WK auxilary transmission cooler? - JeepForum.com
post #1 of 5 Old 05-01-2007, 02:23 AM Thread Starter
tednelson83
has anyone added an auxilary transmission cooler to their WK? while off roading i have on two occasions had to call it quits when the EVIC displays "transmission over temp". i really want to avoid this. i also want to add a trans temp guage, dont yet know where it will go, but i want to add one so i can keep an eye on it. any one else done any of this?
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #2 of 5 Old 05-01-2007, 10:41 AM
nierace
nierace's Avatar
2003 WJ
Are you wheeling in 4lo? Try locking it in gear as well so it doesnt shift, shouldn't really over heat while offroading
What kind of offroading are you doing? Dune jumping ?
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 5 Old 05-01-2007, 12:10 PM
jeep_on
LOL whats what I was thinking. Any way, this is what went on my WJ. Maxi-CoolTMSix Pass and its pretty simple to install. I was towing with the WJ at the time, so is may be overkill... I don't know if you can add a trans temp to the WK. You mite have to crawl under it and look for a port in the tranny to install the sending unit.
2006 Dodge RAM Laramie w/ 5.9L I6
2010 Volkswagen Jetta w/ TDI 2.0L I4
Waiting on a 2013 RHD JK Unlimited
Originally Posted by PM Thor View Post
Wait, you can't cross creeks up there? What the Hell is up with these Canadians?
jeep_on is offline
post #4 of 5 Old 05-02-2007, 11:10 PM Thread Starter
tednelson83
god i wish i could! my GC unfortunately has no Lo. i screwed up when i bought it, and i have found that it would be impractical to change to the nv245. when i wheel i do run it in first gear. i really wish i had better gearing, i find that i need to take some obstacles a bit faster than i would normally want to. the last time i had the tranny overheat i was attempting to pull a rocky, steep 4wd hill. i have done it before, but this time i had my buddy with me. not sure if that had anything to do with it.
i have however decided that i BADLY need to add an auxiliary trans cooler possibly with a blower fan on it. front of the radiator is the best place i can think of for it. i would route the fluid from the tranny into the aux cooler, than into the factory radiator, than back to the tranny.
anyone else done this? and any suggestions, ideas?
post #5 of 5 Old 05-08-2007, 09:12 AM
jeep_on
Hey,
I was looking around for goodies for my truck and ran across this: Vulcan Transmission Temp Gauge Adapter. This will allow you to install the temp gauge you want. Also, I wouldn't route the fluid back to the radiator cooler. Its obviously not doing the job now and may just heat the fluid back up again to 195F. I'd just get the biggest cooler you can find and install that as is. That should take care of the over heating problem.
Just thought you'd be able to use that adapter. Finding a sender and a gauge won't for that adapter won't be hard.
jeep_on is offline
Transmission Cooler bmwguy27 ZJ Grand Cherokee Forum 23 02-23-2010 08:20 PM
Transmission cooler fisher1630 ZJ Grand Cherokee Forum 13 02-25-2008 05:29 PM
Transmission Cooler bill9000 ZJ Grand Cherokee Forum 1 07-17-2006 11:05 PM
Transmission cooler or not? JeremyBelnap ZJ Grand Cherokee Forum 7 08-03-2005 09:20 AM
Transmission Cooler tidesright ZJ Grand Cherokee Forum 4 07-19-2003 04:53 PM
