WK CRD oil leaking near end of intake pipe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > WK CRD oil leaking near end of intake pipe
UCF Memorial Day Savings... Save 15% today!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Axles at CCOR
Unread 05-04-2015, 03:50 PM   #1
plunix
2008 WK
It looks like my CRD has the pipe with the orange seal and leaking.
Do I need to do anything else while replacing with the revised intake pipe, or just swap it out?
2008 Jeep Grand Cherokee CRD
GDE Hot Tune
Turbo Resonator Delete
plunix is offline   Reply With Quote Quick reply to this message
Unread 05-04-2015, 04:01 PM   #2
mushkasdad
2008 WK
Orange seal = junk. new black seal = good.
Coming from mist in crankcase= good.
mushkasdad is offline   Reply With Quote Quick reply to this message
Unread 05-04-2015, 07:11 PM   #3
BAH101
2008 WK
And a GDE tune...just because ya gotta have it
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 12:25 AM   #4
Morphine
I made this one ...
Morphine is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 05:52 AM   #5
08CanuckCRD
2008 WK
Plunix - the short answer is No, you don't NEED to do anything other than replace the orange seal intake pipe with the new black seal version. I'd suggest cleaning up the oil that's blown past the old orange seal (that's the stuff that can pooch your swirl motor), but that's about it. Some guys do the Elephant Hose mod or a Catch Can to remove/reduce the amount of CCV oil entering the turbo intake; others leave it alone on the theory that Mercedes made the engine with the CCV blowby in mind. Getting into that discussion is a lot like arguing Ford vs Chevy, and there's LOTS of discussion on the forum if you want to read through the various arguments.
A lot of CRD owners also use & recommend the Green Diesel Engineering (GDE) Eco and Hot tunes, as they shut off the EGR valve and swirl motor among other things, thus eliminating the CCV oil blowby into the turbo and the risk of swirl motor failure at source. They also have the nice added benefits of added power (Hp and torque) and better fuel economy. Not cheap, though, which is why some guys go with catch cans, EHM, etc.
The extent of mods you choose to undertake thus becomes a personal choice based on your budget, willingness to turn a wrench and the individual engine characteristics of your CRD (some suffer more CCV blowby than others, etc). Climate can also factor in, as there are reports of owners in northern climates with cold winters having trouble with condensation freezing in their Elephant Hoses.
Of course, if your vehicle is still under any factory warranty, I wouldn't be getting too mod-happy, as Chrysler is still on the hook for at least a portion of any repairs. Not many of us left in that particular boat though.
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 03:09 PM   #6
plunix
2008 WK
Canuck, I didnt think the GDE tune did anything in regards to the CCV functionality, just the EGR. Am I wrong?
I do have the GDE Hot Tune as of a few days ago. Just catching up on all the mods I :need: to do in addition to it.
GDE Hot Tune
Unread 05-05-2015, 03:10 PM   #7
plunix
2008 WK
This looks difficult to make without the proper tools. Do you have a DIY write up of how you did this? Thanks.
Originally Posted by Morphine View Post
I made this one ...
GDE Hot Tune
Unread 05-05-2015, 05:57 PM   #8
08CanuckCRD
2008 WK
Sorry - you are correct. The GDE tune shuts off the EGR function, which stops the mist of oil blowby from entering the turbo intake. This is the oil that leaks around the orange seal, drips down and eventually pooches the swirl motor on these engines.
Unread 05-11-2015, 07:20 AM   #9
davids0865
2005 WK
I'm really interested too, did you cut down an existing silicon hose application?
davids0865 is offline   Reply With Quote Quick reply to this message
Unread 05-11-2015, 07:26 AM   #10
plunix
2008 WK
It looks like he might've used the existing pipe and simply added his own rubber pipe where the seal exists. I'm going to buy the revised part instead. My dad has a shop that can get what sounds like 33% cheaper factory parts. I'll pay around 100 vs the 150 asking price (Canadian funds).
GDE Hot Tune
Unread 05-12-2015, 10:26 AM   #11
davids0865
2005 WK
I'm sure you're right and as I have been asked for £170 for the new part, a silicone hose mod would be really useful as the basic pipe is fine with just the seal leaking and if that's a standard hose that has been modded it could be a lot cheaper and even looks good!
Unread 05-12-2015, 07:07 PM   #12
TangoTango
2008 WK
That looks like the orange seal and plastic hose was cut off with a saw; and then that Lowe's type hose clamped on with some marine hose clamps (NCX 68 75 ?). That is a similar hose to what omlette used on his modified safari snorkle.
That hose is not round, it more oval so I'd be surprised if it didn't leak as the marine hose clamp is round.
One is better off just using the black replacement part.
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is online now   Reply With Quote Quick reply to this message
Unread 05-12-2015, 07:36 PM   #13
plunix
2008 WK
I actually disconnected my air cleaner tube and cleaned up my orange seal today and tightened it more. It seems to be in good shape, if not slightly heat warped. Ill keep an eye on it for now.
GDE Hot Tune
