WK (and possibly others) LED lighted cupholders - Page 13 - JeepForum.com
post #181 of 805 Old 05-02-2013, 09:25 PM Thread Starter
craigbru
2007 WK
Just an update guys. I've got some good news and some bad news. How about the bad first? I took a little time tonight to get some more rings cut, however my CNC wasn't cooperating. More specifically, the special end mill I'm using for the acrylic wasn't playing nice. I ended up with about 8 sets that are pretty rubbish. (I cut a sheet of 16 rings at a time.) I was having issues with the acrylic melting despite the feed speed. Any attempts to raise the speed, and I would get edge chipping. Basically it bounced back and forth between melting and chipping. I'm guessing the end mill is duller than it appears, despite the fact that it's pretty new. So, the only immediate remedy it to switch from the 3-flute 3/16 mill", to a single flute 1/8". The biggest downside to doing that, is simply the milling time. I've got to slow the feed rate down a little more, reduce cut depth, and it won't remove as much material per pass. Oh well, there's not much I can do about it at this point until I buy a suitable replacement. As part of this end mill drama, I've not got as many sets done as I'd hoped. I'd like to get a few more done before I send out PM's to the new site.
So, on to the good news. The website is up and ready to take orders. With the exception of a link to some install instructions, we're ready to go there. I'm hoping to get the link out there to a few of you by the first part of next week. Also, for you cheapskates out there, I'll have some 'B' stock to sell for the 05~07 WK's. Here is why. On a few of the rings that were chipped during milling, I can't sell them as first quality. However, due to the fact that the 05~07 cupholders have those 3 'grips' around the bottom of the hole, those chips are easily hidden underneath them and will never be seen. I figured I'd sell them at a discount. Sorry I probably won't be able to do the same for the 08~10's. There would be nothing to hide the chips, and I think it would look bad when lit up.
Anyway, thanks for your patience will all of this. I'll get these things worked out soon enough!
Jeep-Core
craigbru is offline
post #182 of 805 Old 05-03-2013, 03:10 AM
jeremyc653
2005 WK
Well it is what it is. We are all just glad you are taking care of us. Your the best
Build Thread: http://www.jeepforum.com/forum/f67/jeremyc653-build-thread-1423295/#post14245927
jeremyc653 is offline
post #183 of 805 Old 05-03-2013, 04:41 AM
JeepWKHemi
2006 WK
That's a bummer to hear, but you gotta do what you gotta do. It's completely understandable about wanting to push the release date out a little further. I mean we have been waiting this long, what's a little longer. Just take your time. I can't necessarily speak for everyone else, but I know I am patient and don't mind the wait.
2006 Jeep Grand Cherokee Limited 5.7 Hemi QDII
2015 Jeep Cherokee Trailhawk
JeepWKHemi is offline
post #184 of 805 Old 05-03-2013, 04:45 AM
tom19511
2014 WK
I can be a guinea pig if need be. I can figure out how to install..
Tom
tom19511 is offline
post #185 of 805 Old 05-03-2013, 05:31 AM
jeremyc653
2005 WK
If you want to just unload one of the chipped ones Ill take one if it is easier for you so you dont waste supply's. I Don't mind as long as they function.
post #186 of 805 Old 05-03-2013, 07:14 AM
justinmiller930
2011 WK
I'll take one of the crappy sets for the 05-07! Ha ha.
justinmiller930 is offline
post #187 of 805 Old 05-03-2013, 08:12 AM Thread Starter
craigbru
2007 WK
Thanks for the support guys. It's all a matter of getting the bugs out. I've usually just made one off pieces for myself in the past. Running batches requires a slightly different approach. It's basically a balance between volume and machine time. Anything can be cut cleanly when you're only taking .05" off per pass. However, that puts machine time at close to 5 minutes per ring. So, you then have to figure out how much faster you can ramp up the feed speed without getting chips. Speed helps when milling acrylic as it means less time spent with the mill on the acrylic surface, and you're less likely to have melting. It's all back to that balance.
So yes, the 'B' stock rings would be functionally perfect. Any cosmetic flaw would be completely hidden once installed.
Jeep-Core
craigbru is offline
post #188 of 805 Old 05-03-2013, 11:15 AM
AA-Train
2006 WK
Maybe I'm missing something (if so, sorry), but where is this website again?
o| | | | | | |o
'06 WK Limited
Dark Khaki
Quadra-Drive II
Muffler Delete; Homemade Intake (w/ Spectre P4 & 4" Tubing)
AA-Train is offline
post #189 of 805 Old 05-03-2013, 11:17 AM
jeremyc653
2005 WK
It will be release when he gets more sets done and ready to ship
post #190 of 805 Old 05-03-2013, 12:03 PM
AA-Train
2006 WK
Got it. Thanks.
o| | | | | | |o
'06 WK Limited
Dark Khaki
Quadra-Drive II
AA-Train is offline
post #191 of 805 Old 05-03-2013, 12:04 PM
RagtagGuy
2005 WK
Hell I'll take some 'C' rated rings haha
Its not like you will see them much anyway
RagtagGuy is offline
post #192 of 805 Old 05-03-2013, 12:16 PM
JeepWKHemi
2006 WK
True
post #193 of 805 Old 05-03-2013, 12:45 PM
jeremyc653
2005 WK
Yep is take some also
post #194 of 805 Old 05-03-2013, 10:35 PM
S1L3NT_WH33L3R
2005 WK
How about the ones for a JK?
'05 WK Limited, QD-II, 5.7L HEMI, Volant Cold Air Intake, Aries Taillight Guards, Rola Roof Rack, Cobra CB, Firestik Antennas, Magnaflow Performance Exhaust, OME HD lift, 285/70-17 GY Duratracs, Spidertrax Spacers, Superchips Programmer, Steel Armadillo Super Sliders
~Jeep makes it HEMI shakes it~Ain't Nothing Humble about that HEMI Rumble~
S1L3NT_WH33L3R is offline
post #195 of 805 Old 05-03-2013, 10:37 PM
Bogie
2005 WK
Are they all multicolor now or can they be had as single color only ? Also interested in a damaged set if still any left.
05 WK 5.7 Limited Stone White Dead Stock
84 Dodge W350 Crew Cab 9'+ Lift 37" SSR's
66 Dodge Dart 273 4-Speed Radio/Heat Delete
Previous Jeeps - 78 SJ,91 YJ,94 ZJ,98 XJ,06 LJ Rubi
Bogie is offline
