Is it worth getting a diesel? - Page 4 - JeepForum.com
post #46 of 91 Old 02-05-2014, 04:56 AM
MC_wk
2007 WK
Originally Posted by 1dzlwk View Post
European versions of this engine don't/didn't utilize the same intake system that's giving many of us fits in the U.S.
A couple of years ago, we took the CRD out to Yellowstone Park. We filled the tank right outside the park (far cheaper!) before we drove in. We were in the park for a week, driving everywhere. Our lodge was at the lowest altitude (7000 feet) and the highest spots IIRC were at about 11,000 feet. The week comprised climbing mountains, coasting back down them, some flat running, and quite a bit of stand-still idling (waiting for buffalo, staying warm, etc.). When we filled up again at the same station outside the park, I crunched the numbers and found that the car had given over 28mpg. And, mind you, it never once felt as though it was missing any power at all. There were people there with gasser SUVs complaining about loss of power going up those grades, but we never felt any such thing...
The WH/XH (export CRD) uses the same intake system as domestic WK/XK. The export CRDs do not come with DPF, which is a large factor in engine longevity. It's also the difference between a clean tailpipe which you described, and a dirty/sooty one, like what many JF users have.
I agree, zero loss of torque at altitude. Kinda nice, really.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline
post #47 of 91 Old 02-05-2014, 09:52 AM
1dzlwk
2007 WK
...European versions of this engine don't/didn't utilize the same intake system that's giving many of us fits in the U.S...
Originally Posted by james_2k View Post
er no its the same
Originally Posted by RMC_xj View Post
The WH/XH (export CRD) uses the same intake system as domestic WK/XK...
Sorry guys, I'm just (foolishly?) going by what the diesel techs at two different dealerships have told me. If I'm truly wrong about this, please forgive me. The last guy I talked to explained it this way: somewhere back around '09, the E.U. changed their diesel emission requirements to bring them more in line with what were, at that time, the more restrictive U.S. requirements. According to him, as of those ~'09 regulation changes, engines for Europe and the U.S. can be mechanically more or less identical...that is, the regulations are now similar enough that mere software changes can pretty much cover the differences. He claimed that, before this ~'09 regulation change, the U.S. and E.U. engines (specifically the intake systems) were physically different. He didn't explain exactly how they were different, but the implication was that the E.U. engines of that period did not have the same swirl motor/intake flap setup that we're cursed with. That's all I know on the similarity issue...
____
Bob
1dzlwk is offline
post #48 of 91 Old 02-05-2014, 10:36 AM
94jeepman
2005 WK
I kind of want to get a crd but don't want to start over or swap all my stuff. With wouldn't be hard tho hardest thing would be my tires and lift.
94jeepman is offline
post #49 of 91 Old 02-05-2014, 11:13 AM
1dzlwk
2007 WK
As the original owner of an '07 CRD WK, I'd have to say...definitely not! I just collected my CRD from the dealer after its second round of swirl motor/flap repair in the last year, and on the way home the check engine light came on again...
Fair disclosure update:
As of early February, 2014, my engine seems to be running perfectly. My wife just finished a 250-mile round trip with it and she said it ran great, while getting ~26 mpg...quite good considering the weather and her driving (hint: she's not slow). The above-mentioned CEL was not an engine problem after all...it was yet another new problem: the shift mechanism and shift controller were defective and both were replaced...and yes, the car had shifted oddly and/or refused to shift at all from time to time, but it was just another intermittent problem that I assumed would never be corrected. Thank providence that it actually finally failed completely, so they could find it. The tech told me that the shift mechanism all by itself was worth about $1300. He didn't say how much the electronic shift controller was worth, but it probably wasn't cheap, either. Again, this repair was also taken care of under my extended warranty, which has just under five months remaining on it (tic-tic-tic!). So far, the warranty has paid for itself close to three times over, and we're probably not done yet. While the rear drive shaft was just replaced as we attempt to chase down the root cause of a horrific drive train vibration issue (common to many WKs), the front drive shaft has not, and the vibration is still present occasionally. I haven't even bothered complaining to the dealer about the seat/radio/mirror memory that erases itself every several months, or the copious amounts of liquid water that will spill out of the headliner if you make the mistake of leaving the vent-free sun shade closed for too long during the winter (condensation buildup), though I did tell them about the HVAC's outer door (the one near the under-hood ventilation filter) failing to close all the way...which allows a lot of outside air to leak in, summer and winter, whether you want outside air or not. The result is that the AC can't keep up in hot humid weather because there's no effective recirculate function, and the heater sometimes has trouble keeping up in really cold weather. Their solution to this: test HVAC motor functions (motor functions test normal, so no problem found)!
Look, I regret if all this is coming off like sour grapes. It is obviously based just on my own personal experience with my owned-from-new CRD WK of 77,000 miles. However, I do also have to say that the other two WKs that I have personal knowledge of, while not CRDs, have also been quite problematic/expensive propositions as neither had an extended warranty. The OP is free to do as he chooses, and good luck to him either way. I just hope you can understand why I, personally, can't recommend the car to him...
____
Bob
1dzlwk is offline
post #50 of 91 Old 02-05-2014, 10:12 PM
Drudgery1971
2007 WK
The discussion is silly now overall (the WK diesel is less than 2% of all people owning a WK in US) so any opinions of the CRD should only be valid if said person owns one. I have ZERO mods other than deleting swirl motor with a $.13 cent resistor and 105k miles later started today at 15 F after 4 days at airport - no block heater attached and 4 year old battery. Then got 24.3 MPG highway home with a 4" thick ice sheet on the lid. At the end of the day...... buy what you want and enjoy it- they are all Jeeps.
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #51 of 91 Old 02-06-2014, 02:58 PM
chrali
2006 XK Commander
I don't agree at all. This was true maybe through the very early 90s; after that, all the things that comprise modern emissions equipment (electronic ignitions/injection, etc.) have demonstrably helped engines to run better/cleaner, and to last longer ...
Yes the engine ran cleaner on the outside so guess where all the crap went? Yes inside! Hence cars getting carboned up intakes, egr valves and engines. Even catalytic converters introduced decades ago make your car run less efficiently.
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #52 of 91 Old 02-06-2014, 03:02 PM
chrali
2006 XK Commander
My 2006 uk xh has a dpf but I don't think the wh did.
GDE HOT Tune
chrali is offline
post #53 of 91 Old 02-06-2014, 11:43 PM
manny31
2008 WK
Originally Posted by jaje View Post
The CRD is an "acquired taste" for many and the owners have to be more educated of the vehicle they drive as they are different and require more attention.
I never try to do the equation between a diesel and gasser by their EPA rating as it more often than not overstates a gasser's mpg as their test has nothing to do with real world (it's done on a dyno in a lab and takes only account for aero by adding "friction" to the dyno wheel). That means the vehicle can lug up to speed at low RPMs (think of the many Honda, Hyundai, Ford owners who sued the companies b/c real world mpg would not even come close to the sticker mpg). On the flip side diesels often have lower EPA ratings that you get in real world often because the engine is not worn in yet and by 20k miles their efficiency has significantly improved (by the tune of 1-2 mpg). Plus with a diesel real world driving doesn't affect its rating as much as they can lug under power and not use high rpms to get moving.
I do see your point and its valid. If you don't haul or tow and want to save money you can save quite a bit by getting (and I'm drawing this logic to the WK2) a v6 and it'll do everything you need and more (if you want to get a diesel you will find it hard to make up that delta versus the v6 as its substantially cheaper and you have to at least get a Limited to even get the diesel and it's $4,500 extra). Also the v6 is slightly faster to 60 mpg than the diesel but sprint acceleration has never been a strong suit of any diesel vehicle. Where the diesel makes sense is when you only compare it to the Hemi where it costs only $500 - $2,500 more (depending on options as the diesel includes several forced options such as the lux package on the 4x4 limited where you can get a Hemi without it).
Just don't forget in your evaluation that in 3-5 years you may not want to keep it and as the market demands - a diesel will have a higher resale value so you'll get more for your trade or private sale and more often than not recoup your higher upfront investment (all the while saving at the pump and to me the most important not having to visit the gas station as often) - I'm not much of a shopper for lottery tickets, donuts, 64 oz sodas, or energy drinks.
Something fun: Citroen AX 1.4 diesel (52 hp) doing sub 10 mins at Nordschliefe
The V6 is faster than the Diesel to 60. I DONT THINK SO. Something must be wrong with yours. I can take a hemi to 60 with air on and bikes on the rack.
08 CRD elephant mode, kidney empty. GDE eco tune, DPF gutted, 20' SRTs 265 and 295 stock height, SRT front bumper
manny31 is offline
post #54 of 91 Old 02-07-2014, 07:55 AM
james_2k
2003 WJ
i hope he doesnt mean in the wk, because if so yeah.. hes very very wrong haha
james_2k is offline
post #55 of 91 Old 02-07-2014, 08:29 AM
jaje
2007 WK
Was talking about the WK2 Ecodiesel versus the Pentastar.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #56 of 91 Old 02-07-2014, 10:43 AM
ZF1FR
2007 WK
My WH CRD, does not have a DPF. However that's because it's a 2005. Later they fitted DPF maybe 2007 or 2009.
US and particularly Cali are more restringent on emissions, but not that much. On some vehicles it leads to DPF and SCR systems.
But here in Europe in several countries have to pay a CO2 tax directly related to fuel consumption. That's why we have more "efficient" but pricier and more complex engines making them less reliable.
You don't feel loss torque may be because you have a huge margin over full load torque?
Atmospheric engines suffers from low atm pressure -> low air density wheras turbo engines could suffer from turbo spooling too fast. Most of the times, the manufacturers derate performance with altitude.
Maybe MB was large on it's turbo max speed.
ZF1FR is offline
post #57 of 91 Old 02-07-2014, 10:51 AM
james_2k
2003 WJ
soo.. pointless in a way. he was asking about the wk. what specs are you looking at by the way, it doesnt look like the crd is slower than the 3.7 in the wk2 either? bearing in mind there are two diesel engines for the wk2. the slower one is 10.2 secs and the faster one 8.2
my 2009 doesnt have a dpf. uk spec car.
with variable vanes / wastegate, boost should be constant up to a point. similar to aircraft with turbo chargers, boost is constant to a given altitude and then tails off.
james_2k is offline
post #58 of 91 Old 02-07-2014, 11:11 AM
ZF1FR
2007 WK
Did I say different?
ZF1FR is offline
post #59 of 91 Old 02-07-2014, 11:23 AM
james_2k
2003 WJ
to a point.
james_2k is offline
post #60 of 91 Old 02-07-2014, 01:57 PM
jjt250
2007 WK
I was gonna say, a WK V6 is definitely not faster. Mine is faster than my buddy's 4.7 by a good margin. Never raced a hemi though. The Pentastar with the 8 speed tranny in the WK2 is probably faster however.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
advice , diesel , wk
