Small Campers for Wranglers - Page 6 - JeepForum.com
post #76 of 148 Old 12-09-2008, 04:22 AM
grogie
M-F: Cell Block #4533
grogie's Avatar
Mike, how did the teardrop pull with a lifted TJ? Plus, I know their not heavy, but how is it without having trailer brakes? (I believe that they don't have brakes.)
Also, if you were to buy another one, would you step up to the next size, 5x8?
Thanks for your input. It's just a wife and I, so we still have the back of my TJ for packing stuff. I'm starting to dislike sleeping on the ground, plus the back my TJ is overly full for trips!
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #77 of 148 Old 12-09-2008, 05:40 AM
Hilldweller
2014 JK Wrangler
Originally Posted by twichers View Post
HillDweller - you have the weight specs - empty and GVWR on that Conqueror Compact?
i couldnt find it on their website...
looks nice
thanks!
They claim a GVWR of around 1700 pounds --- the axle is rated at 5500. I really need to put it on a scale some day; I don't believe their weight claims at all. There's alot of steel back there... ...and you can tell the difference with the water tanks full.
You don't notice it on the trail at all; only time it makes itself annoying is on highway-speed uphill sections.
http://www.youtube.com/watch?v=GIZkH1XBFBE
Safety fast,
Security is mostly a superstition. It does not exist in nature, nor do the children of men as a whole experience it. Avoiding danger is no safer in the long run than outright exposure. Life is either a daring adventure, or nothing.- Helen Keller
Hilldweller is offline
post #78 of 148 Old 12-09-2008, 06:18 AM
FourEyes45
Sorry but have not read all 6 pages of this----but we tow a R-Vision 21' trail lite camper with our 4d Rubi. The camper wt. is 2700lbs. We like it better that the truck slidin that we are trying to sale.
Have a great and safe week.
FourEyes45 is offline
post #79 of 148 Old 12-21-2008, 06:19 PM
JIMBOX
The TENTRAX is very light duty and will go WHEREVER you can take that jeep
It weighs 900 lbs and you can DeHitch it and move it around, by yourself--IDEAL
JIMBO
JIMBOX is offline
post #80 of 148 Old 12-25-2008, 07:53 PM
jagular7
The trailer pulled very nicely. The tongue was a little long (greater than 3' but don't recall exact measurement) which helped track the trailer behind the TJ. For its size and design, this was a very basic teardrop. There was really no galley like in the traditional design td. So I had to carry a kitchen box. The inside was a little tight with my son and I camping 1 time, but I guess kids will always 'roll' around. So yes, I would step up to a wider one for sure.
Biggest things I could complain about are the 'packing' for a wheeling weekend was inside and you had to unpack to use the inside. Second, it sat a little low when you wanted to enter it. 3rd, no location to place your boots, weather gear, etc. when you go to sleep.
I would suggest you pack what you would normally for a camping wheeling trip and place that on the garage floor looking to keep things as tight as possible. Put tape down on the floor around your packing for the walls. Setup a test camp and add to the tape area where needed.
The traditional td is a good thought, but layout and packing for enroute is not what I like best about it. I would build it also rather than buy something built. 5x10 would be better and I would enclose the tires into the wall. The bed floor would be raised to clear the wheelwells. You could have sliding drawers underneath the raised floor. With the frame a little taller, the wheelwells won't be so tall into the floor.
I'd also build it tall enough to be able to kneel in it to get dressed.
For braking, I have an disc'd 8.8 and never thought I had a problem braking.
Have you checked out the teardrop and tiny travel trailer forum? Lots of builders there. Was the td you looking at the one from Little Guy?
That was the plan I had also, but as plans go, things had changed. I do think the bigger you go, the better you will feel and be more comfortable. I really don't think you will need brakes, but for the cost of knowing and spreading it over couple years of ownership, it's not that costly. Also check aftermarket axles for swapping in rather than purchasing from the mfr. My Dexter axle I have under the trailer frame I put together has a parking brake as well as electric brakes and was made to my width. A parking brake would also help you keep the camper still in rough terrain. Then look at stabilizers at corners. This stabilizes the camper when you go in/out and shift weight.
Last spring I put together a trailer frame for an idea for a camper. I used a slide-in Quicksilver camper on the frame. It weighs 440#s. Its a very small box as well as camper. I wasn't satisfied in its use.
Now looking to adapt a base for the truck shell, add a couple slideouts that would hold a kitchen and extending bed outwards, mod an area within the door area for standing/getting dressed. I did get it really cheap at $90.
If this shell doesn't work out, I plan to build a Compact III.
Take care.
Mike
Jagular
Lnxa, KS
97 TJ SE lifted, locked and rubbered for fun
94 YJ SE stock, 225s, Trail Tested
jagular7 is offline
post #81 of 148 Old 01-13-2009, 06:58 PM
outlawjosywales
My teardrop
900 lbs. (dry). Been coast to coast,north to south. 15" LCD tv,cable tv ready (for RV parks). Shore power ready. Use a little Honda generator when "roughing it". 2 burner butane stove.
Go Anywhere.
outlawjosywales is offline
post #82 of 148 Old 01-14-2009, 04:56 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
XBOX 360 in the camper!! Why didn't I think of that.Sweet. Here's mine. It pulls very well at 2800 lbs with trailer brakes.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #83 of 148 Old 01-20-2009, 12:36 PM
MountainMan864
I would not want to pull that in my tj with the 4.0. Since you have a supercharged stroker i bet you have no prob. Any plans on a stretch later down the road?
MountainMan864 is offline
post #84 of 148 Old 01-21-2009, 10:17 AM
mike_dippert
mike_dippert's Avatar
the 4.0 can pull that easy. my LJ has a 3500# rating. 4.0L XJ's have 3500# also. the SWB of TJ's is was what lowers the rating to 2500#.
mike_dippert is offline
post #85 of 148 Old 01-22-2009, 09:00 PM
Joker741
I would love to buy a T@B T16-1 U-Shaped, but there is no way I am paying what they want for one.
I really want a hard sided trailer and not a "tent" style. The weather is usually not the greatest while we are der hunting and last year was enough to start the hunt for a trailer. I had the tent under an EZ-UP, the wind was so strong it broke a tent pole and it was raining so hard that even under the EZ-UP it was wet in the tent. Wife said trailer or she is staying home this year.
Oregon State
School of Pharmacy
Sold my 97 TJ, was looking for a TJ Rubicon, but school put that on hold.
Joker741 is offline
post #86 of 148 Old 01-28-2009, 05:46 PM
grogie
grogie's Avatar
Nice tear drop!
I'm thinking about one myself... one of these would be great, but a bit pricey. http://www.tinycamper.com/index.htm
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
grogie is offline
post #87 of 148 Old 02-01-2009, 07:34 PM
Josey
So do you have it? How is it? Mind letting us know what you paid? Thanks!
Yes I picked it up in the fall, just returned from a 22 day trip to Florida, Pulled the Little Guy more than 2400 miles. Went down the west coast came back by way of the East Coast, camped everywhere from wal-mart parking lots to horse fields & campgrounds. I traveled with my father and law who was in a 26ft fifth wheel. Every campground I was able to park on his lot, not once was it a problem.
The little camper its self pulled like a dream, some places when we where only staying one night, I didnt even unhook. My Jeep was the get around vehicle and it was just as easy to leave the thing back there as it was to unhook it.
The overall cost was a bit pricey, but if your'e like us without children you can afford to play more than most couples with children $9,500. The trailier held up well against all them miles including some off road time before the trip. I love the camper, but to be truthful I feel the camper should have been tagged by quaility control before leaving the plant. I had to glue the self back together & the Jackwheel which is welded to the frame released during my trip, something I need to fix by replacing it with a bolt on jackwheel. Also there was a question with the back hatch, the company sent me a repair kit free of charge, but as I stated all this should have been taken care of before leaving the plant.
Other than the few small details overall the camper is tough, and a lot of fun. I placed a microwave and 19 inch color Tv in the back hatch, its the hit of any campground people gather around the back like a bar. all thats missing is the bar stools.
Since buying my little camper, I look hard at others wondering if I made the right choice. I still feel I did, & am looking forward to many more trips. I wished I could post the picture of my rig, be awhile before I get 50 post on any board.
Anyway, thats my review of the Little Rough Rider, Nothing else like it on the market. If your'e looking for an off road camper, I don't think you'll find a better one, if you find one at all.
Josey is offline
post #88 of 148 Old 02-01-2009, 07:45 PM
ccrane2299
I bought an Aliner. I have wanted one for several years and the opportunity came to get one so I did. It has a fridge, micro, water heater, a/c, cool fan in the roof, and an outside shower. It weighs 1400+ pounds and pulls great behind a TJ. I hunted out of it all winter and was always warm and comfy. It has a couch on one end that makes a bed...I just leave it as a bed all the time. If you don't mind the cost, you cant beat it. Here a pic in my driveway....red TJ has been replaced by a Blue LJ.
ccrane2299 is offline
post #89 of 148 Old 02-02-2009, 06:14 PM
grogie
grogie's Avatar
Other than the few small details overall the camper is tough, and a lot of fun. I placed a microwave and 19 inch color Tv in the back hatch, its the hit of any campground people gather around the back like a bar. all thats missing is the bar stools. The problem about this little guy is the people wanting to talk to you about it, never ending. Now this isn't really a big problem, but Ima a big 420 kinda guy. And strangers pressing their nose up to the windows find themselves offended, for this I apologize.
Thanks for the review! If you can link to photos, we can post them. I can imagine you get a lot of questions. Now does your Little Rough Rider have brakes?
I've also looked at the Aliner. Did you get their "off-road" package that includes brakes? I also see that you bought the Classic. Would you have been as happy with the slightly shorter Sport? But I can see your point about having the back as a bed that you just leave it as with the Classic. Thanks as well for the post.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
grogie is offline
post #90 of 148 Old 02-02-2009, 08:12 PM
Josey
It does have power brakes, at only 980 pounds. I slammed my brake on hard a few times going though Atlanta and the whole rig stopped on a dime.
The only reason I didn't decide on a pop up was because of the canvas sides and set up time. seems this little Aliner has taken care of atleast half that problem, may come down to a matter of price.
Josey is offline
Campers - What tent? fdkss03 Outdoor Recreation 42 02-07-2010 02:45 PM
Zombie-proof campers Hilldweller General Discussion 15 08-25-2009 07:03 AM
Help ! All of you young campers ScotZ General Discussion 43 03-26-2008 01:05 PM
Towing Small Campers? blackbirdcd Trailers & Towing 0 02-16-2008 09:14 AM
