XK Front Hitch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > XK Front Hitch
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 10-24-2011, 08:37 AM   #1
cmdrjim
2006 XK Commander
XK Front Hitch
I finished installing my front hitch, from another thread, I started out with designing it on Solidworks and ran an FE on it to make sure it was strong enough. My goal what 10,000lbs straight front load and 500lb tongue load. Does the front of the XK frame support a 500lb tongue load? Not sure. Will it support the 10,000lbs straight load, I think it will considering each tow hook is rated at 5000lb. The FE pics show the 500lb tongue load from another thread I posted on.
06 Red Jeep Commander 3.7L V6 "Manual QT2", and many more upgrades
cmdrjim is offline   Reply With Quote Quick reply to this message
Unread 10-24-2011, 08:42 AM   #2
cmdrjim
2006 XK Commander
Here is the finished hitch and my new heavier duty bolt bars. Grade 8 blots which are longer and thicker bolt bars that slide inside of the frame. These replace the parts that came with my tow hooks.
Unread 10-24-2011, 08:43 AM   #3
cmdrjim
2006 XK Commander
Here is the bolt bars installed into the frame and all is ready to mount my hitch.
Unread 10-24-2011, 08:45 AM   #4
cmdrjim
2006 XK Commander
Here is the hitch and tow hooks back on the Jeep. Note I had to grind a bit of the rear of the tow hooks to clear a couple radiator bolts.
Unread 10-24-2011, 08:46 AM   #5
cmdrjim
2006 XK Commander
Notching of the front bumper and the back in place. Note, I did have to trim back the center rib all the way off after fitting the bumper back on.
Unread 10-24-2011, 08:52 AM   #6
cmdrjim
2006 XK Commander
Finished views, note how the hitch really doesn't affect the approach angle of the front. I did have to slot the license plate holder about a 1/4" to set it higher. However do note the hitch is angled up some in the front. I believe the frame of the Jeep angles up some and to level it all out I may put some shims under the front set of bolts.
Unread 10-24-2011, 10:01 AM   #7
trax95008
2006 XK Commander
That looks nice and clean. Good job! What do you plan to use it for? Removable winch? Towing the XK?
trax95008 is offline   Reply With Quote Quick reply to this message
Unread 10-24-2011, 10:16 AM   #8
cmdrjim
2006 XK Commander
Just for a removable winch. I have the wiring and fuses set up to be able to use it in the front or rear.
The extra 4 small tapped holes on the vertically section of the angle of the hitch will eventually be used for mounting hidden running lights behind the grill
Unread 10-26-2011, 03:59 PM   #9
LouC
2007 WK
Looks GREAT...fits like the Matrix, but looks beefier....
LouC is offline   Reply With Quote Quick reply to this message
Unread 10-28-2011, 09:03 AM   #10
cmdrjim
2006 XK Commander
If this fit the WK as well would any of you be interested in buying this?
Unread 01-07-2012, 09:08 PM   #11
sebastien
2006 WK
yes.
sebastien is offline   Reply With Quote Quick reply to this message
Unread 11-05-2015, 05:38 PM   #12
WasatchXK
Sorry for the thread revival, but the op's messages are full. Would you be willing to share the solidworks model? Hopefully you're still active on this site.
WasatchXK is offline   Reply With Quote Quick reply to this message
Unread 11-05-2015, 08:18 PM   #13
Tango.
2008 WK
looks like a jk hitch cut and welded to 3/8" hot roll.
Life is hard-John Wayne
Tango. is online now   Reply With Quote Quick reply to this message
