WK (and possibly others) LED lighted cupholders - JeepForum.com
post #1 of 801 Old 02-25-2013, 06:17 PM Thread Starter
craigbru
2007 WK
**** And we are live! http://jeep-core.com/
Okay guys, as promised, here are a few pics of how I made and installed my lighted LED cupholder rings. Had I known the response would have been so positive I would have documented things a little better. I think you'll get the gist of things though.
I'll start by saying that this isn't exactly easy to replicate unless you have access to a CNC. I build small form factor computers as a hobby, and I make frequent use of the CNC for those projects. I've only now started playing with it on other projects. It's small, but more than adequate for the work I typically do.
I took a few measurements and came up with a simple design in CAD. I converted the design for milling and pulled out some 5mm acrylic I had left over from a previous project.
I clamped it to the CNC and let her rip.
A few minutes later I was left with a small disk with a recessed pocket.
With the backing peeled...
I used Little Dot SMD LED Accent Lights. They are pretty cheap, and already have the resisters built in, along with substantially long lead wires. They fit perfectly in the smaller pocket I milled in the disk. In this pic you can also see I lightly sanded the surface of the acrylic disk. I did this to help diffuse the lighting a bit.
Although I didn't get a picture of the disk insert being made, it's simply a piece of 1mm PVC sheet. The tolerances are very tight, but the insert just presses in place. Once there, it's not ever going to fall out on it's own. In fact, I had tap on it a bit with a rubber mallet to get it seated.
A test lighting... and success!
I basically repeated the same process above for the second cupholder with a slightly larger ring, since they aren't the same size.
Now, in order to get them seated in the cup holder, I had to do a little trimming of the rubber. Using a very sharp x-acto knife, I just made the bottom openings a little taller. I really only needed to take a few mm out.
Lastly was the wiring. I tapped into the 12v switched auxiliary plug (left) on center console stack.)
As far as wire routing went, I just ran a wire to the left and right of where the rubber on the front of the cupholder 'snaps' into place. I didn't have any at the time, but I'll likely go back in and add a simple plug to disconnect the wiring should servicing of some kind be needed.
Overall I'm pretty happy with them, although I'm going to try and tone down the boldness of the green to match my instruments. I've ordered some white LED's and some colored filters to attempt this. I also ordered a simple PWM dimmer to play with. Either might get me the results I was looking for.
Now, some of you have expressed interest in me having a few of these fabbed up. I'd be happy to do that. I'd need to get some more materials and LED's. Just let me know!
**** Update! Check this post for the first color samples with a white LED and gel filter.
**** Update 2! Check this post for the second color samples with colored LED's.
**** Update 3! Check this thread for an informal poll on colors.
**** Update 4! Check this thread for information regarding the switch to RBG LED's with a controller.
**** Update 5! And we are live! http://jeep-core.com/
Jeep-Core
craigbru is offline
post #2 of 801 Old 02-25-2013, 07:20 PM
hxdrummerxc
2008 WK
That's awesome,
They look great.
I would be interested in seeing how much you would make and sell them for. Ill keep watch on this thread.
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline
post #3 of 801 Old 02-25-2013, 07:27 PM
sixfoot9psu
2005 WK
Sweet man! Like omelet, I also would like blue ones to match my blue engine components! Do you have an estimated price?
'05 GC 5.7L Hemi QDII...Rock Krawler lift, 4XGuard Matrix, rock sliders, front and rear skids, belly guard, rear diff guard, Bilstein HDs, Volant intake, 265/70 Goodyear DuraTracs, Superchips, Rola roof rack, BORA wheel spacers, Rocky Road Leveling Spacers, Magnaflow muffler, KC Slimlights, BT catch can, tb cover, and underhood kit, Expanded Sheet Metal Grille
'09 G8 GT 6.0L...Kooks Headers, Rotofab intake, SLP exhaust, Vector Motorsports Tune
sixfoot9psu is offline
post #4 of 801 Old 02-25-2013, 08:14 PM
Jeepforthewin
2010 JK Wrangler
I would Definitely buy these if you started making them!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 801 Old 02-25-2013, 08:26 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Very Nice! As I said before, if you made a set in blue I will buy them
Omelet is offline
post #6 of 801 Old 02-25-2013, 08:34 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
BTW the stock dash lights are more of an aqua than a blue or green. I know they make LEDs in the color you would need to match.
Omelet is offline
post #7 of 801 Old 02-25-2013, 09:24 PM Thread Starter
craigbru
2007 WK
You are right, they are a bit more aqua than anything.
We'll see how my color tests go before I commit to anything, but doing some quick math, I figure I could do $25 shipped anywhere in the US. I have no idea if that is reasonable or not, but that allows for materials and any of my labor/time. Thoughts?
Jeep-Core
craigbru is offline
post #8 of 801 Old 02-25-2013, 09:31 PM
sixfoot9psu
2005 WK
Great price!
post #9 of 801 Old 02-25-2013, 09:44 PM
clbailey
2005 WK
Fair price. color options would be awesome, but probably more time intensive.
clbailey is offline
post #10 of 801 Old 02-25-2013, 10:09 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Sounds like a good price to me! I'll pay it for sure!
Omelet is offline
post #11 of 801 Old 02-25-2013, 10:33 PM
punisher65
punisher65's Avatar
2006 WK
Those look awesome! Also I see you did what I have been thinking of doing for a few weeks now...carbon fiber wrap over all the wood trim stuff. I assume it wasn't too hard? Anyway, good work!
2006 5.7 WK
OME HD, 265/70-17 Duratracs on Level 8 Strike 5, Aspen Creek Shackle Mounts,
Airaid CAI, Superchips Flashpaq, Gibson 3" catback, Steel Armadillo Engine Skid Plate
BT Catch Can, TB ground, Cree LED Reverse Lights, Interior LED upgrade
1993 4.0 ZJ
BB and 31" Bighorns SOLD :(
punisher65 is offline
post #12 of 801 Old 02-25-2013, 10:50 PM
inhidin
2014 WK
I'd go for a set as well, would prefer a white color to match my led interior bulbs.
inhidin is offline
post #13 of 801 Old 02-25-2013, 11:35 PM
moonvan
2008 WK
sounds like a good price point to me.
moonvan is offline
post #14 of 801 Old 02-26-2013, 12:05 AM
GregB_00XJ
I to would be interested in a set to match the interior lights (aqua as mentioned).
$25 bucks sounds fair to me!
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #15 of 801 Old 02-26-2013, 01:57 AM
chachi44089
Very cool mod!!! What colors can you do them in??
chachi44089 is offline
