Wk Sputtering... Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Wk Sputtering... Help
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete
Unread 07-06-2014, 10:17 AM   #1
thelms
2009 WK
Hi there everyone. I am new to the forum and I have a question.
I have a 2009 Grand Cherokee. It has recently started sputting when driving. It seems to do it when I have the gas pedal barely pushed in. When I accelerate it does just fine and no sputter. I haven't noticed it sputting when I am stopped either. It's not all the time and no lights have came on. Also the check engine light isn't on.
It has 83k miles on it. It also has the 3.7 v6. I recently replaced the air filter and it does seem like it has helped.
I have heard from a few local people that it could be anything from fuel filter, fuel pump, fuel injector, spark plugs, spark plug wires or o2 sensor.
I could really use some help. Thanks.
thelms is offline   Reply With Quote
Unread 07-06-2014, 11:19 AM   #2
tom19511
2006 WK
Try spark plugs first. They should be changed every 30000 miles.
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is online now   Reply With Quote
Unread 07-06-2014, 11:28 AM   #3
thelms
2009 WK
What would be the best spark plugs? Should I stick with NGK copper? Or go with others? Also is it fairly east to do in a WK? I have done it in a wrangler and my cars, but not a WK.
Unread 07-06-2014, 01:15 PM   #4
modernblueWK
Get the stock replacement plugs. They go in from the top under each coil. Held down by the coil packs which are held down with 10mm nuts. I unplug each coil. A little dielectric grease in the connector, inside the boot and some anti sieze on the plug threads.
2008 WK 4.7 245/70-17 Grabber AT2 - Magnflow - JBA - G2 - Steel Armadillo - MLL's
Blue WK club #4
modernblueWK is offline   Reply With Quote
Unread 07-06-2014, 01:19 PM   #5
thelms
2009 WK
Thanks tom19511 and modernbluewk for the information. I am going to pick up the NGK 6987 spark plugs after work today. I hope to have them installed in the next few days. I just hope this is it and nothing else.
Unread 07-07-2014, 08:43 AM   #6
tom19511
2006 WK
Great, Please let us know how you made out.
Tom19511
Unread 07-13-2014, 11:02 AM   #7
thelms
2009 WK
I am finally able to do the install tomorrow. But I have noticed something strange. I only have 3 coil packs on the drivers side. I was told that there should be 6 coil packs. Has anyone else experienced this?
Unread 07-13-2014, 12:25 PM   #8
modernblueWK
3 on each side. V6
Blue WK club #4
Unread 07-13-2014, 03:05 PM   #9
thelms
2009 WK
I have looked under the hood and I don't seem them on the passenger side. I have heard of other 2009 WK with the 3.7 only having 3 on the driver side. Looks like a wire is running to the other side of the motor to where the other spark plugs would be.
Unread 07-13-2014, 03:07 PM   #10
thelms
2009 WK
also my coil packs on the driver side is held down by a bolt and not the nut like others have posted.
Unread 07-13-2014, 04:54 PM   #11
modernblueWK
Well 3 coils or 6 your spark plugs are in the same place. Straight down into the heads. So look for spark plug wires in this area.
Blue WK club #4
Unread 07-13-2014, 04:57 PM   #12
modernblueWK
http://www.jeepforum.com/forum/f67/2...p-how-1346787/
Heres my writeup for the 4.7 v8.
Blue WK club #4
