Would a Tuner get me anywhere? - JeepForum.com
post #1 of 4 Old 07-24-2012, 05:13 PM Thread Starter
reldridg
Hi there I have a 2005 Cherokee with a 5.7 it is all stock and I will keep it mostly that way. May go up 1 tire size I am at 245/65/17 right now and I am thinking on going up to 245/70 and maybe leveling our the front end rake.
I use the jeep as my DD and driving to our cabin in the mountains as well as towing a 2 place snowmobile trailer during the winter.
Of course I would like to increase gas mileage when a I can and then also get the power I want for towing.
Would there be anything to gain from going to a tuner for my setup?
When I bought it gas mileage was pretty poor but I have replaced the MAP and PCV, and have cleaned the throttle body. These have seemed to make a small difference. I will be replacing the EGR and plugs this week or next once the temp cools off some.
Let me know your thoughts.
Thanks
reldridg is offline
post #2 of 4 Old 07-24-2012, 05:29 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I think over time a 1 - 2 - or 3 mpg improvement would pay for the cost of a Superchip programmer. I don't really know what you would see with your set-up but that is what most WK's see as far as improved fuel econ w/ oversized tires. So my guess is you would see larger gains.
Food for thought.........
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 4 Old 07-24-2012, 10:00 PM Thread Starter
reldridg
That is kind of what I was thinking. If I could see a gain during my normal driving and then change the program if I need to tow something that would be great.
Do folks thing it is typical to maybe see a 2 mpg increase if driving normally with some of the programmers?
reldridg is offline
post #4 of 4 Old 07-24-2012, 11:02 PM
JRLT
2010 WK
Assuming your driving habits don't change. Tuners add that little bit to your response that make you want to quit driving like a grandma and that's what kills it in the long run. Watch your shift points too or just take notice of where it normally shifts on the tach and compare that with after you apply the tuner.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
SCT Tuner 10cent WK Grand Cherokee & XK Commander Forum 3 09-09-2013 11:54 AM
Tuner rraiderr WK Grand Cherokee & XK Commander Forum 3 05-24-2012 01:00 AM
TV Tuner in WK arc11 WK Grand Cherokee & XK Commander Forum 9 03-24-2009 08:53 AM
Tuner gets hot - 95 ZJ 10s_linger ZJ Grand Cherokee Forum 3 11-26-2007 08:16 AM
