Quantcast WK - Differential Fluid Change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > WK - Differential Fluid Change
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 10-06-2008, 05:33 PM   #1
BigSensFan
2007 WK
I was informed by the stealership that the Differential Fluids need to be changed every 24,000 km to keep warranty. Talking to another mechanic, he said that seems kinda often (he suggested every 100,000kms)
Regardless, while it is under warranty, I should do it. Anyone done their own, and know how easy it is and what fluid it takes and how much of it.
Mine is the 2007 WK CRD (3.0)
BigSensFan is offline   Reply With Quote
Old 10-06-2008, 05:39 PM   #2
robpp
Schedule B: Axles every 15K miles.
Its all here:
http://www.wkjeeps.com/wk_maintenance.htm#FAXLE
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline   Reply With Quote
Old 10-06-2008, 07:15 PM   #3
Texas WJ
Texas WJ's Avatar
2005 WK
Quadra-Drive?
Texas WJ is offline   Reply With Quote
Old 10-06-2008, 07:22 PM   #4
BigSensFan
2007 WK
Originally Posted by Texas WJ View Post
Quadra-Drive?
QD II
And to the other poster, thanks for the link.
Old 10-06-2008, 07:43 PM   #5
robpp
QD II
No worries.
With QDII dont forget to add the limited slip additive. It shows it over on wkjeeps.
Old 10-06-2008, 08:43 PM   #6
Texas WJ
Texas WJ's Avatar
2005 WK
QD II
Yeah, definitely stick with the schedule and as robpp mentioned above, absolutely make sure the friction modifier is added in the process.
I've had places assure me they have the right stuff for the diffs only to stare blankly when I mention the friction modifier.
Old 10-06-2008, 09:06 PM   #7
basthen
2007 WK
That friction modifier goes only in the rear end right?
basthen is offline   Reply With Quote
Old 10-06-2008, 09:12 PM   #8
robpp
Go back and check the link. It shows for both.
If you have the QDII, you have ELSD in both front and back.
Old 10-06-2008, 10:31 PM   #9
Texas WJ
Texas WJ's Avatar
2005 WK
Agreed front and rear on the QDII
If it's not added, you'll soon notice. You'll start getting some grinding and binding in tight turns.
Old 10-07-2008, 12:19 AM   #10
fegarciaii
Has anyone tried Mobil One Synthetic gear oil without adding additional friction modifier (since it's supposed to be designed in part for limited slip applications)?
fegarciaii is offline   Reply With Quote
Old 10-07-2008, 11:27 AM   #11
Glenzo
2005 WK
I still have some binding/shuddering in my front diff after a fluid change on my 05 with QD11. Would it do any good/harm to add more friction modifier to the front diff?
Glenzo is offline   Reply With Quote
Old 10-07-2008, 02:11 PM   #12
Ridin' Around
Wanna Go Along?
Ridin' Around's Avatar
http://www.amsoil.com/products/gearlubes/WhitePaper.aspx
Here is the ever talked about gear lube white paper, Enjoy!
Ridin' Around is offline   Reply With Quote
Old 10-07-2008, 02:24 PM   #13
Texas WJ
Texas WJ's Avatar
2005 WK
Where did you have it changed?
If it was right after a fluid change that you started having problems I would probably just have it changed again. Either bring the friction modifier from the dealership with you to what ever shop you'll be at, change all the fluid yourself, or have the dealer do it.
Old 10-07-2008, 05:08 PM   #14
Glenzo
2005 WK
It was done at a 5 star dealer. I made sure they used 75-140 Mopar and I saw the 2 little bottles of friction modifier on the bench.
I had shuddering before the fluid change and it was only slightly better after the fluid change. This is why I am thinking adding some more friction modifier might help but I am not sure. Can too much cause damage?
Old 10-07-2008, 06:13 PM   #15
Texas WJ
Texas WJ's Avatar
2005 WK
Sorry, can't help you there. I image too much would render the ELSDs inoperable, so it would be like running open diffs. Dunno though, just a guess on my part.
Glock Forum
