WK (and possibly others) LED lighted cupholders - Page 44 - JeepForum.com
post #646 of 801 Old 03-01-2014, 07:04 PM
94jeepman
2005 WK
Thanks Craig just got my inserts.going to install tonight
94jeepman is offline
post #647 of 801 Old 03-02-2014, 12:24 AM
aralph30
2003 WJ
Where can I find a write up for the installation. Does anyone know ?
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #648 of 801 Old 03-02-2014, 12:39 AM
94jeepman
2005 WK
Jeep-core.com under the installation instruction section
http://jeep-core.com/installation-instructions/
post #649 of 801 Old 03-02-2014, 08:44 AM
jtodaro
2014 JK Wrangler
Craig... Just an FYI on your instructions for the WK. It doesn't say which one goes in which cup holder (since they are two different sizes). Just figured I'd point that out there since you were revising the instructions (or so I thought I saw).
2014 JKU Sport Anvil
jtodaro is online now
post #650 of 801 Old 03-03-2014, 08:48 PM
t_ewing3
If I were to choose the "standard wired controller" option on the website, are the colors able to change when installed, or would I have to choose one color when checking out?
t_ewing3 is offline
post #651 of 801 Old 03-03-2014, 11:03 PM Thread Starter
craigbru
craigbru's Avatar
2007 WK
That's right, it doesn't. I should make note of that. Especially since some years only have a single mm difference between the rings.
Yes, you choose the color you want when installing. No need to lock into a single color. The wireless controller allows you to change much more easily on a whim. It uses a credit card sized wireless remote. The standard controller is inline between the power source and the LED's. You can always creatively mount it so it can be accessed easily, but a lot of guys just set their preferred color and then stash it.
Jeep-Core
craigbru is offline
post #652 of 801 Old 03-03-2014, 11:03 PM
Keeslinger31
2005 WK
Afaik you use the remote and change color and brightness then you can stash it once you've picked
05 Hemi ome hd/spacers 265/70 Geolandar
winch HLM aspen creek grille defaced wheels
Black WK #126
Keeslinger31 is offline
post #653 of 801 Old 03-04-2014, 05:02 AM
caulk04
2008 WK
Hey, is it normal for the brightness to reset to the highest level every time power is cycled to the controller? I was hoping to leave them dimmed down some but it always resets. Keeps the color, but defaults the brightness.
As far as changing colors goes, you can keep the controller hidden under the shifter bezel, it's very easy to pop that off and get at the controller.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #654 of 801 Old 03-04-2014, 06:42 AM
aralph30
2003 WJ
Order mine today. Can someone post a link to a write up on how to install it. Need something with pictures lol.
aralph30 is offline
post #655 of 801 Old 03-04-2014, 07:38 AM
caulk04
2008 WK
Listed for both early and late WK's. Basically you need access to the bottom of the cup holders and need to make a slot in the bottom of each for the wiring to run through. It's really quite simple.
caulk04 is offline
post #656 of 801 Old 03-04-2014, 10:25 AM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Nope, that's not normal. Mine doesn't reset, and I haven't heard anyone else mention it. It's possible the controller just isn't working as it should. If it doesn't resolve itself somehow, I'll send you a replacement when my next batch comes in, as I'm currently out.
Jeep-Core
craigbru is offline
post #657 of 801 Old 03-04-2014, 10:29 AM
caulk04
2008 WK
That'd be mighty cool of you! I've been ignoring it, but I'll keep trying to set the brightness down and let you know if it starts working right.
caulk04 is offline
post #658 of 801 Old 03-04-2014, 10:31 AM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Not a problem man. I want you guys to be happy and have the features promised. I always keep mine on the lowest setting as well. I like it subtle.
Jeep-Core
craigbru is offline
post #659 of 801 Old 03-04-2014, 12:06 PM
Mustangt125
Is there any way to do this without taking the car apart? Probably not, just thought I'd ask...
It looks amazing in the pics youve posted but I will just be getting a Jeep soon and have no experience working on cars, don't want to screw anything up.
Mustangt125 is offline
post #660 of 801 Old 03-04-2014, 12:20 PM
caulk04
2008 WK
It's super simple guys, just pop the shifter bezel off and you have the access you need. I just opted to go a little further and pull the whole console out.
caulk04 is offline
