WK transfer case fluid change write-up - JeepForum.com
post #1 of 36 Old 08-04-2009, 08:52 AM Thread Starter
conrasm
conrasm's Avatar
I did a search and didn't see any write-ups, so I thought I'd snap a few picture when I changed my wife's TC fluid. It was an easy job and I'd say it's as easy as changing engine oil.
Couple things that you'll need:
Set of ramps
container to catch the oil (only hold 2 quarts, so doesn't have to be big)
2 quarts of Mopar Transfer case lubricant (about $8 a quart from the dealer)
10 mm hex head or allen wrench (I think an attachment for a socket would give you more leverage)
Marine lower unit pump (not needed, but makes filling very easy) - I got mine at Gander Mnt for about $8.
Start with driving the front of your jeep onto some ramps to give yourself some room to work. This will also help tilt the TC to aid in draining.
Here's a picture of the back of the TC. I labled the fill and drain plug. They are both 10 mm.
I always try to loosen the fill plug first. You don't want to drain the fluid, then get stuck not being able to get the fill plug out to fill it up again. Both came loose easily. My wife's is an 06 and she just hit 60k miles.
Here you can see the remainder of the fluid draining out. It is similar to motor oil in color. I didn't take a picture of the mess I made trying to snap a picture when I first pulled the drain plug. It shoots out pretty far, so better to hold your drain pan close to the drain hole.
After reinstalling the drain plug, you can then remove the fill plug. I didn't take it out the hole way at first because it will run out some with the vehicle on the ramps. The lower unit marine pump works great. It probably took about 2 minute to pump a quart in.
The pump is designed to screw onto a standard 1 quart bottle and will pick up all but a 1/2 - 1 ounce of fluid. When the bottle starts to get empty, just tilt it to the side the pump is on.
A little trick you can do once you get most of the fluid in is to put the fill plug in loosely, back the jeep's front wheels off the front ramps, and move them to the back wheels, this way you will tilt the TC and it will be easier to get remaining fluid in without it wanted to run out the hole. I poured what was left from the first quart into the 2nd bottle and probably only have an ouce left over. I don't think that will make much of a difference.
I'm planning on using this pump when I change the diff fluid if I can't get the bottle in there. I'll let you know how that works out.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #2 of 36 Old 08-04-2009, 09:01 AM
Texas WJ
Texas WJ's Avatar
2005 WK
Tech write-ups are always welcome. Thanks for posting this. It really is an easy fluid swap...
Texas WJ is offline
post #3 of 36 Old 08-04-2009, 09:03 AM
thewalrus
2005 WK
Can someone start to sticky these? The most recent diff change ones, the spark plug one, and this one of course. It sure would be nice to have it at the top of the forum so people quit asking over and over how to do it. Maybe merge all the posts into one giant tech write-up.
-Thanks
ASE Master Tech
thewalrus is offline
post #4 of 36 Old 08-04-2009, 10:28 AM Thread Starter
conrasm
conrasm's Avatar
Maybe something like in the XJ section, a thread with links to the write ups.
Shawn
conrasm is offline
post #5 of 36 Old 08-04-2009, 11:27 AM
TonyVideo
TonyVideo's Avatar
2008 WK
Nice and simple write up. Thanks. The tip about lifting the rear is a great idea. Sometimes it's the little things that make it easier.
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #6 of 36 Old 08-04-2009, 11:42 AM
08WKJGC
Wow, and i cant believe i just paid my dealer $90 to do this. I will be doing this myself at 60k now.
1998 Jeep Grand Cherokee Laredo 4x4 | 4.0 L6 | Stone White
08WKJGC is offline
post #7 of 36 Old 08-04-2009, 01:22 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Just did mine today. Same tools as you. Good post. Thanks
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #8 of 36 Old 08-04-2009, 01:52 PM
brutusjeep
2014 WK
Great Post!
brutusjeep is offline
post #9 of 36 Old 08-04-2009, 03:47 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Wondering what others do. Mine's a NV245 (QDII)
The owners manual says fill to overflowing.
The Service Manual says 1.8L (3.8 pints)
I quit at 2L. It wasn't overflowing.
How much do you put in?
89 GW w/plow
wookiee is offline
post #10 of 36 Old 08-04-2009, 08:19 PM Thread Starter
conrasm
conrasm's Avatar
My dealer said they put 2 quarts in and that what they recommended I buy. The TC was tilted slightly up hill with the jeep on the ramps, so I'm sure it would start to run out if it was flat.
Shawn
conrasm is offline
post #11 of 36 Old 08-04-2009, 08:44 PM
konarider94
2005 WK
very good advice on removing the fill plug first. i was going to suggest that but you already did.
ive read lots of threads in the xj forum about people doing the opposite and having trouble when they cant get the fill plug out
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline
post #12 of 36 Old 08-04-2009, 09:31 PM
yrkoverland
Thanks!
Can we add to the FAQ PLEASE!! =)
yrkoverland is offline
post #13 of 36 Old 02-01-2011, 12:02 PM
b0ogeyman
2006 WK
I was wondering if this is the standard procedure for all WK's? I have an 06 overland QDII would it be the same?
Thanks
b0ogeyman is offline
post #14 of 36 Old 02-01-2011, 12:22 PM
jager00
2005 WK
Good write up! I will need to do mine soob im at 56k
2007 JK Sahara- trying to figure this one out
2005 WK 9" lift on 37's with all the goodies- regretfully sold :(
jager00 is offline
post #15 of 36 Old 02-01-2011, 01:24 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Thanks
Yes, it's the same procedure.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
231 Transfer Case fluid change + a couple questions littlefdl ZJ Grand Cherokee Forum 3 09-11-2009 03:40 PM
ZJ Transfer Case Fluid Change 98ZJBlack ZJ Grand Cherokee Forum 9 11-17-2008 10:21 AM
Transfer Case Fluid Change Mechanic Mistake! adgjqetuo ZJ Grand Cherokee Forum 13 02-19-2007 06:10 AM
Transfer Case Fluid Change dpierson ZJ Grand Cherokee Forum 13 07-26-2006 11:45 AM
tranny and transfer case fluid change write ups... askoop ZJ Grand Cherokee Forum 3 04-03-2005 09:35 PM
