post #1 of Old 02-02-2016, 02:42 PM Thread Starter
DRENNAN5
XK lift question
hey guys, thank you in advance for taking the time. I recently had a friend lift his JK rubi. He has a set of the 17in rubi wheels and 80% tread life on the BF Goodrich Mud-Terrain tires, size 255/75/17. my question is how much lift am I looking at needing for my 06 commander to get these under it? I see several spacer style kits anywhere from 1" to 3" heights. Keep in mind this is strictly mall crawl, looks only. He owes me some cash so this is an easy way to settle up, but I don't want to alter my XK too much or get to deep into pocket on a lift. I have a cut up 1 ton YJ that is my trail beater. Any thoughts/ideas please comment. I am totally lost on commander tech.
thanks, Russ Drennan
95 YJ
104" wheelbase
HP Dana 44(4.88/lockright)
HP Ford 9(4.88/spool)
38x12.50 TSL
15x8 36 bolt MRT
front susp: SOA(buggy/reversal)
rear susp: 4 link, quarter elliptic
Ramsey 9k, full cage, fuel cell
DRENNAN5 is offline
post #2 of Old 02-02-2016, 04:50 PM
Bchain5
2007 WK
You can either trim THE bolt and run stock. MAJOR RUB. Or you can go with a Rough Country lift for about $150 and get some spacers. Or you could go all the way with an OME 3in lift for about $800. I'm going with the Rough Country lift but the OME is definitely best way to go hands down
My 7th Jeep, 07 Grand Cherokee QTII 4.7L
#164 of the Silver WK Club
My build http://goo.gl/sr5m5f
Bchain5 is offline
post #3 of Old 02-02-2016, 08:04 PM
Rwwmoran918
2007 XK Commander
I did the 255/75r17 from jeep rubi. I purchased lift and wheel spacers for less than 300. I also purchased new rear shocks to keep the factory stance. Not sure if this applies to all jeeps on this platform, but my jeep set higher in the front. The shocks cost less than 90 on amazon. monroe 58643. Hope this helps
Rwwmoran918 is offline
post #4 of Old 02-04-2016, 07:19 PM Thread Starter
DRENNAN5
thank you
the pic above is exactly what im looking to do. do you guys think I will be able to get away with just doing the 3inch spacer lift? it is under 200 and seems to be a weekend driveway install.
95 YJ
104" wheelbase
38x12.50 TSL
15x8 36 bolt MRT
DRENNAN5 is offline
post #5 of Old 02-05-2016, 09:42 AM
caulk04
2008 WK
A typical spacer lift should suffice just fine. I imagine you'll need to do the pinch weld also (search pinch weld mod). Wheel spacers will also be needed to allow the tires to clear the upper ball joint. 1" is enough. The more spacer, the less clearance against the pinch weld.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #6 of Old 02-06-2016, 11:04 AM
Rwwmoran918
2007 XK Commander
If you add wheel spacers it gives the jeep a wider stance and you don't have to worry about grinding down the caliper or cutting the control arm bolt. As you can see by the pic... that's the setup I went with. Lift,spacers, and new rear shocks
You may not post new threads
You may not post replies
