Xk hydraulic cooling fan issues - JeepForum.com
post #1 of 5 Old 09-13-2012, 10:36 PM Thread Starter
manhands
2007 XK Commander
well where do i start,
blew the hemi in my 07 commander , after get junk yard motor in i have no ps or fan running . the power steering works above idle but fan never comes in , even when it warms up . tried replacing pump already and have vacuumed the ps system as recommended. any help would be great.
manhands is offline
post #2 of 5 Old 09-14-2012, 12:06 AM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
Does the fan spin at all? I read somewhere that the fan should spin a little as the fluid circulates. The fan itself is actuated by the engine controller wired to the back of the fan, at the fan it controls the amount of fluid driving it.
YB Normyl is offline
post #3 of 5 Old 09-14-2012, 12:18 AM Thread Starter
manhands
2007 XK Commander
fan turned first time cranked after swapping motor , blem return hose off fan on test run and now nothing at all.
Never use a XK as a sub. Hemi's dont like water.
manhands is offline
post #4 of 5 Old 09-14-2012, 04:40 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
what does "the power steering works above idle" mean?
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #5 of 5 Old 09-22-2012, 05:29 AM
kentman
kentman's Avatar
2006 XK Commander
What ruined the Hemi? If it was overheating, maybe your fan and/or fan solenoid is toast.
I recently replaced all this gear on the WJ. I did fan, pump, all high pressure lines, cooler, steering gear, radiator, condenser, water pump, etc. One of my issues was the aftermarket pumps. They were all crap. An OEM pump worked like a champ.
Make sure that all your lines are installed in the proper locations. There is a picture in the FSM.
For bleeding the system, you need to have the wheels off the ground and slowly rotate the wheel lock-to-lock for like 20 times. I would do that procedure a few times if needed.
'06 XK Limited, 5.7L, QD II, Black, 170K
'02 WJ Overland, 4.7L HO, QD, Inferno Red, 130K
kentman is offline
More 4.7 Hydraulic Fan Issues WiCkeDuDe ZJ Grand Cherokee Forum 27 04-23-2012 12:49 PM
CRD double whammy; swirl motor & failing hydraulic cooling fan GCOilBurner WK Grand Cherokee & XK Commander Forum 14 06-20-2011 05:32 PM
Hydraulic Cooling Fan Solenoid Issues slush ZJ Grand Cherokee Forum 4 06-23-2009 08:36 PM
ARB Bumper Hydraulic Cooling Upgrade??? CrazyWalnut13 ZJ Grand Cherokee Forum 11 07-05-2008 10:27 PM
WJ 4.7 Hydraulic cooling system. LEDFoot ZJ Grand Cherokee Forum 2 09-28-2004 04:23 PM
