Bow Hunting - JeepForum.com
Go Back JeepForum.com > General > Outdoor Recreation > Bow Hunting
GenRight Offroad at CCOR! 706-207-4140Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaWarn, Smitybilt, Engo, Rugged Ridge Winches at CCOR
Unread 11-16-2006, 11:54 AM   #1
coonash
coonash's Avatar
Bow Hunting
Well, I leave tomorrow early for a hunting trip s.w. of San Antonio, TX . It's being put on by by one of our company's vendors. I'm going to take the wifes Sahara. I've never hunted with a rifle but they will have one for me to use.
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline   Reply With Quote
Unread 11-19-2006, 07:17 PM   #2
coonash
coonash's Avatar
Well, just got back. Saw some nice deer, but can only shoot 8 point or better. My only good deer to shoot at was scared away by some cows . First hunt on Fri. night was with my bow on the ground. Way to many rattlers around, ended up using a 270 in a stand after that. Well, there's always next time.
Unread 11-25-2006, 06:50 AM   #3
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Got my Columbia Blacktail yesterday. Good luck to you.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline   Reply With Quote
Unread 11-25-2006, 08:38 AM   #4
blb_yj
thats a good size blacktail. nice
blb_yj is offline   Reply With Quote
