3.73 gears - JeepForum.com
post #1 of 4 Old 12-15-2012, 09:29 PM Thread Starter
charper
3.73 gears
have an 03 liberty sport and I'm trying to put 02 liberty gears in it...
the old gears are bigger than the new ones.. does anyone know if I can use them?? I'm in a pickle right now and would hate to put it back together and ruin the warranty.
charper is offline
post #2 of 4 Old 12-16-2012, 01:11 AM
cory4um
Try asking in the liberty forum.
You can run different ratio gears in the front and rear, but not in 4wd. I'd pull the front driveshaft for insurance. Hate to forget and blow s*** up.
cory4um is offline
post #3 of 4 Old 12-16-2012, 01:21 AM
kg4kzv
1995 XJ Cherokee
If you mean physically bigger different gear ratios in the same axle are often different sizes. If the axles are the same type they should fit but you may need to swap the carrier as well. I'm not an axle pro though so hopefully someone that knows more than I do will chime in.
If not ask the mods to move this thread to the right sub-forum to get more hits on it!
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #4 of 4 Old 12-17-2012, 03:33 AM
RogueSpear2023
I would ask in the liberty forum but you must change the gears in the front too, if it is 4wd, otherwise you will be unable to use the 4wd. You may need to change the carrier depending on the gear split. You will also have to have professional with the proper tools do the swap, this is not something that can be easily done in the garage, takes a bunch of specialty tools and knowledge to do properly.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
