1960 Jeep Utility Wagon - JeepForum.com
post #1 of 9 Old 09-28-2015, 01:28 PM Thread Starter
Shadytom
I recently picked up a 1960 Jeep wagon in excellent condition. I'm just trying to get some thoughts and opinions as to some upgrades that may be available.
I would like to keep it as original as possible. She will be used as a DD. I've never understood doing all the restore work just to keep her locked up in a big 'ol box.
Super Hurricane 6-226
Manual shift
4x4
Currently just waiting for tags to come in so I can get it out on the road and start this restore.
Thanks for any input.
Shadytom is offline
post #2 of 9 Old 09-28-2015, 08:32 PM
TSEJEEPERS
Pictures????
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #3 of 9 Old 10-04-2015, 03:53 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
The simple stuff.......
Front disk/11" wagoneer drum brakes
Dual brake master cylinder
Alternator upgrade/12V conversion
jeepdaddy2000 is offline
post #4 of 9 Old 10-04-2015, 11:56 PM
MRknowitall666
RIP Wounded Warrior
1950 M-38
Pics??? One of the best vehicles ever and no pics yet?
DAV Wounded warrior project
MRknowitall666 is offline
post #5 of 9 Old 10-13-2015, 07:02 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
Petronics electronic ignition distributor if it hasn't been done yet. Nice stereo and cruise around showing it off.
http://www.vintagevibes.net/jeep_cj.htm
I know it is for a later model CJ but will still look good in it with the rest of the components scattered (hidden).
Need pics to be able to give any other advice.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #6 of 9 Old 10-31-2015, 11:02 PM Thread Starter
Shadytom
1960 Wagon
I apologize. I never knew there was any responses here.
I wanted to keep this as original as possible but after long thoughts, I need this to be more efficient and economical too. Let's say, more up to date.
I also have a '91 YJ with a tweaked frame that I'm not interested in fixing, so all parts are available. Also parts from an 88 YJ. Including the 258.
I've decided to restore the body to original but upgrade the drivetrain and some components.
Before anyone suggests it, I'm not putting any motor in that is not in the JEEP family. I'm set on using this 4.0L bc I have history with it. Thank you.
My thoughts are simple:
1960 Jeep Wagon
4.0L HO motor (1991 YJ)
AX-15 (1991 YJ)
Novak Adapter (AX-15 to T-18)
Original Dana 44 and Dana 27 rears
The reason for using the T-18 instead of the NP 231J are bc the Dana 27 is a passenger side drop. The NP231J is drivers side. People have said to upgrade the front axle to the Dana 30 from the YJ. I'm not going that route bc the Dana 30 is drivers side drop, different gear ratio, and also lug pattern. I believe it MAY also be a slightly different width. Yes, it is set up for power steering and disc brakes, which would only require me to rebuild the rear axle at that point. I'm still factoring and figuring $$$ on that aspect.
As far as the motor is concerned, I ordered a kit from CLIFFORDS PERFORMANCE. I AM degrading to a carbureted engine. I work with computers all the time but rather not have them in my vehicle. With a new intake, dual exhaust. Other upgrades also include ignition system and cold air intake. If you've made it this far, please comment or give me some feedback. I'll appreciate it either way. BTW, I AM AN AMATEUR at this. I do know how to read and use tools tho. Thanks all.
20151008_184045.jpg   20151008_184149.jpg   20151030_122801.jpg   20151030_122712.jpg
Shadytom is offline
post #7 of 9 Old 10-31-2015, 11:18 PM Thread Starter
Shadytom
I forgot to mention, If someone could correct me if I'm wrong, I believe I read something about using the 258 crank and rods. (@ 4.5 stroker IIRC)
Shadytom is offline
post #8 of 9 Old 11-06-2015, 04:31 AM
HubDeepDriver
Dip it in Chocolate, cause that's sweet like candy! Seriously. You've been gifted with a relatively rust free vintage Jeep. Obviously you are favored by a divine power. I agree with other posters though, install electronic ignition and disc brakes. Avoid the temptation to install a turbocharged Cadillac V8. ( If I had known that image would still be with me after all these years I would have gouged my eyes out! Well, maybe not, but I'd have worn dark glasses at the least. )
HubDeepDriver is offline
post #9 of 9 Old 11-06-2015, 07:03 AM
TSEJEEPERS
Sweet!
