The 4.0... - Page 2 - JeepForum.com
post #16 of 33 Old 04-04-2012, 10:36 PM
andy_mitch92
1977 CJ7
Originally Posted by JFranko
They were putting a 4.2L in the trailblazers up until they stopped making them. I drove one for about half a year and really liked it. It was pretty quick for a big SUV (270hp 275 ft/lbs of torque). My mom owned it for 10 years before me and we never had any problems with the engine. It was also on Ward's 10 best engines list for a few years.
I was reading the other day that it was designed to be turbo charged. Think of the power it could make with some boost.
andy_mitch92 is offline
post #17 of 33 Old 04-05-2012, 08:03 AM
Chris_
I had a Ford 4x4 truck with the I6 when I was in high school. It was a 4 speed with a granny gear, and had 5.13 gears. It had a twin, and they were special order farm trucks. It would pull a house off the foundation, but it would barely do 65mph going downhill with a tailwind. My XJ I6 ran great with 200k on it, and my Wrangler I6 will do the same. The GM 3800 V6 is another motor I've used, and it would run forever.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline
post #18 of 33 Old 04-06-2012, 01:57 PM
Azzy
Ive been reading up on the later XJ 4.0's... the same ones used in the later Grands and TJ's. Turns out after those years, the engines have a pretty fatal flaw.
http://pgh-offroad.com/forum/showthr...w-someone-good
My hypothesis is two fold;
1)the pistons are different from 96-ish/97 although internal specs are the same. I think they went with a cheaper casting which leaves the piston inheirently weaker. Some of early powertechs didn't have teflon coating on the skirt, those that did they weren't as far down on the skirt as the others. Weaker piston/skirt material, with less/no teflon coating means more friction on a weaker material.
2) Now add in that misfire detection isn't the greatest (Im getting long winded as usual so I am not going to go into detail)
2a)and that CMP and CKP sensors tend to fade in and out on without going completely out of spec- just living on the hairy edge of the outer limits t on our rigs and only then ultimately going gonzo.
This all meaning the revolution algorythm of the misfire detection prgram gets eronious data, doesn't set a light/dtc when there is a misfire and you keep motoring on unitl CMP/CKP come back into range or you feel a dead miss that the PCM didn't detect and mitigate.
This all allows a misfire to go undetected straining the weaker pistons, until the skirt cracks, then it splits, then it chunks out, then it goes gonzo.
Thats just my theory.... nothing other than pure talking out of my arse. I came to that plausable explination after talking with a handful of customers and hearing similar stories no light, good verified service history, etc. Coupled with a handfull of my rigs, and engine work on the side- and talking to Bob @ ICS who agrees, and he seems to seen alot of them too go out that way.
Of all the cracked skirt 4.0/2.5s I have brought back to life with replacing cracked skirts with improved pistons and honing or boring if need be; I never had one come back and to the few I keep in touch with have gone 50 60 80K since my engine work without issue.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #19 of 33 Old 04-06-2012, 03:04 PM
Millermagic
Friend of mine drove his a few hundred miles with a broken piston skirt. From what we could tell, the block was fine and it would just need a new piston.
2000 XJ - 3.5'' Lift & Skinny Mudders.
Previous: A CJ, Few TJs and JK.
Millermagic is offline
post #20 of 33 Old 04-06-2012, 03:30 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Ford 4.9's
AMC 4.2L
Jeep 4.0L
All indestructible work horses IMO they should have never done away with them !
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #21 of 33 Old 04-07-2012, 01:17 AM Thread Starter
00xj54
00xj54's Avatar
Originally Posted by Tom95YJ View Post
Ford 4.9's
AMC 4.2L
Jeep 4.0L
What did they put the AMC 4.2Ls in?
[I]00' XJ Sport. 4.0 I6.
[B]|15" Canyon Crawlers | 30x9.5 Bridgestone Dueler A/T Revos | [Lifted (2" Teraflex Spacers | 2.5" RE AAL | Edlebrocks IAS)| K&N Homebrew Intake | Flow Master 70 |Clear Corners/Side Markers| Class III Hidden Hitch | C4x4 Fronts Tow Hooks | JKS Discos | Surco Safari Rack | Hella 500s |
00xj54 is offline
post #22 of 33 Old 04-07-2012, 09:19 AM
Mickey_D
CJ-5, CJ-7, first couple years of the YJ. I also believe they were a "fuel economy" option in the 2 door FSJ's.
The AMC 4.2L I-6 was pretty much universally known as the 258 cu in I-6. American Motors Company (AMC) were staunchly opposed to anything metric.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #23 of 33 Old 04-07-2012, 09:32 AM
commodore_dude
commodore_dude's Avatar
The 4.0 in my XJ blew without any warning at 100k miles, never did get a satisfactory explanation but I presume it was just poor maintenance in the 70k miles before I owned it. So far the one in my LJ has been trouble-free for 45k miles (been getting an intermittent O2 sensor code for about a year, but that's hardly the block's fault).
2006 Rubicon Unlimited
1998 Buick LeSabre Custom
commodore_dude is offline
post #24 of 33 Old 04-08-2012, 10:56 AM
Azzy
Ford 4.9's
AMC 4.2L
Jeep 4.0L
You ever look through the XJ forum? The 4.0 is tough, and can handle abuse, but it is far from indestructible.
Azzy is offline
post #25 of 33 Old 04-09-2012, 05:08 PM
89YJmoneypit
KMG365
89YJmoneypit's Avatar
Kinda funny considering they were in bed with Renault towards the end...
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
Now belongs to my daughter.
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Marseilles Fire Dept:
89YJmoneypit is offline
post #26 of 33 Old 04-09-2012, 05:20 PM
Balvar24
1979 CJ7
REAL Jeeps.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #27 of 33 Old 05-13-2012, 10:50 PM
jeepyj13
Ford 4.9's
AMC 4.2L
Jeep 4.0L
I agree. We had a 93 ford f150 with 4.9 with a 5speed connected to it and it was a torquer. I have the 4.0 in my yj and xj. My xj I put through hell, Ive overheated it on more than 1occasion, ran it low on oil once before, and my wheeling mostly consist of mudriding. Since my xj is stock with some walmart ats the skinny petal was my bestfriend and I stayed mashing on it. I had a old dodge dart with a slant 6 that was a dog, but that engine was tough too.
"Its a Jeeps World, other 4x4s just get stuck in it."
jeepyj13 is offline
post #28 of 33 Old 05-14-2012, 01:37 AM
RogueSpear2023
Jeep had a rough spot around 00-01 but since then they have been trouble free, and most of that was head, and manifold issues. I have an 03 with 85K on still runs great, my dad has 98 4.0L with over a 175K on it still running strong. These are both in TJs. The 05-06 TJs have OPDA issues.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #29 of 33 Old 05-14-2012, 06:44 AM
andy02
Originally Posted by ShrekII View Post
Straight 6's are hard to beat...the old Dodge slant 6 was damn near indestructable..
Damn near? When I was in high school, a buddy of mine drove a 68 Barracuda with a 225 slant 6. He had a built 360 sitting in the garage just waiting to get dropped in but his dad put the nix on that until the slant 6 died. Us being the high school kids that we were decided to accelerate that. He brought the car into the auto-parts store that I worked at and we drained the oil out. His plan was to drive the car until the engine exploded. Two weeks later it was still running when his Dad found out about our little plan.
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
post #30 of 33 Old 05-14-2012, 07:00 AM
grandboost98
i picked up a 72 nova recently with a 250 i6 in it. i already planned on swapping a 350 into the nova and thought, what better place to put the 250i6 than in my jeep. that will be next years project
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
