Working: Torque App trans temp - JeepForum.com
 2Likes
  • 1 Post By mb81
  • 1 Post By colinzj
post #1 of 14 Old 03-19-2017, 07:02 PM Thread Starter
mb81
2006 WK
I just posted this on another thread buried in this forum, but thought I'd post my victory for others to enjoy.
I think I got it working. It's taken me a while because it hasn't been top priority of mine, but here ya go...
To get Torque App to read trans temp on my 2006 Grand Cherokee WK:
- Go to settings, manage customer OBD2 PIDs, select from predefined the last one [Chrysler]Transmission Temp (Jeep Pre 2012)... click it and select EDIT.
- Change the top field (OBD2 Mode and PID...) to 2118, leave the min/max, scale factor, and unit type (F* set elsewhere in settings), and equation alone. (Should be ((A*256)+B)*(1/64).
- Change the "OBD Header to use" to 7E1.
It will read the correct temp when the vehicle is running. (At least it did with mine).
Hope it works for any and all. Please let me know if it does. I'd like to think the time and money I spent on this wasn't a complete waste. Thanks!
2006 Grand Cherokee Limited 5.7 HEMI
mb81 is offline
post #2 of 14 Old 03-19-2017, 11:45 PM
underscore
2007 WK
Did you try using the post-2012 Chrysler PID?
2007 WK CRD QDII
underscore is offline
post #3 of 14 Old 03-20-2017, 06:20 AM Thread Starter
mb81
2006 WK
Yes, but I have the 545-RFE trans. The PID and formula are not correct for the 2012+. None of the predefined ones worked for my jeep model.
I guess I should have mentioned my set up in the original post.
When I bought mine last summer it was having the trans over temp issue. A new PCM fixed that, but initially I wanted to monitor the temp, like everybody else, and torque didn't have it like I thought it would... but now it does!
underscore likes this.
mb81 is offline
post #4 of 14 Old 03-20-2017, 07:30 AM
Nejeep
I also have the Torque app and the post-2012 Chrysler PID works with my 06 WK with NAG1 transmission when its in Drive (not Park).
Good to know there is a way to use it for the 545-RFE trans.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #5 of 14 Old 03-21-2017, 09:47 AM
08rubie1
What is the average operating temp for this trans? had my filter changed and the pan droped and refilled and im around 176 on the high way with 32inch mud terrains.
08rubie1 is offline
post #6 of 14 Old 03-21-2017, 12:19 PM
Nejeep
I have not monitored the trans temp on the road, just used it for checking the trans fluid level, but I seem to recall others indicating they run in the same temp range as yours.
EDIT: Found an older discussion, here the link.
http://www.jeepforum.com/forum/f67/t...l-app-3702369/
Nejeep is offline
post #7 of 14 Old 03-21-2017, 01:07 PM
PolkaPower
Atf4 starts to shear around upper 200*. Short spikes are ok but prolonged high temp will ruin the fluid and then the transmission.
I'd change mine if it ever got to 250* just to be on the safe side. Anything less I wouldn't worry about.
If you can put a temp sender in the hot line coming from the transmission before it reaches the cooler, you can see the hottest temps the fluid will reach right out of the torque converter.
It's a good place to monitor the fluid temps.
Remember, if your fluid is sheared then it's not going to protect the transmission.
PolkaPower is offline
post #8 of 14 Old 03-22-2017, 09:17 PM
GhostJeepWJ
GhostJeepWJ's Avatar
I have seen a few postings about this and get conflicting info. Has anyone gotten this to work on WJ? Mines a 2002 4.7
I have the Torque Pro and would love to be able to monitor my tranny. I'm using the Bafx adapter. Thinking of upgrading it to a better one such as the ScanTool.
Also I have yet to see what PID stands for.....
If you want to achieve greatest, stop asking for permission!!
2002 Grand Cherokee Overland 4.7 HO
2" IRO Spring Lift w/Bilstein 5100s 245/75/R17 Goodyear Armour Shield
GhostJeepWJ is offline
post #9 of 14 Old 03-22-2017, 11:49 PM
underscore
2007 WK
In my industry it stands for "proportional–integral–derivative", but that's for control systems.
2007 WK CRD QDII
post #10 of 14 Old 03-23-2017, 09:11 PM
colinzj
2006 WK
Parameter ID.
What a letdown, right?
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline
post #11 of 14 Old 03-23-2017, 09:58 PM
PolkaPower
Pizza Is Delicious?
post #12 of 14 Old 03-23-2017, 10:01 PM
GhostJeepWJ
I like Polka's better....lol
Parameter ID was to much of a let down!.....lol
post #13 of 14 Old 03-25-2017, 12:03 PM Thread Starter
mb81
2006 WK
As I understand it, 2002 obd2 used the ISO 9142-2 protocol, so the diagnostic port pinout is different from my 06 using CAN ISO 15765-4. I built a cable to listen to traffic on that port, but would need to modify it to work on your system (and do more research on it in general).
If I can locate someone nearby with a 4.7 WJ who wouldn't mind me messing around, I'll see what I can come up with for you.
mb81 is offline
post #14 of 14 Old 03-25-2017, 08:48 PM
GhostJeepWJ
That sounds awesome!!! Us 4.7 owners would love it!...lol
