$650 Willys Wagon Project - JeepForum.com
post #1 of 3 Old 04-25-2002, 12:37 AM Thread Starter
evilpsych
evilpsych's Avatar
k guys.. i've located a 56 Willys Wagon project vehicle at a local cars for causes.. how difficult is it to modify this vehicle to accept upgraded parts?
I'm thinking a Golen Performance 4.0l (260 hp), a nv4500 and a dana 300 or quadratrac out of a wag w/ it's d44's.. how difficult will it be to do this from the frame up? are there many body-frame bolts or weird things i need to know about?
I know it's not really a willys standard.. but does anyone offer A/C for this vehicle? i only ask because it's not a convertible.
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #2 of 3 Old 04-26-2002, 05:33 AM
4wheeler4CJ
4wheeler4CJ's Avatar
evil,
I don't know anything about a project like the wagons, but I think that would an awesome truck done up! Those wagons are very unique! Good Luck! [Wink]
4wheeler4CJ is offline
post #3 of 3 Old 04-26-2002, 09:24 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Like any Jeep,with enough time and money you can put just about anything under the hood. As for the motor of choice, I'd try to stay with as short an engine as I could. A later 4 or V6 would fit with minimial cutting as the motor bay is somewhat small.After that you have room to bolt just about any trans/transfer combo you want.The rear axle(tapered axle D44)is plenty strong but you will probably want to replace the D27 front as it is marginial behind any kind of HP.As for the AC, two choices,find an aftermarket AC unit from a local shop that deals in them or drive real fast with the windows down! On a serous note, be sure to upgrade the brakes with a dual master cyl. and replace the backing plates with a self energising brake set up out of a later model.And replace the stock draglink/bellcrank steering with a manual/power steering box. With a mild lift and some goodies these trucks have a killer look about them, and are good wheelers to boot
bazinga
jeepdaddy2000 is offline
1960 Willys 4x4 wagon good to pull a trailer with my TJ on it? Kenbo-Slice Trailers & Towing 3 08-10-2011 11:59 PM
1958 willys wagon worth it? LostINohiO General Discussion 3 09-30-2008 01:37 PM
my new station wagon... tuckinauster General Discussion 23 10-29-2007 06:23 AM
G-Wagon Goodness KCjeeper General Discussion 1 02-23-2005 08:23 AM
'53 Willys Wagon For Sale zuck2001 General Discussion 0 04-15-2002 09:04 PM
