WK (and possibly others) LED lighted cupholders - Page 21 - JeepForum.com
post #301 of 801 Old 05-19-2013, 01:02 PM
hxdrummerxc
2008 WK
Originally Posted by craigbru View Post
Those look fantastic man! Mind if I put your pics in a gallery on the website? What you did with the controller looks pretty good. Maybe I'll add some commentary to the install instructions showing it as an optional way to go.
Thanks man!
Yea no problem man.
BTW, Im still trying to see if I can get those measurements of the JK for you.
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #302 of 801 Old 05-19-2013, 07:30 PM
audiophonicz
2007 WK
FYI: On With Lights
Not sure if this has been mentioned yet, but:
For those of you that remember the original post, Craigbru hooked his LEDs to the Orange (+) and Black (-) wires of the 4wd LO to come on with the parking lamps. Yet in the instructions he has it hooked up to the Cig Lighter power to come on with switched Acc power. The reason is the amperage on the t-case plug isn't enough to push the LEDs, and they simply don't light up.
Long story short, the entire console's lights are powered by the same fuse as the passenger side parking/tail lights. #10 in the image below, 10AMP mini fuse.
Throwing in a mini Add-A-Line from Advance Auto with another 10 AMP fuse, you can wire in the LEDs to come on with the lights using virtually the same circuit the prototypes used.
-wkjeeps.com
audiophonicz is offline
post #303 of 801 Old 05-19-2013, 07:40 PM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Originally Posted by hxdrummerxc View Post
Yea no problem man.
Outstanding!
-wkjeeps.com
Wow, great post. I didn't get a chance to expand on this earlier, but you are completely correct. That's also a great method to use for those guys that are leery of tapping into any OEM wiring. If anyone chooses to take the route audiophonicz suggested, pics would be appreciated. I can then add them to the install instructions.
Jeep-Core
craigbru is offline
post #304 of 801 Old 05-19-2013, 07:50 PM
audiophonicz
2007 WK
I'll get you some pics tomorrow.
post #305 of 801 Old 05-19-2013, 07:51 PM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Thank you very much. I appreciate it!
Jeep-Core
craigbru is offline
post #306 of 801 Old 05-20-2013, 12:15 AM
rollindom
rollindom's Avatar
2005 WK
I placed my order last weekend and received it Friday in Pasco, WA. I got them installed today was very happy with how they look as well as how easy they were to install. I thought I'd point out that the RGB controller allows you to turn the lights off completely. So even if you don't wire them to an illumination trigger, they can be turned off during the day or any other time you want them off.
Craig thank you for sharing your product with us other Jeep heads!
rollindom is offline
post #307 of 801 Old 05-20-2013, 03:19 AM
jeremyc653
2005 WK
Audio by virtually useing the same fuse you mean one of the bridges that connect with the fuse and you run a wire from it to the leds and install an inline fuse? Thus leds will get power when the fuse gets power witch is via acc key turn? Correct? Just trying to make things a little clear so everyone understands
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #308 of 801 Old 05-20-2013, 07:40 AM
Whit
1950 CJ3A
I finally installed mine and everyone loves them. I have it set to rotate through colors slowly... Kids picked that mode.
So now I'm wondering if you've thought about making a rectangular one to fit into that spot just to the right of the shifter? Could it be tied into the other two electrical connections and work ok?
1950 Willys CJ3A, all stock.
2010 WK, 3.7l, Rubicon wheels in Anthracite, K&N intake, Hypertech, 2.25" RRO lift, Bilstein 5100, Stillen brakes, 265/70-17 Hankook DynaPro ATM, Cupholder Ring LED's, Expanded Sheet Grill mod
UPCOMING MODS: Fastman TB, cargo LED's
Whit is offline
post #309 of 801 Old 05-20-2013, 08:18 AM Thread Starter
craigbru
craigbru's Avatar
2007 WK
Attachment 628653
They look great man! Can I put your pic in the customer gallery on the website?
Yes, the LED's would get power when the fuse gets power, but it's better than just ACC. They would actually turn on when the lights do, and only then.
Haha, awesome!
I hadn't thought about that, but it would certainly work. Another 'Y' adapter and a rectangular LED would do it. Would there be much demand for that? I could certainly make it an upgrade option.
Jeep-Core
craigbru is offline
post #310 of 801 Old 05-20-2013, 09:10 AM
rollindom
rollindom's Avatar
2005 WK
Absolutely! Actually I just snapped a quick phone pic to show the end result because you know "if you don't have a pic, it didn't happen". I will get a few better pictures to you within the next day or so for you.
post #311 of 801 Old 05-20-2013, 06:55 PM
audiophonicz
2007 WK
... thought about making a rectangular one to fit into that spot just to the right of the shifter? Could it be tied into the other two electrical connections and work ok?
That, my friend, is a brilliant idea. I already have thoughts of JEEP illuminated vertically...
#1 no inline fuse needed, it adds a 2nd fuse itself. See next post.
#2 My way gets power via PARKING LAMPS, not ACC. Ie, no key in the ignition, turn your headlights on, they come on. During daytime driving with headlights off or set to Auto, they are NOT powered on.
post #312 of 801 Old 05-20-2013, 06:55 PM
audiophonicz
2007 WK
On With Parking Lamps Wiring
Instructions for On-With-Parking/Tail Lights:
Pick yourself up a Mini Fuse Tap "Add-A-Circuit" ($10 Advance Auto) and some mini 10 amp blade fuses (5 for $5 Advance Auto).
You only need one fuse, but spares are good to have.
Locate fuses 8 thru 10 in the Power Distribution Center. They're all 10 amp.
#8 = Left Parking/Tail Lamps
#9 = Trailer Hookup Parking/Tail Lamps
#10 = Right Parking/Tail Lamps <-- We tap into this one
Install Add-A-Circuit like so
Testing and hookups:
Green is LED controller to ground
Red is LED controller to #10 Add-A-Circuit fuse
Ignition ON - Headlights OFF - Parking Lamps OFF
Ignition OFF - Headlights OFF - Parking Lamps ON
I ran the power wire from the Add-A-Circuit through the firewall using the lowest, hardest to reach grommet the same way I ran my subwoofer power (pics stolen from my other thread).
Engine Side:
Interior Side: (The grommet pictured is actually higher up than the one you want)
And finally, wire into the controller in place:
post #313 of 801 Old 05-20-2013, 11:55 PM
Whit
1950 CJ3A
I have mine illuminated with ACC on. Here are a few daytime photos.
Whit is offline
post #314 of 801 Old 05-21-2013, 01:38 AM
S1L3NT_WH33L3R
2005 WK
Man these are sooo sweet I cannot wait to get a set for the JK
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #315 of 801 Old 05-21-2013, 04:47 AM
guls
2015 JK Wrangler
It would be nice to have the rectangular one with "Jeep" in the middle that lights up.
Seen some on ebay for Hyundai/ Kia
guls is offline
