2001 XJ brake question - JeepForum.com
post #1 of 4 Old 06-25-2013, 11:41 AM Thread Starter
daveboehme
Does the '01 Cherokee 4.0 two wheel drive have a proportioning valve in the break system? I have an issue where the pressure isn't being applied to all four wheels in a uniform matter. The passenger front hits first and it feels like the Jeep is being spun around to the left. The passenger rear locks up also. I just did the calipers, rotors and rubber lines.
Any ideas, thanks.
daveboehme is offline
post #2 of 4 Old 06-25-2013, 11:50 AM
Budke
there's a proportioning valve under the hood on the MC.
04 TJ- Short Bus. It's got some stuff.
Sometimes I question my sanity. Occasionally it replies.
Budke is offline
post #3 of 4 Old 06-25-2013, 11:53 AM Thread Starter
daveboehme
Is incorporated in MC or separate?
Thanks
post #4 of 4 Old 06-25-2013, 02:32 PM
TSEJEEPERS
Separate.
The front is suppose to lock up first. Both fronts.
Make sure you have the right calipers. The bleeders will be on top.
If they are not, either you put them on wrong or the parts store gave you two for the same side.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
