WK Paint problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > WK Paint problem
FS: Wranger BRIGHT License Plate LED! Just $3! Great value6th annual beat your wife to the credit cards sale!!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 08-25-2015, 04:57 PM   #1
WK Paint problem
Hi, I have a 2006 WK in which the paint has started etching away down to the base coat. Has anyone had or heard of this problem? I would appreciate any input.
bmaccausland is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 05:12 PM   #2
sheepdog918's Avatar
2007 WK
Strange, but can happen to any vehicle depending on where you live, if it was ever washed of road chemicals, salt etc etc. Just started by probably eating the clear coat off and then after that there's no stopping it unless you get it re sprayed and some new clear coat on
There are the wolves, there are the sheep, but then, there are the Sheepdog's
sheepdog918 is offline   Reply With Quote Quick reply to this message
Unread 08-26-2015, 10:10 AM   #3
2007 WK
Yes, Jeep did have a "checking" problem with certain colors. It looks like a million razor cuts in the clear coat. The thought is that the colored base coat wasn't cured properly which along with UV rays causes the clear coat to check. There is no "fix". The repair is to remove all the paint and start over. I had my '07 walnut shell blasted, re primed, painted then clear coated. BTW, with zero help from Chrysler.
OM642WK is offline   Reply With Quote Quick reply to this message
