XK 3rd Row Seat Issue - JeepForum.com
post #1 of 14 Old 02-07-2012, 09:25 AM Thread Starter
marka2k
2006 WK
06 Commander Limited drivers side third row seat will not unlatch the lever feels loose suspect problem with the lever or the cable that goes to the latch (if there is one) problem is I need to fold the seat to take the trim off so I can investigate. Is it possible to actuate the latch so I can fold the seat down? If so how do you do it when the lever does not work?
Thank you!
marka2k is offline
post #2 of 14 Old 02-07-2012, 02:44 PM
99FormulaM6
2007 WK
I don't have much to give you, since my XK's seats go up and down fine, but I found this on the Commander forum:
All, I doubt this will fix everyone's problem but I was prepared to take my 2010 Commander to a local shop to see what could be done, expecting to pay $300-500 for the fix.
PROBLEM
The seat was stuck in the upright position because the release lever seemed to just freely move back and forth. I tried getting a screwdriver in the latch with no luck - pretty tight design.
SOLUTION
While toiling over the seat, i notice the lever cap (small piece of plastic) was missing. Turns out it's NOT decorative but totally necessary for the lever to work!?!? I "popped" the cap off the other lever (which was working fine) and popped it on the end of the "broken" lever and BAM! Works totally fine like nothing was wrong.
Again, I'm sure there are several other failure mechanisms but I've seen others comment about the lever being broken and not releasing - so here's one fix to rule out.
-Mark
2006 Commander - 4.7l, QTII
2007 Grand Cherokee - Hemi, QDII, Predator tune
99FormulaM6 is offline
post #3 of 14 Old 02-08-2012, 09:06 AM Thread Starter
marka2k
2006 WK
I bet that's what is wrong with mine the cap is missing I will give it a try.
Thank you for the reply!
marka2k is offline
post #4 of 14 Old 03-31-2012, 09:13 AM
joyg
3rd row latch broken thank you!
Thank you, thank you, thank you!!!!! My third row has been stuck in up position since July! The dealership wouldn't even talk to me about putting it down for less than $100, and then upwards. IT WAS JUST THE LATCH COVER! What is that? A fifty cent piece!!! It worked! I pulled it off the working side, put it on the broken side, and WELLA, DOWN IT WENT! All I can say is thank you. This was a serious safety issue, complete blind side in the rear window, and I didn't have the money to fix it. The sad thing is, the dealership probably knew it, and didn't even care. I expressed the concern of not being able to see, it was a safety issue, they could of cared less. Thanks again!!!!! SHARING KNOWLEDGE IS POWER.
joyg is offline
post #5 of 14 Old 11-04-2012, 02:39 AM
IndustrialG33k
2006 XK Commander
Cheap Fix
FWIW putting a penny in the slot seems to be a good temporary fix. It is not often you have a $0.01 repair!
Joe
IndustrialG33k is offline
post #6 of 14 Old 11-18-2012, 10:18 AM
mmenta860
The penny trick worked. Any idea how much the actual cap costs or how available it is at the dealer?
mmenta860 is offline
post #7 of 14 Old 03-02-2013, 03:37 PM
kirkross
The seat was stuck in the up position for months, the second time this has happened. DO NOT TAKE YOUR CAR TO THE DEALER. THE ISSUE IS THE CAP WHICH POPS OUT. FIND IT AND STICK IT BACK IN AND ALL YOUR PROBLEMS ARE SOLVED. the dealer could have told you this when you came in to have it fixed. crooked bast.......
kirkross is offline
post #8 of 14 Old 12-03-2013, 07:33 AM
jesimay1999
2006 XK Commander
You are outstanding!!!!
This totally fixed my problem!!! Thank you thank you thank you. You are outstanding!!!
jesimay1999 is offline
post #9 of 14 Old 07-01-2014, 08:00 AM
DorieLL
2010 XK Commander
commander third seat
Thank You so much for posting this. I was on vacation when the right rear seat stuck in the upright position on my 2010 Commander. So grateful that you had an answer for me that allowed me to drop that seat.
DorieLL is offline
post #10 of 14 Old 07-01-2014, 11:11 AM
luckyse7ens
2010 XK Commander
Good info, will remember this for when it inevitably happens to my rig
Black WK Club #152
luckyse7ens is offline
post #11 of 14 Old 11-14-2014, 10:05 AM
Shiloz
Thank you, thank you, thank you! This forum saved me so much money! I was able fix this last night and now I can order the part.
Shiloz is offline
post #12 of 14 Old 11-14-2014, 10:39 AM
luckyse7ens
2010 XK Commander
Will have to keep this in mind.
Black WK Club #152
post #13 of 14 Old 05-02-2015, 08:08 PM
2tom2
Ha!!!! I had this problem today and google pulled this up top hit!!!
2tom2 is offline
post #14 of 14 Old 02-13-2016, 11:15 AM
CommanderBrian1
3rd row seat lever problem
I am absolutely amazed & elated!!!! the cap trick was the entire problem!!!! to top it off, I found the missing cap!!!
You guys are geniouses & I can't thank you enough.
I was expecting to pay $500 from the dealer (it seems that every damn thing cost $500 these days).
I am one happy Jeep owner.
Bless you, bless you bless you.
Commander Brian
CommanderBrian1 is offline
issue with power seat kjohns53 WK Grand Cherokee & XK Commander Forum 0 10-02-2011 02:50 PM
5.9 power seat issue NYCXJ90 ZJ Grand Cherokee Forum 5 03-31-2011 04:28 AM
Seat heater issue MuddSlutt ZJ Grand Cherokee Forum 3 10-29-2010 05:12 AM
Leather Seat Issue acsimon WK Grand Cherokee & XK Commander Forum 7 07-21-2008 01:31 PM
98 ZJ Heated Seat issue ZJMagicMike ZJ Grand Cherokee Forum 1 04-11-2006 08:19 PM
