Trailer tents? - JeepForum.com
post #1 of 20 Old 06-02-2013, 01:33 PM Thread Starter
aircruiser
aircruiser's Avatar
Trailer tents?
Everytime we have gone wheeling I bring a tent, drive the jeep there and me and the girl sleep in the tent all weekend. Now my jeep is a trailer queen and since it seems to rain half the time, I want to put the tent on the trailer. Smooth deck so no surprise rocks and up off the ground so should stay dry inside. The last straw was waking up to an inch of standing water in the tent soaking everything. Only problem is my tent has the stakes like most do on the end of the supports to go in the ground and on the trailer, theres no real spot to put them.
My trailer is a 16ft wood deck by 82" wide and the frame is all steel box tubing with angle iron for the deck side supports. I was thinking of taking some round hollow tubing and making some mounts basically and welding them on the sides but I still feel like that would slip out. Are there any tents out there for cheap that dont use inground stake mounts? How do you all mount your tents on your trailers?
TIA
aircruiser is offline
post #2 of 20 Old 06-02-2013, 10:45 PM
Roobicon
Throw 4 sandbags onto the trailer. Set up the tent, stick the sands in the corners and call it good.
2004 Roobicon
Clinging to my guns and my religion
Roobicon is offline
post #3 of 20 Old 06-06-2013, 05:41 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
^That would be nice to mount a tent to the trailer to get off of the ground. I've got a Turbo Tent that doesn't require stakes to stand it up (it springs open). But it's not a cheap tent.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists.” -- Don Colacho
grogie is offline
post #4 of 20 Old 06-07-2013, 11:50 AM Thread Starter
aircruiser
aircruiser's Avatar
Cool thanks for the suggestions I will try the sand bags
post #5 of 20 Old 06-07-2013, 12:07 PM
ontarioXJ
If its a wood deck couldnt you mount 4 of those flush dock tie downs to it? Then when you set up the tent you can just flip up an tie the corners down or use quick clips to mount the corners.
More durable in wind and bad weather.
ontarioXJ is offline
post #6 of 20 Old 06-07-2013, 03:32 PM
84_Fiero
1966 FSJ Wagoneer
Plus never a bad idea to have more places to tie things down to your trailer when the tent isn't on it either...
-Nick
Engineer in training
"Anything that is complex is not useful and anything that is useful is simple. This has been my whole life's motto." –Mikhail Kalashnikov
“And note that it behooves a good Workman to hammer his Work as true as he can; for one quarter of an hour spent at the forge, may save him an hours work at the vice.” Josheph Moxon “Mechanick Exercises” from the year 1703
84_Fiero is offline
post #7 of 20 Old 06-07-2013, 07:36 PM Thread Starter
aircruiser
aircruiser's Avatar
Where can you buy those at? I never thought of that
post #8 of 20 Old 06-07-2013, 08:25 PM
84_Fiero
1966 FSJ Wagoneer
Auto parts stores, or Tractor Supply would be my first places to look.
-Nick
84_Fiero is offline
post #9 of 20 Old 06-08-2013, 09:50 PM
Indy
Indy's Avatar
Lowes, home depot, harbor freight.
Really the stake hole type are pretty expensive. You can get strapped d-rings cheaper, should do the job well.
I'm the only gay eskimo.
Indy is offline
post #10 of 20 Old 06-22-2013, 07:08 PM
ontarioXJ
These i found at a local part source here in pickering, ontario.
How has your look gone so far? Have you found a solution yet?
post #11 of 20 Old 06-23-2013, 11:01 PM Thread Starter
aircruiser
aircruiser's Avatar
Ah now I gotcha, I was thinking boating tiedowns for some reason, I will have to pick some of those up I can get those at menards. My only issue is my tent has the stakes that stick into the ground and I need to stick them into something to support the tent
post #12 of 20 Old 06-24-2013, 03:41 PM
ontarioXJ
Can always use 4 carabiners, one at each corner.
Then you can quickly connect it up an pull her down if ya needed to.
Dont wana lose them? Connect them all together and toss them all in the tent bag.
post #13 of 20 Old 06-24-2013, 05:15 PM Thread Starter
aircruiser
aircruiser's Avatar
How would you connect the stake to that?
post #14 of 20 Old 06-24-2013, 05:40 PM
ontarioXJ
Should be able to fit through the tent peg holes and then to the trailer flush mounts...
What kind of tent do you have?
post #15 of 20 Old 06-24-2013, 05:46 PM
ontarioXJ
Lol i had to draw what i meant. Less confusion haha
http://twitter.com/dmilwain/status/3...682241/photo/1
