WK (and possibly others) LED lighted cupholders - Page 48 - JeepForum.com
post #706 of 801 Old 04-05-2014, 01:01 PM
davy27
Hey Craig,
is it possible to order just the driver side LED cupholder?
Accidentally snap the connections to the cupholder when i was jiggling it around to try to get the colors to sync.
Also i noticed coffee stains were able to seep through so just a word of caution to all coffee drinkers.
Also about the ambient lighting...
Sorry if it was mentioned in ealrier posts but does the dim level stay the same after you turn off and on the car?
davy27 is offline
post #707 of 801 Old 04-05-2014, 01:46 PM Thread Starter
craigbru
2007 WK
Originally Posted by davy27 View Post
Hey Craig,
How long ago did you order your rings? I'm assuming you have the older two piece design without the soldered connections? If so, PM me your address and I can send a new pair of LED strips. The new rings are a 1 piece design, so seepage shouldn't be an issue. They also have a bedliner surface so they are pretty durable.
The ambient lights match the rings, and the lighting level should stay the same after a restart. If it doesn't, it's likely due to a bad controller, and in that case, I'd replace it.
Jeep-Core
craigbru is online now
post #708 of 801 Old 04-07-2014, 12:28 AM
scootter82
2009 WK
Any plans to make a HEMI version? I'd preorder that!
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline
post #709 of 801 Old 04-10-2014, 06:16 PM
davy27
I believe in Sept of 2013? I dont have a prob purchasing one but since i see the JEEP logo ones, im leaning towards that
Few questions for the Jeep logo rings...
can i just swap out my old rings and plug the logo rings in? (using the old remote?)
Are they they are a 1 piece design?
Also about the ambient kit..
Can it be wired independently? and not to the cupholders? The cupholders i usually have it on the brightest level but like the ambient lighting dim.
As you can see Im preparing to make another order once the wireless remote comes back in stock!
davy27 is offline
post #710 of 801 Old 04-10-2014, 06:26 PM
hxdrummerxc
2008 WK
Hey Craig, I sent you a pm.
I noticed you had some of the logo kits in stock for the 08'. Was wondering if I could get that mix-matched set. Ill pay for a whole new set even though I just needed the rings/leds. Ill just take a whole new package. Tomorrow is pay day, so it would be perfect timing. Lemme know. Thanks
Id also pay for ambient lighting kit when you get them.
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #711 of 801 Old 04-10-2014, 06:35 PM
sickchilly
2010 WK
I finally got my ambient and cup holder lights installed last night. If you need a report of a flawless install, I can make it. Everything worked perfectly the first time. The mode/color/brightness is remembered through power cycles and all 4 LED strips stay in sync.
If I have to nitpick, it would be that the cup holder discs could be about a half mm bigger in diameter. After reading some posts about them being really tight, I was surprised to see I could spin them (not easily, but just so) in my 2010. I put a couple small dabs of silicone on each to hold them in place. Once dry, you can't move them by accident, but you can still get them out if you need to.
It'd also be nice if the wiring connectors were captive. I wrapped each connection with a bit of electrical tape so they wouldn't work free down the road or while I was futzing with tying things up.
All in all though... great work, nice quality, and a complete kit for a very decent price. Thanks.
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is online now
post #712 of 801 Old 04-10-2014, 09:11 PM Thread Starter
craigbru
2007 WK
Yeah, I do plan on making some.
Yes, you can swap out the rings without changing the controller.
They are indeed a single piece design now. I'm milling the acrylic from both sides. It's more machine time, but a better product all the way around.
The ambient lights can be wired separately utilizing a second controller. If you order a new kit, you'd have a second controller.
I'm not sure when my next batch of wireless controllers will arrive, but a page back I've got links for alternative sources.
Oh dang, I forgot to respond to that. I could do mixed set, but someone would have to be willing to buy it's 'opposite' since the rings are matched sets. Any takers?
A little small? I think you are the first to mention that. I do want them tight enough to stay in place without issue. I can revise my design if needed.
There's really no feasible way to use captive connectors with the parts I'm using. I do have a huge roll of heat shrink inbound however. I'll be adding shrink to the kits that can be used to secure the connections.
One more thing guys. I apologize if I'm a little slower responding to stuff than I was a week or two ago. I think I mentioned earlier in this thread that the wife and I bought a new house in Omaha. Well, she already moved in a while back, but I haven't yet. I'm still almost 2 hours away at the old house. I've been helping my dad finish building a new house here, and we've only got about a week's worth of work left. I've accepted a new job in Omaha as a CNC machinist (haha, imagine that!), and I've been working on packing my things up. Over the next two or three weeks, I've got to get fully out of this house, and try and get a shop set up down there. I'll work on getting as many rings made as possible before I do, since I don't want to have any downtime. As it is, I've had some sets go out of stock already and haven't had a chance to fire up the CNC. I hope you guys understand, and I appreciate your patience. All in all this is a very good move, but it's a little disruptive until I'm actually there.
Jeep-Core
post #713 of 801 Old 04-11-2014, 03:37 AM
hxdrummerxc
2008 WK
So in case anyone missed that. Im trying to get a set of mix-matched cupholder rings for 08-10 models with "jeep" on one cupholder and "ORT" on the other. But I need someone else to also want this. I would need someone to purchase opposite sets so we can have them mix-matched by Craig.
Also Craig, if someone was willing to buy the opposite set, Would both rings work for either cupholder? Because I would really want the driver cupholder to say "Jeep" and the Passenger to say "ORT". But I thought the rings were slightly different for each cupholder. Which would mean someone else would have to have "ort" as the driver side and "Jeep" as the passenger? or are both rings the same? I can't remember. If that's the case Im not sure if anyone would want that. It seems sort of backwards that way.
Also If nobody is willing to go in with me on a mix-matched set.... id be willing to pay a little extra.
post #714 of 801 Old 04-11-2014, 04:05 AM
caulk04
2008 WK
I felt mine could have fit a little tighter as well, but ended up gluing then in place as it seemed the radius in the cup holder was causing the fit issue with the square corner of Craigs insert.
The heat shrink he mentioned wwill work great to hold the connectors, it's what I did with mine to keep everything in place.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #715 of 801 Old 04-12-2014, 12:25 PM
Mitkch
2007 WK
...I would need someone to purchase opposite sets...
I got so excited for a second because I was interested in getting one with Jeep and one with ORT but then I realized I have a 2007 and my cup holders are different than yours...
*sigh*
Black WK Club #138
Mitkch is offline
post #716 of 801 Old 04-13-2014, 12:56 AM
hxdrummerxc
2008 WK
*sigh*
Damnit..... lol
post #717 of 801 Old 09-17-2014, 10:49 AM
connie1973
2009 WK
hi Graig,
i visited your site but they are all sold out. Will you make some more ? I have a 2009 WK and the diameter of the bigger holder is 7,2cm and the smaller about 7,0cm. Would the discs fit tightly in my holders ?
connie1973 is offline
post #718 of 801 Old 09-17-2014, 04:10 PM Thread Starter
craigbru
2007 WK
Originally Posted by connie1973 View Post
hi Graig,
I need one good weekend... I've been so swamped lately with work commitments that I've not had time in the evenings to get anything done in the shop. As a result, a lot of items are sold out. I do have some late model WK rings made, but I'm waiting on a new shipment of controllers to arrive. I'm hoping that happens in the next week!
Jeep-Core
post #719 of 801 Old 09-17-2014, 06:40 PM
tom19511
2014 WK
Welcome back, Craig!
Tom
tom19511 is offline
post #720 of 801 Old 09-17-2014, 08:53 PM Thread Starter
craigbru
2007 WK
Haha, I have been pretty quiet lately. I drop in most every day, but between moving and a new job not too long ago, my posting has taken a hit. With summer activities winding down, that's gonna change!
Jeep-Core
