Project- brick skirting help - JeepForum.com
post #1 of 7 Old 10-20-2013, 11:08 AM Thread Starter
Skerr
I'm trying to resolve this in my head as outdoor recreation (gardening). It fits best here, me thinks! I have been given another project by the Boss. I'm sure I could muddle through it, but I want it to be better than that. Would some of you experienced brick layers/masons give a hand?
I have these planter boxes that we have used for several years. Wifey wants them off the ground where she doesn't have to bend over them. I also have this pile 'o brick. I want to build a nice looking skirt to set the boxes upon. I will have 4 boxes.
How do I prepare the ground and stack/lock the brick together? I'm looking for a no/low cost plan.
Thanks, All, for your input.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #2 of 7 Old 10-23-2013, 12:03 PM
Kuntryboy816
Kuntryboy816's Avatar
I'm not a bricklayer/mason but I've tackled a few projects in the past such as brick walkway and a patio made with pavers. As far as ground prep with a conern that erosion may buckle the wall, I would say at the least tamp it down and level as best you can. The ideal thing would be to put down a base layer of crush n run or the like.
As far as building upwards, they make a masonry type adhesive but judging from the size of those boxes you might need a lot of it. I'm not sure how it compares to traditional mortar but I'd think mortar would wear better. Also depending on what you plant in those boxes you might not want to build the bases too high or it'll be difficult to reach any taller plants. Good luck with the project!
Originally Posted by 14Sport View Post
Until you know exactly what is underneath the, well, not really sure what to call them...mistakes...it's hard to come up with a plan of action.
Kuntryboy816 is offline
post #3 of 7 Old 10-23-2013, 07:43 PM
petergrady08
Being from the masonry industry, I have a few pointers. If this project was mine this is what I would do.
First where your brick are going dig down about 5 or 6 inches, and pour concrete(sakrete will work) for a footer.
There's a couple different product you can use to lay the brick with. If you use masonry cement you will have to add sand with it. We recommend 3 parts sand to one part masonry cement. Or you could just buy the premix and just add water. Either way you go, you want the mortar consistency to be like peanut butter.
If you have any questions pm me.
petergrady08 is offline
post #4 of 7 Old 10-24-2013, 11:35 AM Thread Starter
Skerr
Hey Guys... Thanks! I wasn't thinking about mortar, and I wasn't thinking about a foundation. I can build the footer, no problem. The only "mortar" work I have ever done is pouring slabs or burying corner posts! I'll need pointers if mortar is necessary.
I was thinking of just stacking the brick (interlocking- mortarless), but if ya'll think I need mortar then I will do that. Will I have to have a double-walled or a single-walled thickness? Obviously, too narrow could be tipsy, but I was trying to be economical. Which was should the bricks lay? The boxes are 16" wide X 96" long x 12" tall.
Or would the bricks make a better BBQ pit??
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5 of 7 Old 10-26-2013, 08:10 AM
TheBoss
Though it would require buying more materials I would suggest adding masonary cinder block as the inner wall and supporting foundation. As suggested a minimum of a crushed aggregate or concrete base slab and build up from there. It doesn't appear in the photo you have enough brick to build a strong enough base to support the weight of the planters fully loaded with soil.
Another option would be a post and beam style support where the post rise up above ground and the beam brings it to the desired elevation. Kind of like a mini deck build.
TheBoss is offline
post #6 of 7 Old 10-26-2013, 11:49 AM Thread Starter
Skerr
Post and beam... hmmm. I can do that! Obvious and over-looked. Thanks, Boss.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #7 of 7 Old 10-26-2013, 06:55 PM
TheBoss
Hey, no problem. With a little creativity you could extend the posts overhead and make a sprinkler trellace.
TheBoss is offline
