WK - Different sort of heated seat problem - JeepForum.com
post #1 of 3 Old 08-02-2013, 08:35 AM Thread Starter
tjlaven
2005 WK
Hi,
I've had a problem with the driver's heated seat in my 2005 GC and the searches I've done on the problem always seem to describe an open circuit - broken wire type problem - but the problem I have is different:
The heated seat is operational, sometimes. I've tested it out enough times to figure this out: on cold mornings, if I turn the seat on right away, it'll turn on and heat up properly. However if I don't think about it for a while and try to turn the seat on later - it won't come on at all (no indicator LEDs lit, no heat). Also, and this is very wierd - after its been on for a while, it WON'T turn off. It seems to get 'stuck' in the ON position. I've already replaced the switch bank, thinking it was a defective switch - so that's not it.
Could it be a heat-related problem with the heated seat controller, or relay?
The passenger heated seat works fine.
Thanks for your thoughts and advice.
tjlaven is offline
post #2 of 3 Old 08-02-2013, 11:04 AM
BAH101
2008 WK
Sounds like a sticky relay
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #3 of 3 Old 08-28-2013, 07:12 AM Thread Starter
tjlaven
2005 WK
Thanks for your response. I can't find the relay listed in the shop manual I have. Is the relay built into the Heated Seat Module, located under the passenger seat?
tjlaven is offline
