2001 Cherokee Shimmying and knocking noise when hitting bumps - JeepForum.com
post #1 of 2 Old 01-11-2002, 09:30 AM Thread Starter
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxRory
Guest
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxRory is offline
post #2 of 2 Old 01-11-2002, 01:30 PM
clegger
I would start by turning the rotors. By the time the brakes wear out, there has been enough heat on the rotors to warp them. Then start looking at tie rods and wheel bearings. The noise you are hearing when you hit a bump could be a couple of things. My 90' is making the same noise and it is the exhaust pipe hitting the transmission crossmember. It could also be one or both of the shocks are loose and are moving around.
Good luck
Matt
78' CJ-5 in process of frame off, 84' V8 Ranger
clegger is offline
XJ cherokee , cherokee , knocking , noise , bumps
Just checked out a 2001 Jeep Cherokee Muscles00GT General Discussion 4 01-11-2010 04:23 PM
Towing with 2001 Grand Cherokee ploconto Trailers & Towing 1 04-11-2007 06:24 AM
STOLEN! 2001 Jeep Cherokee Silver, 6" lift khunjeep General Discussion 3 01-18-2005 05:58 PM
Stolen Grand Cherokee - 2001 Gold/Beige from E. Central Illinois loricar General Discussion 3 10-01-2003 07:38 AM
