308 ammo question - JeepForum.com
post #1 of 16 Old 07-02-2013, 02:05 PM Thread Starter
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
308 ammo question
I have a 308 round with no powder in it. I want to detonate the primer. What is the best way to do this without the gun. Also I don't have a vice.
Originally Posted by Beefstew View Post
brain guts all over the windshield!!!!!!!!!!!!!!!!
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by Duck Dodgers View Post
I'd rather take the chance and belive in God than take the chance and not.
Cuz ya got nothing to lose by believing, but ya sure might if ya don't.
White Jeep Club Member-2027
paulmatyn is offline
post #2 of 16 Old 07-02-2013, 02:15 PM
JimmydaGreek
2015 JK Wrangler
You need a way to secure the round, typically in a vice. If you don't have a vice you just need to find a way to hold the round in place so you can strike it.
2015 JK Unlimited Rubicon Loaded and Modded
JimmydaGreek is offline
post #3 of 16 Old 07-02-2013, 02:17 PM Thread Starter
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
What kind of force does the primer create. Also, does the slug need to be remove for this process?
post #4 of 16 Old 07-02-2013, 02:29 PM
CJATE
I'd be worried the primer does have enough force to blow back or send projectile.
Primer has plenty of snap
What is it you are trying to accomplish? Might be best to someone with a re-loader to put lead into a spent shell.
Sent from AutoGuide.com Free App
83 CJ-8 scrambler
SOA
Locked and Twin-sticked
35's, fenders cut
4.56
bad paint
leaks just about everything
CJATE is offline
post #5 of 16 Old 07-02-2013, 02:41 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
remove bullet. place cartridge in rifle. pull trigger (do this outside).
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #6 of 16 Old 07-03-2013, 09:48 AM
JimmydaGreek
2015 JK Wrangler
Do you just want to dry fire your rifle? Do you have a local gun store you can just run in and pick up some snap caps?
post #7 of 16 Old 07-03-2013, 07:26 PM
CoastieShep
First, are you sure there's no powder in it? Don't tell me you tried shaking it and didn't hear anything.
Second, that primer will have enough to launch the lead hard enough to be dangerous.
CoastieShep is offline
post #8 of 16 Old 07-03-2013, 11:40 PM
Indy
Indy's Avatar
Thinking of all the ways this can go badly. There are quite a few.
1st ? Would normaly be how experienced a loader are you,but im guessing negative numbers here.
So lets start with why are you messing with this?
A primer launched bullet can kill you, ask brandon lee. If youre wrong about it having no powder things can get real interesting quickly. Ive been shooting for decades and coming close to my second decade loading. With my gear and my experience, i wouldnt think of blowing a primer with a bullet in the case much less an apparently unknown round.
I'm the only gay eskimo.
Indy is offline
post #9 of 16 Old 07-04-2013, 02:09 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
as mentioned.
remove bullet. place empty primed cartridge in rifle. fire.
outside, in safe direction.
-Andrew
Marn is offline
post #10 of 16 Old 07-05-2013, 07:14 AM
CoastieShep
MUST BE DONE IN THIS ORDER!!
1. Call 911
2. Hold cartridge with pliers.
3. Strike primer with ball been hammer
4. Wait for ambulance.
post #11 of 16 Old 07-06-2013, 07:08 PM
bigwahini
next time you BBQ just drop the shell in the....no,no,no,no just kidding. If not using a rifle, then drill a hole in a 2x4 just large enough for the round to fit. Drill ALL the way through the board. Do not block the open end of the shell. Be positive there is no powder in the shell. Get your redneck neighbor to hit the primer with a nail and hammer. Seriously man, what are you doing? Just get a spent round and remove primer the safe way. If you need a spent round I'll send you one.
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #12 of 16 Old 07-06-2013, 07:13 PM
samuraisavr
This has bad news written all over it. Just leave the stupid human tricks to other people and watch from a safe distance. Do a quick youtube search for someone striking a primer with a hammer. It looks the same, but the difference is: You won't lose a hand or die...
Just
Empty
Every
Pocket
samuraisavr is offline
post #13 of 16 Old 08-06-2013, 03:44 PM
swirve
Bullet puller then run it through a resizing die with a decapping pin. It will push the primer back out. Or just leave the primer in the case but still pull the bullet to verify there is no powder charge. Just by shaking it will not tell you theres powder in it or not.
swirve is offline
post #14 of 16 Old 08-14-2013, 05:10 AM
Apostle
"To learn who rules over you, simply find out who you are not allowed to criticize.”
–Voltaire
Apostle is offline
post #15 of 16 Old 08-20-2013, 04:47 AM
Holder350
1995 XJ Cherokee
I've got a way better idea. Throw the damn thing away. Bury it. Something.
When I was younger I thought I would set a shot shell primer off in a vice (no shot or powder just a empty shell with a live primer). I clamped her down and hit a small screwdriver setting on the primer.
When it went off the primer cup ruptured and shot out of the pocket. Luckily the screwdriver went thru the cup and it ended up on the shaft of the screwdriver. Unluckily tho the pad of my finger was against the shaft of the screwdriver.
Took a good hunk out of my finger and I could just imagine what it would have done if the screwdriver shaft had not captured the cup and it had hit me.
Now......most gun shops sell a kinetic bullet puller that I have used many times to disassemble loaded rounds to check for bullet weight and powder charge. THAT is your best bet to stay out of the hospital.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
