WK CRD Exhaust Upgrade - Page 5 - JeepForum.com
post #61 of 78 Old 02-01-2009, 11:37 PM
cb2630
test
...[YT]http://www.youtube.com/watch?v=xtp4-8k1NtE&feature=related[/YT]
cb2630 is offline
post #62 of 78 Old 02-01-2009, 11:41 PM
cb2630
[YT]xtp4-8k1NtE&feature[/YT]
cb2630 is offline
post #63 of 78 Old 02-13-2009, 02:38 PM
basthen
2007 WK
I removed the resonator today. Barely no difference from a noise perspective. I only drove 15min in the city after that and EVIC gained 4mpg. I could be the cold weather and just me driving like an old men. I'll report later on the mileage.
basthen is offline
post #64 of 78 Old 03-03-2009, 09:36 AM
DREWSCRD
2007 WK
any updates on performance and mpg gains from removing the resonator
DREWSCRD is offline
post #65 of 78 Old 03-05-2009, 06:16 PM
basthen
2007 WK
Oups sorry. I gained .5L / 100km which should be around 2 mpg on highway driving (70-80mph). Sometimes it's closer of 4 mpg but to not disappoint anybody I'll say 2 mpg. I like it. Cheap mod.
basthen is offline
post #66 of 78 Old 03-07-2009, 09:41 AM
Swayse
I really don't understand how it can make such a big difference in mpg, it's not even really a muffler, it's a strait through resonator. Now I want mine gone.
04 Jeep Rubicon
Swayse is offline
post #67 of 78 Old 03-07-2009, 05:07 PM
basthen
2007 WK
I thought I threw 50$ away when I looked thru the muffler on the ground. (Straight thru no restriction in the ID..) It made a difference though.
basthen is offline
post #68 of 78 Old 03-15-2009, 06:30 PM
suzieque
2008 WK
in theory, a resonator simply reduces/eliminates sounds caused by resonation.
you folks should listen for noise at different speeds/rpms after removing the resonator.
It would be nice to see two tips out the back, one on each side, like a true dual exhaust setup.
suzieque is offline
post #69 of 78 Old 03-15-2009, 06:44 PM
basthen
2007 WK
it rumbles a little bit more (enough for the girlfriend to notice it) but nothing major. It's barely noticeable.
basthen is offline
post #70 of 78 Old 03-15-2009, 08:29 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
I routed CCV hose under the car straight to the rear end area and plugged side inlet on the intake sleeve today. I can feel the difference in power, breezing fresh air definitely helps too. I was even thinking of "Y" connecting it into exhaust line, close to the dredded resonator, but seems like too much work.
06 Touareg V10 TDi
Mish_Mish is offline
post #71 of 78 Old 03-15-2009, 09:18 PM
basthen
2007 WK
what have you used to plug the T to the intake manifold? Have you let the line heater connected?
basthen is offline
post #72 of 78 Old 03-16-2009, 06:54 AM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Line heater is still there, I used wine cork on the other side of the CCV inlet hose that got to the inline heater. You can use your imagination, anything solid will work.
06 Touareg V10 TDi
post #73 of 78 Old 03-16-2009, 02:54 PM
Jake03KJ
2007 WK
I bought high temperature silicone cap to use.
14 WK2 Summit EcoDiesel/ Nokian WRG3 tires
Lost to the Ex. 07 WK Overland CRD Black/4xGuard Belly Skid & Rear Skid/Amsoil/Custom Winter Front/InMotion Stg II/MBRP Exhaust
Jake03KJ is offline
post #74 of 78 Old 03-16-2009, 05:19 PM
basthen
2007 WK
Not to open a can of worms but what if the crankcase was meant to be on a vaccum (coming from the intake) and now it's forced to flow and push by itself?
basthen is offline
post #75 of 78 Old 03-16-2009, 05:46 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Nope, it is not supposed to. Older versions had crank gas simply vent under the engine, same still goes for large semi trucks and other heavy machinery.
06 Touareg V10 TDi
The ZJ needs exhaust upgrade sevierville01 ZJ Grand Cherokee Forum 1 10-16-2008 09:28 PM
Exhaust Upgrade trotter8 WK Grand Cherokee & XK Commander Forum 17 01-24-2008 12:51 PM
exhaust upgrade mikeridesbikes ZJ Grand Cherokee Forum 2 05-29-2006 07:49 PM
5.9 exhaust upgrade kemicalburns ZJ Grand Cherokee Forum 7 09-24-2005 01:42 PM
Exhaust Upgrade for I6? 4cherokee ZJ Grand Cherokee Forum 2 12-18-2003 03:55 PM
