WK (and possibly others) LED lighted cupholders - Page 20 - JeepForum.com
post #286 of 805 Old 05-17-2013, 10:13 AM Thread Starter
craigbru
2007 WK
Originally Posted by hxdrummerxc View Post
hmmm, the thing that doesn't make sense to me, is the connector on the led rings. I don't want to drill a hole that big for the connector to fit through, that would surely be noticeable. Im thinking my only other option is to cut the connector off, feet the wires through and then re-splice the connector back on after it is fed through. I don't know
Check this out man.
http://jeep-core.com/200810-wk-grand...-installation/
Jeep-Core
craigbru is offline
post #287 of 805 Old 05-17-2013, 11:11 AM
hxdrummerxc
2008 WK
Originally Posted by craigbru View Post
Sweet. Lol,
Well I did everything pretty much exactly how you had written it anyways. I cut the holes in the cup holders so small that the wires barely fit. But I cut the connectors off and im gonna re-solder them on afterwords. I just wanted a real small slit in the cup holder. Im a little picky. lol
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #288 of 805 Old 05-17-2013, 11:21 AM
holmants
2005 WK
With the wiring setup that comes with our order, is there a way to set up the rings so that they are only on when the lights are on or will they stay on as long as the key is turned on? Thanks!
holmants is offline
post #289 of 805 Old 05-17-2013, 01:59 PM
marka2k
2006 WK
Yes I will tell me what you want (same as post #277 ?) and I will work on it this weekend
Outstanding! I see it Mark. I'll get it out tomorrow. If you are willing to work with me on measurements for your wife's Commander, I'll get some made, haha.
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
2006 Commander Limited - Wife's
marka2k is offline
post #290 of 805 Old 05-17-2013, 02:18 PM Thread Starter
craigbru
2007 WK
Sweet. Lol,
Lol, okay, that works too. When resoldering, please note the black and red wires matched, but the blue and green's were switched. That's just the way the plugs were manufactured, and I had to go blue-green, green-blue to 'correct' it.
You can't do it with what I sent. I know exactly which wires you'd have to tap in to, but while there is enough voltage, there isn't quite enough amperage (just a guess), to run the RGB controller. Before I switched to RBG it was testing fine, after RGB, not so much. So, it's either turn on with the ignition or you would have to use a relay to work with the light's alone. I can let you know which wires to use if you want to attempt it.
Yep, just like #277. With any luck they might match one of the WK versions. I also notice you have a '04 TJ in your sig. Would you be willing to get measurements there too?
Jeep-Core
craigbru is offline
post #291 of 805 Old 05-17-2013, 02:43 PM
marka2k
2006 WK
Yes I will do the 04 Wrangler as well, I also have a 2000 Grand Cherokee if you ever decide to include the WJ rigs as well
Silver WK Club #46
06 WK Overland
04 Rubicon
2000 Grand Cherokee
marka2k is offline
post #292 of 805 Old 05-17-2013, 03:04 PM Thread Starter
craigbru
2007 WK
The TJ would be great. I've got someone working on a 2000 WJ already, or I'd certainly take you up on it.
Jeep-Core
craigbru is offline
post #293 of 805 Old 05-17-2013, 03:34 PM
Bogie
2005 WK
craigbru 05-07 Commanders use the same cup holder 07-10 has no insert and will be different size
05 WK 5.7 Limited Stone White Dead Stock
84 Dodge W350 Crew Cab 9'+ Lift 37" SSR's
66 Dodge Dart 273 4-Speed Radio/Heat Delete
Previous Jeeps - 78 SJ,91 YJ,94 ZJ,98 XJ,06 LJ Rubi
Bogie is online now
post #294 of 805 Old 05-17-2013, 03:48 PM
jbaldry
If anyone is wondering about shipping time, I live in Portland Oregon and it SHIPPED on Monday and got here today (Friday), and it took two days from when I placed my order for it to be shipped.
2000 Jeep Grand Cherokee Limited, Quadradrive, 4.7 V8
Living life mod by mod
jbaldry is offline
post #295 of 805 Old 05-17-2013, 08:19 PM
hxdrummerxc
2008 WK
I somehow noticed that too, right at the last minute before I soldered I looked at the other cord and seen the blue/green mismatch.
I got it all done. I also didn't think that I could live without the controller accessible. So I wired it so that the controller is in that little cubby hole in the dash right below all the temperature settings. If you pull the rubber piece out of that cubby, there are holes big enough to feed the wires through. I did however have to cut the connector side of the controller off and re-solder or splice that back on after i fed the wires through. It was a lot more work, but now my controller is easily accessible and hardly noticeable.
Looks great btw. Pictures coming in a minute
EDIT:
Pictures
Here is a cell phone pic of how I have the controller installed in that cubby
And here are some pictures of it completed
post #296 of 805 Old 05-18-2013, 09:51 AM
S1L3NT_WH33L3R
2005 WK
EDIT:
Pictures
Look ssoooooooo sick
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #297 of 805 Old 05-18-2013, 12:03 PM
tom19511
2014 WK
Dammit, hxdrummerxc.. I never thought of putting it in there. Now I may have to go back and put it there. I left it under the trim pieces.....Ehhh.. Not now though.. I was also thinking of putting it in the cupholder rectangle trough too... Oh well Later maybe...Looks good...
Tom
tom19511 is offline
post #298 of 805 Old 05-18-2013, 10:02 PM
Nitronitty
BTW- I only have the one cupholder in the gear shift console--98 TJ-- I do not have a center console between the seats so I am not sure if the size differs from the other console but I can measure it if you need
We don't own our Jeeps, they own us! LOL
Nitronitty is offline
post #299 of 805 Old 05-19-2013, 07:11 AM
LJS8510
LJS8510's Avatar
2015 WK
That looks great.
Good Luck
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #300 of 805 Old 05-19-2013, 10:03 AM Thread Starter
craigbru
2007 WK
So, they changed console designs when the GC's did. Man, it would be great if they were identical.
EDIT:
Pictures
**Pic snip
Those look fantastic man! Mind if I put your pics in a gallery on the website? What you did with the controller looks pretty good. Maybe I'll add some commentary to the install instructions showing it as an optional way to go.
That would be great if you could. If it's between 69~70mm, then it's the same as the double cupholder console. Meaning I can minimize parts.
Originally Posted by LJS8510 View Post
That looks great.
Good Luck
Thanks man!
Jeep-Core
craigbru is offline
