WK aux tranny cooler - JeepForum.com
post #1 of 6 Old 06-21-2009, 12:01 PM Thread Starter
conrasm
conrasm's Avatar
I'm planning on using my wife's 06 GC to pull out ~3500 lb boat once in a while, as in a couple times a year, longest trip being 120 miles one way. I've already installed the factory hitch and wiring, but was wondering if the tranny cooler that's already on it is enough. It has one loop of tube/fin across the front of the rad (which I'm assuming is for the tranny since it seems a little big for PS) and if needed I can tap into this and add another cooler.
Does the towing package come with bigger cooler? We'll have a long climb for the one trip, probably going from 900ft to 2000 ft above sea level on the turnpike and I don't want to fry her tranny.
She'll be following me in my truck pulling the 30 ft travel trailer, so I'll be keeping the speed to around 55-60.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #2 of 6 Old 06-21-2009, 01:23 PM
sanitarium16
2007 WK
I have the towing package on my 07 JGC and it has a tranny cooler in front of the radiator. It also says it has an oil cooler and PS cooler. Probably the same things you have. It is sufficient enough. I would make sure your coolant is up to the task. When is the last time you changed it?
2014 Jeep Grand Cherokee Altitude
sanitarium16 is offline
post #3 of 6 Old 06-21-2009, 02:14 PM Thread Starter
conrasm
conrasm's Avatar
I doubt it's ever been changed. Are you referring to radiator fluid or tranny fluid? Either way, they are original.
I'll have to climb under and trace the lines. I don't recall seeing an oil cooler, but if it's small I might have missed it when I was under changing the oil.
If anything, I was going to run another cooler in line with the factory one that's already there. I'd rather spend $40 rather than $$$$ for a tranny.
Shawn
conrasm is offline
post #4 of 6 Old 06-21-2009, 06:32 PM
colinzj
2006 WK
You should be good on an 05 or 06, assuming the engine's rated for it. It's not until the 07s where Jeep decided to save some money (and adding an upgraded fan is required for the full 6500 on the 4.7s).
Nothing wrong with adding an auxiliary cooler if you want, though. Better to spend the money than burn things up.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #5 of 6 Old 06-21-2009, 08:58 PM
nostaw22
Does your tranny have a dipstick?
If you look and find a plastic cap over your tranny "dipstick tube" then your tranny isn't serviceable... Which is to say the dealer has to change / measure / alter the fluid level (according to the factory). You can buy a dipstick from the chryler's suppliers online and you'll have to find a TSB on how to fill the fluid level and get some kind of reader to get the tranny temp from the computer.
Is a PITA...
If you have an aux cooler already I wouldn't worry about adding another one.
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #6 of 6 Old 06-21-2009, 11:24 PM
sanitarium16
2007 WK
I would change to coolant and transmission fluid if they are both origional.
Oil or Tranny cooler? Casper4x4 ZJ Grand Cherokee Forum 2 06-02-2009 01:26 AM
tranny cooler crazydude2500 ZJ Grand Cherokee Forum 4 02-15-2009 06:17 PM
Do I NEED my aux tranny cooler if I never tow? mailforjon ZJ Grand Cherokee Forum 33 02-26-2008 02:25 PM
96' ZJ Tranny cooler Soreloser ZJ Grand Cherokee Forum 0 02-20-2008 12:02 PM
Tranny cooler??? WCoon ZJ Grand Cherokee Forum 6 05-22-2006 09:16 PM
