Xk park assist no power - JeepForum.com
post #1 of 10 Old 09-10-2013, 10:32 AM Thread Starter
overland-wk
2006 WK
I did the search on the forum but still can't find an answer . I have a 07 jeep commander 3.7l Rocky Mountain edition the problem with the park assist is that it has no power to it nothing lights up and button don't work it's like I don't have that park assist option. Any suggestions? Thanks
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #2 of 10 Old 09-10-2013, 05:33 PM
R32R1
2006 WK
Check fuses and if your reverse lights turn on.
R32R1 is offline
post #3 of 10 Old 09-10-2013, 06:37 PM Thread Starter
overland-wk
2006 WK
I checked all fuses and my reverse lights do work.
Youtube channel
Bumsmodified98xj
post #4 of 10 Old 09-11-2013, 07:52 AM
JeepCares
FCA Customer Care
JeepCares's Avatar
My assumption is that you know the Commander came equipped with that function. Did it somehow get disabled?
from the 2007 Commander Owner Manual:
Enable/Disable the Rear Park Assist System
The Rear Park Assist System can be enabled and disabled
with a switch located in the switch bank of the instrument
panel.
When the switch is pressed to disable the system, the
instrument cluster will display the PARK ASSIST DISABLED
 message. Refer to “Electronic Vehicle Information
Center (EVIC)” in Section 4 of this manual. When the
shifter is changed to R (Reverse) and the system is
disabled, the instrument cluster will actuate a single
chime, once per ignition cycle, and it will display the
message.
The Rear Park Assist Switch LED will be ON when the
Rear Park Assist System is disabled or defective. The
Rear Park Assist Switch LED will be OFF when the
system is enabled.
JeepCares is online now
post #5 of 10 Old 09-11-2013, 08:29 AM Thread Starter
overland-wk
2006 WK
panel.
message.
system is enabled.
I tried the disable button but that don't even light up.
Youtube channel
Bumsmodified98xj
post #6 of 10 Old 09-11-2013, 01:00 PM
JeepCares
FCA Customer Care
JeepCares's Avatar
When was the last time it worked? Any mods put on after that?
post #7 of 10 Old 09-11-2013, 01:37 PM Thread Starter
overland-wk
2006 WK
I did replace the hole shifter assembly a couple years back but i cant remember if was working before the shifter or after. It didn't bother me back then but now that I paid off my commander I want everything working properly like when I first bought it.
Youtube channel
Bumsmodified98xj
post #8 of 10 Old 10-12-2013, 09:06 AM Thread Starter
overland-wk
2006 WK
Is there a module for the park assist? And if there is where is it located?.
I can swap things out from my wk and see if somethings work.
Youtube channel
Bumsmodified98xj
post #9 of 10 Old 10-22-2013, 04:30 PM Thread Starter
overland-wk
2006 WK
Anyone?
Youtube channel
Bumsmodified98xj
post #10 of 10 Old 11-19-2013, 07:12 AM Thread Starter
overland-wk
2006 WK
Just an update on the parkassist problem i had. It was a faulty parkassist module works like new again.
Youtube channel
Bumsmodified98xj
