WK Submarine - JeepForum.com
post #1 of 11 Old 02-28-2013, 08:36 AM Thread Starter
jb1961
WK Submarine
So my eighty-three year old father comes home safely the other night in his stock '05 4.7L WK and announces that the crossing at his private creek was "a feet feet above flood stage." Whoa, that's a big deal dad! Now, he does cross this ford daily and the WK, with 125K miles still shows no obvious signs of damage. This time though, water flowing above the rocker panels? Dam* car stayed dry and easily conquered the crossing. What a vehicle. Really. However, I am now curious though, given the fact that the WK gets wet frequently and on occasion, submerges all if its drive components, what is the most likely part(s) to fail? Bearings, seals etc...help me target some preventive maintenance.
It is a real tribute to WK though. Never had an issue.
jb1961 is offline
post #2 of 11 Old 02-28-2013, 09:11 AM
trax95008
2006 XK Commander
Impressive! Do you have an idea on the actual depth? Are we talking close to 3 feet?
trax95008 is offline
post #3 of 11 Old 02-28-2013, 09:30 AM
SSF556
2008 WK
That is a cool story...using my Jeep below as a reference:
2ft = top of wheels
3ft = just under the red badge on the side or equal to the front wheel arch.
3ft is a lot water for a stock WK to be crossing. The most I have ever been in is about 2 ft.
If this is a regular occurrence you may want to relocate the the diff breather and the transfer case breather
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #4 of 11 Old 02-28-2013, 02:08 PM
terrasmak
2007 WK
How long is the crossing? Is the jeep in the water for 2 seconds or 5 minutes
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #5 of 11 Old 02-28-2013, 05:07 PM
gemiller
2008 WK
Best water prepped WK i've seen
I've taken my stock height (pre lift) through 2+ ft np. I cross a creek on the way to the cabin that ranges from 14" -36" throughout the season. I didn't dare cross at high level last year, but this year with the OME and 265's/275's coming soon i'll go for it no hesitation. The double door seals really do work well when I had water up above the rockers.
gemiller is offline
post #6 of 11 Old 02-28-2013, 06:44 PM
daveWK42
2008 WK
i stayed on the island during sandy this fall & we had about 2ft.+ of water in the front yard. came up to the trim line of my WK w/ it's 2" daystar BB. stayed completely dry inside! sandy was a test & a half, both for the jeep & the community. here's a pic of the wrackline on my jeep after the water went down & as it stands now:
Living well is the best revenge
hers: 2013 patriot sport
his: 2008 grand cherokee laredo
daveWK42 is offline
post #7 of 11 Old 02-28-2013, 07:03 PM
BAH101
2008 WK
I got high centered in water that came to just below the inner door seal. Had to sit there for an hour for help to come and give my a pull out. Ended up vacuuming 4 gallons of water out from under the carpets. Next day They were still wet, so I pulled all my carpets and found there are numerous drain plugs on the belly. If they are not sealed, and your jeep is stuck in water, it will come in.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #8 of 11 Old 02-28-2013, 10:01 PM
TurboDiesel
2008 WK
Originally Posted by gemiller View Post
http://www.youtube.com/watch?v=qbNtGXQh1Mc
http://www.youtube.com/watch?v=p0rWCA-DNJw
oh no u just posted a Gary video...thats a ban!!
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is online now
post #9 of 11 Old 03-01-2013, 02:35 AM
Valpacer
2007 WK
As said above, rear diff breather is a must, if you have just driven through then bearings etc wont be affected, if you have sat there for a while, everything under the waterline will have a shortened life span.
Ive had water to just below the bottom of the windscreen in mine, multiple times, but i wouldnt recommend it. Not muddy, just fresh water so i wanst going to get bogged. Didnt hang around either......
Hot parts that get dunked in cold water suck in the cold water to even out the temp difference, and thats where breathers need to be checked as they will suck in water to the diff or transfer etc, as it will through the diff seals etc.
Got reminded of this vid last week actually! This was ages ago, running a seriously sagged OME lift and 31" tyres. Back when the panels were straight
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #10 of 11 Old 03-01-2013, 07:26 AM
cherrybomb05
2010 JK Wrangler
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #11 of 11 Old 03-01-2013, 03:44 PM
Jeepforthewin
2010 JK Wrangler
Check the transfer case for sure. I had to pay $950 to replace mine after the previous owner took it through some water and didn't get it checked and the thing was pretty much filled with water
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
