300.
Is this too low of an offer for said bike.
this isnt the exact bike but it is in similar condition
http://www.bikez.com/pictures/yamaha...20-%20Rick.jpg
What is a reasonable offer on something like this?
toates89 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2013, 07:34 PM   #2
CJsPerson
I had a DT175 I paid $800 for and it took three years of hard use like a champ before it went off to a new owner. As far as I know it is still going today. I had to bypass the oil injector it was horribly unreliable. After that I never had a problem with it again.
The asking price is way to high for me, but I don’t know the market in your area.
DTs are great bikes though. Even the Harley riders would way to me.
Sitting is hard on any vehicle but it can be elbow greased back to happy.
Never trust a happy man
I off road because I have a Jeep. I don't have a Jeep because I off road. Above all my Jeep is a convertible. That's where my love is for the brand ...convertible overkill
CJsPerson is offline   Reply With Quote Quick reply to this message
Unread 11-02-2013, 12:49 PM   #3
toates89
1989 XJ Cherokee
said bike
Unread 11-03-2013, 09:23 AM   #4
Bigshankhank
Stupid double post.
Bigshankhank is offline   Reply With Quote Quick reply to this message
Unread 11-03-2013, 09:34 AM   #5
Bigshankhank
While it looks like it is in good condition, pictures lie. For $2000, it should be running, otherwise that is a $1000 bike IF it has a clear title. No title, half that. Unfortunately these bikes are becoming increasingly popular with hipsters and it is driving the prices up. So many of these bikes are consequently snapped up at inflated prices, chopped and hacked into poorly executed cafe racers and then dumped when they can't them tuned correctly.
The problem with old two strokes sitting is the crank seals. These are rubber seals that prevent air leaks into the crankcase. When they dry out they crack and leak, causing the engine to run very lean and overheat, causing a piston seizure. Bad things. Plus the bike will run like hell until that happens. Replacing them may or may not require splitting the engine, some bikes this is necessary and others not, I am not familiar with the DT series bikes to say for certain. In addition, the oil in the oil lines from the injector pump can harden into goo, which will block fresh oil from getting to the crank bearings and piston again causing the engine to lock up. Lots of people advocate removing the oil pump and blocking off the ports, this is usually a bad idea. By the late 70's, technology had made these things dead reliable and probably one of the last parts to fail on a two stroke. Removing them could prevent oil from getting places that premixed oil/gas through the carb cannot get to like the crank bearings. Cleaning or replacement may be necessary, not a huge burden but they can be hard to find. Then the usual a old bike stuff, stuck clutch, old degraded wiring, rust, gummy fluids in the forks and transmission case, old tires, etc. It can be fun and rewarding to get one of these old bikes running properly, I enjoy it as a hobby, but it takes more than just a carb clean and an oil change.
Unread 11-12-2013, 08:11 AM   #6
toates89
1989 XJ Cherokee
Well i wound up buying a 98 dr350.
13k miles, good condition. $1550
I just couldnt justify paying that much for a 70's bike that i am going to bring into the woods.
