WK CRD: Swirl Motor Question for the experts - JeepForum.com
post #1 of 20 Old 02-27-2010, 10:05 PM Thread Starter
Drewd
Hi,
Can somebody explain the actual mechanism of how oil leaking form the turbo charger/intake area actually damages the swirl motor? Is the damage caused by oil electrically shorting it or some other mechanism?
Here is why I'm asking. I finally replaced the intake assembly with the upgraded one. I've had a nasty oil smell for a while and I can see visible smoke coming from the area when engine is hot. Is there anyway I can get rid of the oil mess without destroying the swirl motor?
I'd like to pressure wash the area after I soak it with some engine degreaser.
Thanks for your help.
Drew
Drewd is offline
post #2 of 20 Old 02-27-2010, 11:47 PM
maxst2
2006 WK
You talking that the oil lubrication on the turbo is leaking into the compressor?
maxst2 is offline
post #3 of 20 Old 02-28-2010, 04:45 AM
merlinTec
merlinTec's Avatar
Hi
It's the oil getting into the motor that does the damage so washing it I would be careful was around it should be fine as it's only the EGR and oil coolers around it and the V of the engine as drain holes.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 20 Old 02-28-2010, 02:55 PM Thread Starter
Drewd
No, blowby gasses from the crank case ventilation system are laden with oil. A provent/racor CCV filter is mandatory equipment to filter them out. Prior to doing this, oil in the intake from blowby gasses would leak out the intake where the intake is mounted to the turbo (poor seal design) and remainder would damage swirl motor post turbo intake assembly.
Drewd is offline
post #5 of 20 Old 02-28-2010, 07:30 PM
LJS8510
LJS8510's Avatar
2015 WK
Turbo intake tube seal info
http://www.crdsite.com/articles/wkintake/tsoilfix.html
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #6 of 20 Old 03-01-2010, 10:53 PM Thread Starter
Drewd
Originally Posted by LJS8510 View Post
That site appears to be inaccurate. Oil leaking from the turbo intake tube seal doesn't destroy the swirl motor. In fact, oil leaking from the seal may prevent the swirl motor from being damaged if you can stand the stench.
Based on merlin's post, its the oil in the intake from ccv blowby gasses that damage the swirl motor.
Drewd is offline
post #7 of 20 Old 03-02-2010, 04:10 AM
LJS8510
LJS8510's Avatar
2015 WK
An informative thread by merlentec.
http://www.jeepforum.com/forum/f67/c...l-leak-863459/
LJS8510 is offline
post #8 of 20 Old 03-02-2010, 05:37 AM
CRD Dawg
2008 WK
I think I understand the Swirl Motor issue now. Is this correct? It's actually the leak at the mouth of the inlet to the turbo that is the root of the problem. It is the accumulation and POOLING of the leaked oil sitting on the OUTSIDE of the top of the engine between the cylinder banks that's the REAL issue. Does it then find it's way to the Swirl Motor as it runs around the outside of the engine? The oil vapor passing thru the CCV, thru the turbo and into the intake and intercooler (although not good either), is NOT the actual cause of the Swirl Motor failure. As long as I keep oil from leaking onto the top of the engine, I should be able to avoid this failure. And this is a design flaw inherent to the WK and other Chrysler applications and less of an issue on the Benzes with this same engine. Is there a picture of the swirl motor? I assume it's certainly not visible from the outside. Thanks for any dumbed-down explanations you can give. A bit of a novice wrench turner here.
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
CRD Dawg is offline
post #9 of 20 Old 03-02-2010, 08:24 AM
suzieque
2008 WK
http://www.jeepforum.com/forum/f67/w...9/#post5240765
I believe the swirl motor is in photo #3 of merlin's post.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #10 of 20 Old 03-02-2010, 03:57 PM
merlinTec
merlinTec's Avatar
The oil leaking onto the motor from the intake pipe is the primary reason for it to fail however oil going into the intake can clog up the flaps as you can see in my pictures.
post #11 of 20 Old 03-04-2010, 06:43 AM
CRD Dawg
2008 WK
SQ & MerlinTec,
Thanks for the help. 2 more novice questions. What is the purpose of the Swirl motor exactly and what are those 6 flaps?
CRD Dawg is offline
post #12 of 20 Old 03-04-2010, 08:33 AM
justa4banger
2007 WK
RACOR or PROVENT FTMFW!!!!!!!!!
i got mine...do you?!
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #13 of 20 Old 03-04-2010, 09:55 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I got mine and the new tube/seal.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #14 of 20 Old 03-04-2010, 05:09 PM
fishinbama
2007 WK
merlin can tell you better but the swirl motor aids efficient combustion. The flaps are part of it.
fishinbama is offline
post #15 of 20 Old 03-05-2010, 01:22 PM
merlinTec
merlinTec's Avatar
Each cylinder incorporates one swirl port and one charge port. The swirl ports can be closed by the swirl flaps (seen in my pics) In the lower engine speed and load range, the swirl flaps are closed by the swirl valve actuator. The entire air mass flows through the charge ports only, which results in greater swirling (hence the name). The increased swirling produces uniform combustion for better engine performance and reduction of particulates. As rotational speed and load increases, the swirl valves open, so that optimal swirling and the required air mass are provided for the current operating conditions.
Swirl motor and turbo inlet mod ... where to fit Racor or Provent ianrmz250 WK Grand Cherokee & XK Commander Forum 26 08-02-2010 03:45 PM
System set-up question for you audio experts CaseyC ZJ Grand Cherokee Forum 2 10-10-2008 02:01 PM
Any Jeep motor experts here ? Todd97GC ZJ Grand Cherokee Forum 14 06-30-2007 12:38 AM
CJ guy question for the WJ experts barry1me ZJ Grand Cherokee Forum 24 07-27-2006 08:39 PM
Question for the experts MY95JGC ZJ Grand Cherokee Forum 6 03-27-2005 02:59 PM
