1990 chevy 3500 engine troubles - JeepForum.com
post #1 of 3 Old 01-04-2010, 08:46 PM Thread Starter
joe's_yj
joe's_yj's Avatar
I recently bought a 1990 chevy 3500 with a 454 7.4l motor and auto trans. 4wd. now i bought it with these problems hoping i can fix them. i got the codes out, its
code 43 knock sensor
or electronic spark control circuit fault
The symptoms are, the truck doesnt accelerate worth a damn, has terriable gas mileage( i know its a 454) when i shift from park to a gear, the idle drops to almost stalling and then picks back up. i also have a service engine soon light
Would replacing the knock sensor fix this? i was told that code will retard the timing. This could be the cause of all my problems right? thanks
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #2 of 3 Old 01-05-2010, 01:14 AM
jumbojeepman
1976 CJ7
Knock sensor will retard the timing and cause the symptoms you are experiencing. Could be the sensor, there's a checklist to run through before you just throw a new sensor on it, though (basically see if it's getting power, the right resistance, etc.)
jumbojeepman is offline
post #3 of 3 Old 01-05-2010, 08:04 PM Thread Starter
joe's_yj
joe's_yj's Avatar
i got a new sensor, but i cant get the old one off. ugh always somethin. hopefully i can get it tomorrow
my build up
joe's_yj is offline
Chevy engine problem JeepNE General Discussion 33 11-25-2009 08:34 PM
Used SUV for 3500 or less ArrizX General Discussion 12 08-30-2009 07:21 PM
Hand Made 1/6th Scale 327 Chevy Engine Slenny General Discussion 4 01-17-2009 06:33 PM
Non jeep engine troubles. Bender92YJ General Discussion 2 04-06-2007 07:11 PM
Weird Chevy 4.3l starting problem (have an engine code) yoshisushi General Discussion 0 03-21-2005 02:33 PM
