2015 Mustang Just Released - Page 4 - JeepForum.com
post #46 of 64 Old 12-15-2013, 08:43 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Originally Posted by krawler510 View Post
Technically it's still a small block. That LS7 is made for racing.
And weights 100lbs more than the Mustang engine.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #47 of 64 Old 12-15-2013, 08:58 PM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Originally Posted by Ironworker709 View Post
The LS7 is an aluminum small block based souley on the Gen. IV small block
The LS7 has 505 HP @ 6200 RPM's..redline at 7000 RPM's....high revving ability?..i'd say so....
475 Ft Lbs of torque @ 4800 RPM's
Torque is a BIG advantage in the track..mainly when coming out of a slower corner and needing that torque to pull it quickly up to speed...
There is several things that people have been complaining about in the comparison track run they did being called totaly bull..for the fact of the bigger cubic inch displacement..the carbon fiber brake system and some suspension mods that would not be allowed to run in the track class the Boss 302 is designed and built to run...
And these complaints are even coming from the die hard Chevy fans too that are at least honest in opinions and facts..
They have also failed to mention the HUGE price difference between the Z28 and the Boss 302..again..it would of been a fair match if they would run against a GT500 which is would be in the same class and price vehicle...
And the Boss is 380 torque @ 4500 and redlines 7500 with HP at 444.
On a track, spec #s don't mean as much as the intangibles. Have you ever seen a NASCAR ride drop a cylinder at a road track and burn up the track until the engine blows? Yep, has happened many times! The loss of peak power actually makes the car more capable on tracks like that. Too much torque is worse than not enough.
4 seconds is an *** whipping, straight up. It would be much more interesting if ALL models were track tested under similar conditions on a consistent track.
And did you really expect Chevy to do a heads up in which they lost??? O_o
post #48 of 64 Old 12-15-2013, 09:29 PM
Ironworker709
Ironworker709's Avatar
The Boss 302 weighs 444 lbs
The LS7 weighs..............yup....444 lbs.......
Here's a guy who bought a crate LS7 and did the math once delivered...
The 100 lbs more you found was most likely the delivered freight weight...
http://ls1tech.com/forums/generation...ls7-crate.html
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #49 of 64 Old 12-15-2013, 09:49 PM
Ironworker709
Of course they wouldn't "match" anything up..they are well known for it in their advertising marketing schemes..O_o
Another thing they failed to put in the video..is the camaro they ran in the vid has no sound deadening in it..and alot of interior parts to shave weight,,,
But they ran the Boss 302 as is off the showroom floor....( it is already well known the Z28 they ran would not be even closely allowed to run in the race class the Boss was designed to run in)
It would more interesting if they ran more equaly class matched and priced vehicles..
As far as too much torque in track...false..that would be up to the driver if he used that available torque in an overkill situation....its all up how you USE or ABUSE it..and whats available when you NEED it...
I am more impressed with a 302 getting 444 HP than a 427 getting 505 HP..
71 HP more with a hand built engine with 125 more c.i's than a mass produced factory line engine....
I love the LS line of engines..but they are FAR from the "gods gift to hot rodders" engine line up most people put them out to be...
I grew up around dirt tracks and drag strips..and the general rule of thumb was ALWAYS..
You need HP for the quick run in a 1/4 mile..
You NEED torque in the long turning tracks and short dirt tracks..
I pretty much breathed the 1/4 mile growing up and in my 20's-30's( spent way too much crazy money on them all)
And my father and his best freind ran dirt tracks in delaware and Md..
The long stroke torque always prevailed on the dirt tracks and long tracks..just what i seen personaly..not an internet thing...
Never forget 9/11
post #50 of 64 Old 12-15-2013, 10:10 PM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
I disagree.
Torque is the driving force of a 1/4 mile race and most are settled in the first 100 feet where the superior torque(if planted right) makes a big difference. If you have excess torque on a longer track where it has to be used back and forth it becomes troublesome for any driver. Especially on dirt where traction is so often suspect and changing.
Torque matched to the set up and chassis characteristics will always be superior to just having the most. That is why HP/torque numbers aren't nearly as important as skid pad, weight ratio, and slalom numbers in tests like that.
Only thing impressive to me anymore about engine building is when they do it without any extra 'lungs'. Lol
post #51 of 64 Old 12-15-2013, 10:11 PM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Lowest weight I found for the Chevy was 458 with variences all the way over the 525 mark.
post #52 of 64 Old 12-15-2013, 10:32 PM
95YJMountie
95YJMountie's Avatar
Reminds me of a hyundai tiburon
My build:
95YJMountie is offline
post #53 of 64 Old 12-16-2013, 06:35 AM
Ironworker709
I think the new mustang front end design derived from this front end...
Notice how close that front end looks..
And i like the hell outta the new SHO taurus..the fuel mileage and power number are impressive and i thik they look more "sporty" now than ever...
2013 Ford Taurus SHO Front End Photo 6
Never forget 9/11
post #54 of 64 Old 12-19-2013, 11:11 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
Something seems fishy here
May TJ of the Month 2015
TexasTJ is online now
post #55 of 64 Old 12-28-2013, 11:27 AM
SDDAVE
Best Mustang ever built, right here!
SDDAVE is offline
post #56 of 64 Old 12-28-2013, 04:35 PM
CaptD
I traded my 2010 Mustang GT convertible for a 2013 Jeep Wrangler Sport. I loved the car, very fast stock, but I couldn't leave well enough alone... I had Ford Racing cams, high flow intake and exhaust installed. It ran like a scalded dog, dynoing at 348rwhp. Not too shabby for a little 4.6? I miss the 'Stang, but I've had so much fun with this, my first Jeep that I don't regret the trade. The look of this new Mustang is slowly growing on me. Kinda like mold...
http://youtu.be/5UQYkWxxWp8
The southern possum is a flat marsupial that lives in the middle of the road.
CaptD is offline
post #57 of 64 Old 11-12-2014, 07:41 PM
95YJMountie
Old thread, i know..
My opinion got changed on these after seeing and working on one in person. Customer came in with a 2015 5.0 6 speed, with 442 miles on it. I got the pleasure of installing a CAI and a magnaflow exhaust system.
The test drive was awesome btw...
My build:
post #58 of 64 Old 11-13-2014, 12:17 AM
2006_Sport
The ecoboost 4 banger on those is gonna surprise a LOT of people. With JUST a tune from lund racing, it was putting down another 75 whp/135tq. Stock is 310 at the crank.
That's almost 400hp from a 4 banger. Granted its a 4 banger in a mustang but still. But I drove around the only one our dealer had here when it first came in. I'm impressed.
Tune only, nothing else done to the car.
2006_Sport is offline
post #59 of 64 Old 11-13-2014, 08:28 AM
DangFoo
Ford is doing some amazing stuff with relatively smaller displacement engines. I have the 6-cylinder Ecoboost in my F-150 and it's bounds better than the previous 5.4L V8 that I had.
Those Stangs look nice; the interior is a home run.
DangFoo is offline
post #60 of 64 Old 11-13-2014, 01:24 PM
2006_Sport
Yeah I went to the Ford dealer a couple weeks ago and I was looking at 4.6 2005-2010 GTs just to test the waters. Guy said they had ONE 2015 GT that they just got in and let me go look at it in the shop. Interior is SUPER nice and it sounds really good too.
Just a tad out of my price range right now though
