WK Remote Start Xpresskit and Smartstart Writeup - Page 2 - JeepForum.com
post #16 of 36 Old 12-25-2013, 05:33 PM
kona2four
First of all, great write up. I purchased the DBALL2, Xkloader, XL202 and T-Harness for my son's 2006 WK 3.7 Laredo as a Christmas present. We attempted to install today but have not been able to get it working.
A couple of things strike me as odd (besides the fact that it will power accessories but won't crank):
1) xpresskit says the flash goes okay but it shows my browser as Mozilla and not internet explorer.
2) after plugging the final blue connector to the DBALL2 I get a flashing orange light which indicates vehicle not ID'd. I turn key to "ON" per directions but still nothing. If I start the vehicle then green light flashes. I turn it off, hit the lock button and I'm good to go except ...
As I mentioned it will power accessories after hitting lock 3 times but it won't crank.
I'm at a loss. Does anyone have any suggestions.
Thanks,
Mike
kona2four is offline
post #17 of 36 Old 12-28-2013, 11:26 AM
kona2four
Thanks,
Mike
I just wanted to follow up with the"fix" Make sure you use good light. I connected a red yellow rather than a yellow red. Switched it around and works great. I am sofa king we todd did!
post #18 of 36 Old 02-15-2014, 07:48 PM
Btm495
2006 WK
Hey guys, I need a little help. I have the dball with the T harness. I hooked it up figuring it was plug and play. I programmed the module with the xloader from the site. Plugged the T harness in and attached the two seperate wires. Tried getting it all to work and nothing. My light started red and went to flashing green like it should. When i pull the key and hit the lock button to finish the program, the light goes to a solid red. I have it set to start by hitting lock 3x. I havnt had any luck yet. So is someting hooked up wrong or is it actually that tricky to get it to start from the lock 3x? Should I just add the xl202 with a rf to get it to work better?
I DO IT FOR THE ADRENALINE RUSH
� � � ��2000 Blue&Silver BUSA
� � � � 1999 Gixxer 600 #495 track bike � � � � 2001 Honda cr 250r
� � � � 2001 Grand cherokee I6
Btm495 is offline
post #19 of 36 Old 02-15-2014, 08:18 PM
Btm495
2006 WK
This is getting installed on my 2006 SRT8 Grand Cherokee. I am trying to fix my signature and profile picture.
Btm495 is offline
post #20 of 36 Old 02-16-2014, 08:06 AM
Btm495
2006 WK
Just wanted to update . So much to my surprise this morning, I'm telling my wife that my remote start doesnt work. I hit the button 3x and presto she fires right up I alomst fell over. She was laughing. Said I should of seen my face. So that means that I wired her up correctly. I'm thinking I will prob get the added xl202 module and remotes to make it easier.
Btm495 is offline
post #21 of 36 Old 02-17-2014, 11:48 AM
DieselDevotion
2007 WK
Originally Posted by Btm495 View Post
Just wanted to update . So much to my surprise this morning, I'm telling my wife that my remote start doesnt work. I hit the button 3x and presto she fires right up I alomst fell over. She was laughing. Said I should of seen my face. I about ****. So that means that I wired her up correctly. I'm thinking I will prob get the added xl202 module and remotes to make it easier.
I've been using the 3x lock for quite a while now and it works flawlessly for me.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #22 of 36 Old 08-15-2014, 01:11 PM
davidtownsend
2006 WK
Def want to do this asap! i love remote starts! Nice write up.
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #23 of 36 Old 08-15-2014, 02:50 PM
murderedoutGC
2016 WK
seems like one of the cheaper mods out there....nice write up
2016 GC Overland High Altitude White on black
murderedoutGC is offline
post #24 of 36 Old 07-28-2015, 12:50 AM
clemsonscj
2009 WK
I'm a bit confused about one thing with this thread. Does the OP have factory remote start or anything like that? Do you need an aftermarket remote start system already installed?
I have an 09 Overland GC with the 5.7 and factory remote start. I also already have a SmartStart module and Viper 5904 security/remote start system that I pulled out of my old truck. Can I just buy the DBALL and be good to go with just the SmartStart and factory remotes?
'09 Grand Cherokee Overland 5.7L HEMI QUADRA-DRIVE II
Black WK Club #134
clemsonscj is offline
post #25 of 36 Old 07-28-2015, 05:16 PM
clemsonscj
2009 WK
Bump
Black WK Club #134
post #26 of 36 Old 07-29-2015, 01:46 PM
clemsonscj
2009 WK
Bump again?
Black WK Club #134
post #27 of 36 Old 02-02-2016, 12:33 PM
xsparta11x
2007 WK
Kindda, If you purchase a DBALL, you can plug in your smart start module to it and get that going as long as it is still active. The DBALL will allow you to use the factory remote as a the start remote. Sorry I just resurrected this thread.
xsparta11x is offline
post #28 of 36 Old 05-17-2016, 03:48 PM
kryton
Excellent write up & really helpful when it came to installing mine. The only issue I have which I hope someone can help with is my heated seats. They come on as programmed (either low or high, I've tried both) but even if it's boiling hot, they still come on like the dball doesn't care what temperature it is. Has anyone else had this issue?
kryton is offline
post #29 of 36 Old 05-18-2016, 07:55 AM
kryton
Just spoken to DEI & they say my unit doesn't have this feature. I'm confused as others seem to be using it & it does work as far as turning the heated seats on at the correct level, its just ignoring outside temperature. Something weird going on here
Jeep; Rescuing Land Rovers since 1947
kryton is offline
post #30 of 36 Old 05-18-2016, 08:30 AM
wraycoli
2008 WK
I know they said you don't have the "feature", but I find that hard to believe if you're updated to the latest firmware.
Just to cover the bases here, you do have the #7 feature programmed to an option other than "Always On", correct?
screenshot from page 20 on install/config doc:
http://directechs.blob.core.windows....ga20150626.pdf
08 WK 4.7 QTII Rocky Mtn|BB|4600 Front|OME HD, 5100 Rear|GY Wrangler AT Adventure 265/70/17
wraycoli is offline
