WK eyeglass holder broken? Look inside... - JeepForum.com
post #1 of 1 Old 09-29-2013, 10:52 AM Thread Starter
LouC
2007 WK
This is probably a common problem, on the WK sometimes the plastic tab that holds down the driver side rod for the glass holder door breaks and then you can't open it or it does not close. I found a thread on here yesterday about this searched and then couldn't find it. Anyway its an easy fix. You pull down the overhead console and find a piece of plastic to wedge in the opening to hold down the rod. I found that the end piece of zip ties for wiring jobs fits perfect. I cut it to size and then used some plastic epoxy to glue it in place. 10 min job.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
