WK (and possibly others) LED lighted cupholders - Page 38 - JeepForum.com
post #556 of 801 Old 10-27-2013, 10:59 AM
marka2k
2006 WK
I would check and make sure nothing is loose (connector wise) in the area where you ran the wiring, if everything is tight disconnect power to the LED Cupholders and see if that solves the issue.
Originally Posted by Goldenknob View Post
anyone have problems with tire pressure sensor or keyless entry after install? i have suddenly had these random problems and that is all i have changed. the keyless started working again after 2 days of not working, only to have tpms start blinking at me.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #557 of 801 Old 10-28-2013, 07:03 PM Thread Starter
craigbru
craigbru's Avatar
2007 WK
There shouldn't be anything with the LED's that could possibly cause an issue. If you tapped into your power outlet, it wouldn't appear any differently to the WK than any other 12v powered accessory. It's probably just a coincidence.
Now, how about a small update? I've got the accent lighting kit figured out. I found a method that shows just the right amount of lighting. I will have to make small plastic mounting tabs, but overall it won't be bad. That also means they'll be pretty cheap. I'm thinking I can do about $20 shipped.
I've got to wait for a few replacement parts for my CNC though. I had a bearing go out, and they were going to send me a whole new batch. I won't be cutting until they arrive and are installed. Ah, gotta love delays.
Jeep-Core
craigbru is online now
post #558 of 801 Old 10-28-2013, 09:06 PM
jscaffidi
Awesome news on the accent lighting. Is it for the front and rear or will you need two kits to do both? Considering the delays for your replacement parts, when do you figure to have some in stock? Thanks.
jscaffidi is offline
post #559 of 801 Old 10-29-2013, 08:29 AM
rhopkin
2014 WK
JK 2102 Possible? Would love to put them in my JK!
rhopkin is offline
post #560 of 801 Old 10-30-2013, 09:17 AM
davy27
Originally Posted by jscaffidi View Post
Davy27, in the first and third pictures there is a round illuminated object roughly where the keyed-power outlet would be on the bottom left of the dash - is that a push to start button and if so which one did you get? Do you still need to use a key in the ignition? Thanks.
that is just a usb charger.
Still loving these!
davy27 is offline
post #561 of 801 Old 10-30-2013, 10:03 AM
Yooshaw
2007 WK
I don't have these lights, but I can attest that some electronics seem to interfere with TPMS and keyless entry. I have a dashcam that I plug into the cigarette lighter, and every time it wreaks havoc on TPMS and keyless entry. When I unplug it, it goes back to normal.
Yooshaw is offline
post #562 of 801 Old 10-30-2013, 02:59 PM
andygio71
Which dashcam do you have?
andygio71 is offline
post #563 of 801 Old 10-30-2013, 09:38 PM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Ah, I honestly didn't think of that. If I do the rear, should the lighting be under the back of the front seats? Would you rather see a single kit with all lighting included?
Yep, they are coming!
Still loving these!
Awesome!
Jeep-Core
post #564 of 801 Old 10-31-2013, 07:00 AM
jscaffidi
Yes, the lighting for the rear should be under and to the rear of the front seats. See page 8 pr 9 of the instructions for the newer mopar ambient light kit (http://site.justforjeeps.com/guide/82212347.pdf). The older kit only had the front footwells illuminated.
Yes, I would also like to see a single kit so that it can all be installed at once and all be controlled by one controller. Thanks again for your great work on this.
post #565 of 801 Old 10-31-2013, 07:47 AM
Yooshaw
2007 WK
One that I picked up while stationed in Korea. Don't recall the brand now, but I've never seen them in the states.
I also theorize that this problem only affects 2005-2007 models, as in 2008 the frequency of the TPMS sensors changed from 315 MHz TO 433 MHz. But I've never tested my dashcam in a 2008 or above.
Yooshaw is offline
post #566 of 801 Old 10-31-2013, 01:18 PM
Goldenknob
2007 WK
instead of hooking up the the wiring for the cig lighter maybe if I tie in somewhere else the problem would go away?
Goldenknob is offline
post #567 of 801 Old 10-31-2013, 03:18 PM
marka2k
2006 WK
The reason why I suggested to disconnect power to the LED/Control module and see if the problem goes away, this way you will know for a fact if it's the LEDs or not causing the issues
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
marka2k is offline
post #568 of 801 Old 10-31-2013, 03:25 PM
Goldenknob
2007 WK
lol yea I'll do that first. But been to lazy to take it all apart. It was just an advanced question. Heh
post #569 of 801 Old 11-08-2013, 06:46 PM
aralph30
2003 WJ
Do u make these for wjs as well
I LOVE MY JEEP MORE THAN MY GIRLFRIEND :p
aralph30 is offline
post #570 of 801 Old 11-09-2013, 11:07 AM Thread Starter
craigbru
craigbru's Avatar
2007 WK
I do. I had a bearing go out and although I only asked for one replacement, I was sent an entire set. I'm using that opportunity to overhaul my CNC. It should be back up next week.
Jeep-Core
