WK Tow Hitch Install - JeepForum.com
post #1 of 20 Old 10-27-2010, 03:48 PM Thread Starter
cstrait37
2010 WK
Hoping someone could answer a couple questions for me... Just purchased a '10 WK Limited, HEMI, Torch Red (By far the BEST GC I've ). I HAVE to install a hitch (the only drawback is that the factory tow package box was not checked).
1) Any suggestions as to what hitch would work best? I don't tow a lot. Brand, Class IV, etc.?
2) The only hitches I have found online attach behind the license plate and require me to remove the tow hook PERMANENTLY. IS THERE ANY TRIMMING OF THE FACTORY BUMPER WITH THESE?
3) Has anyone installed a tow hitch that does NOT require trimming of ANYTHING? Name, brand, model would be VERY helpful.
Any other suggestions, please feel free... I really appreciate all the help in advance... Have a great day all!
CS
cstrait37 is offline
post #2 of 20 Old 10-27-2010, 03:57 PM
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
Yes, i have my 07 with the 5.7 also no factory tow package, i just went to uhaul and they installed it for me no cutting no nothing i would check it out
2015 WK2
--4x4WK--
smcginnis87 is offline
post #3 of 20 Old 10-27-2010, 04:02 PM Thread Starter
cstrait37
2010 WK
smcginnis- cost? I was looking for an excuse to do it myself... But goo to know. Is it the full boxed frame type> Thanks!
post #4 of 20 Old 10-27-2010, 04:06 PM
bumzo1
2005 WK
you can buy a curt hitch which rests below the bumper. If you buy the stock hitch you have to trim the bumper which is easier then it seems. There is a template already on the bumper and you just use a dremmel to cut it out. I'm about to install mine most likely this weekend. The curt would be easier but the OEM hitch will look much better.
'05 WK 3.7L | OME MD lift | 255/75/17 BFG M/Ts | 20" LED Light Bar
Khaki WK Club Member #1
bumzo1 is offline
post #5 of 20 Old 10-27-2010, 04:07 PM Thread Starter
cstrait37
2010 WK
bumzo- let me know how it goes.... GOOD LUCK and THANKS!
post #6 of 20 Old 10-27-2010, 04:11 PM
smcginnis87
4X4WK
2007 WK
its been years so i really have no clue....and what do you mean by full boxed frame?
2015 WK2
--4x4WK--
post #7 of 20 Old 10-27-2010, 04:15 PM Thread Starter
cstrait37
2010 WK
Brain fart- I meant the hitch that bolts to the frame rails as opposed to the curt hitch...
post #8 of 20 Old 10-27-2010, 04:24 PM
gornoman
2006 WK
You do understand that these vehicles are unibody and have no frames?
'06 Grand Cherokee Laredo 4X4 (26E), Steel Blue Metallic. 3.7, QTII Trail Rated, Factory Skids, Tow Package, RRO Rock Rails, 245-65-17 Bridgestone REVOS
Ipod, CB, Leather Steering Wheel, Fog Lights. Black Bear Road Alumni, Elephant Hill Alumni.
Blue WK Club Member #15
My other passion -
gornoman is offline
post #9 of 20 Old 10-27-2010, 04:31 PM
bumzo1
2005 WK
The oem and the curt hitch mount in the same spot
bumzo1 is offline
post #10 of 20 Old 10-27-2010, 04:38 PM
smcginnis87
4X4WK
2007 WK
mine hangs past the bumper it attaches to some sort of frame.... but not directly in the stock location,...if you can see it in these pics
2015 WK2
--4x4WK--
post #11 of 20 Old 10-27-2010, 09:29 PM Thread Starter
cstrait37
2010 WK
everybody picking on the noob... Sorry for my transgressions... The pics are great and a big help! Thanks!
post #12 of 20 Old 10-28-2010, 01:47 PM
bilbo_28
2014 WK
cstrait37 - by the Jeep hitch and surround and cut the bumper.
I bought a 'bolt under' hutch for my WJ and did not like the look of it against the factory fit, so when I bought my WK I decided to take the plunge and cut the bumper.
The worst part is psyching yourself up to make the first cut. As someone above said the template is already marked on the inside. Once you get going its easy, just make sure you have a set of helping hands because the bumper is too much to hold, support, move and cut at the same time.
The kits come with all the new clips to put the bumper back on. It took me about 30-45 minutes start to finish.
Good luck!
bilbo_28 is offline
post #13 of 20 Old 10-28-2010, 02:21 PM
criket
2005 WK
can you remove the spare tire and cut the bumper while it's on the vehicle? I haven't had time to crawl up under it and have a looksee.
2005 | WK | Khaki | 3.7 | QT1 | OME HD Front Struts | Rusty's 2" lift in Rear w/ Monroe load levelers (F150 version) | 265/70 Nitto Terra Grapplers | 17" Moabs | 1.5" wheel spacers | Pinch weld mod Rear fender trim mod | 4xG Matrix w/ reciever hitch | 4xG Belly guard | SOLID Diff cover | Cobra CB radio | 4xG antenna mount | Rola roof
criket is offline
post #14 of 20 Old 10-28-2010, 02:32 PM
gornoman
2006 WK
Nope. It's gotta come off to mount the hitch anyway.
My other passion -
gornoman is offline
post #15 of 20 Old 10-28-2010, 02:33 PM
bumzo1
2005 WK
I would think so but you would get much better results if you just take the bumper off
bumzo1 is offline
hitch , install , tow
Wj hitch install G-Wagon00 WJ Grand Cherokee Forum 16 05-09-2013 10:50 AM
OEM Hitch Install _Kyle_ ZJ Grand Cherokee Forum 9 05-29-2009 06:24 PM
02 Gc Trailer Hitch Install And Wiring Install evanlaczi ZJ Grand Cherokee Forum 2 03-02-2009 10:10 PM
hitch install neuman WK Grand Cherokee & XK Commander Forum 17 12-03-2008 01:08 PM
need hitch install help clocker ZJ Grand Cherokee Forum 2 08-15-2006 09:23 PM
