700r4 question AND fuel regulator/plumbing question
is it true i have to get an adapter of some sort for the overdrive in the tranny it plugs into a sensor... i cant remember what its called but its because i no longer am running an ECM? where is a good place to get one if so AND also i want to run my electric fuel pump on my carb... i have the 2 lines coming from the tank from the original FI... i need to regulate the pressure to 5.5 PSI... i was told i need a return style regulator, all autozone had was regualar regulators and i cant use one because it will burn up the pump... and do i use the extra line from the tank as a return? Im getting ready to drop this stuff in this week so i need to know what to buy
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife)
1946 CJ2A, 225 V6. mild lift - TIME TESTED
1966 M416 1/4 ton Military Trailer -- WAR TESTED
Full Page Club member #004
Green Jeep Club Member #005
