WK advice please - JeepForum.com
post #1 of 6 Old 08-22-2014, 01:51 PM Thread Starter
Quinny
2006 WK
WK advice please
Hi fellow members... New WK owner here with a couple of questions... But first a few pics of the jeep..
It's an 06 WK Hemi.limited.. And so far I've fitted some wheel spacers, and black wrapped the window trim... I've got a spare set of wheels with AT tyres ready and waiting, but wheels need a refurb before I fit them
Anyway... To my problem... When I open the drivers or passenger door, I'm not getting the "door open" message..
I get it with rear door, hood, tailgate, rear hatch etc.. But neither front doors.
Also, if I use the key to lock the door, it only locks the drivers door, it doesn't activate the locks on any of the other doors.
In addition to this, the lock switch on the inside of the door, (the one by the window switch) does nothing.... But it does work when the ignition is on..
The other thing that seems to be missing from my menu, is "lock all doors" you know the feature that locks all doors when you hit 15mph, just isn't in the menu
It's like the control module, isn't sensing the front doors at all..... Any ideas guys??
Oh, and the radio is a PITA.... No matter what I've tried, it goes to MW when I switch off and then back on again...
This all seems to have happened, after I replaced the battery yesterday.
Quinny is offline
post #2 of 6 Old 08-22-2014, 07:42 PM
Chirpz
Chirpz's Avatar
2007 WK
Hmmm... I tried mine. Key only locks and unlocks the one door.
Door lock switch should work even when the key is OUT. It may not work if the key is IN.
In my menu I have one Item "Auto Door Locks".... I keep it off. According to my manual, if I turn it on, I should get another option for the for the 15mph....at least that seem to be what it means.
Then I have the "feature" or "quirk" as you wish. If I lock with the key fob, or the door button and wait for the alarm to activate, then open the door with the KEY instead of the FOB, all seems fine but as soon as the door swings open, the alarm sounds.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #3 of 6 Old 08-22-2014, 07:52 PM
Tango.
2008 WK
Key on -- and there are menu options for this. Look at personal options.
Tango. is offline
post #4 of 6 Old 08-23-2014, 01:55 AM Thread Starter
Quinny
2006 WK
Thanks... I'll be checking this out later..... I also discovered I have no interior lighting on unlocking or opening any doors. But the interior lights work if I switch them on with the stalk (ignition on as well)
Quinny is offline
post #5 of 6 Old 08-23-2014, 11:42 AM
mkmk
2006 WK
(oops -- mistaken post)
mkmk is offline
post #6 of 6 Old 08-23-2014, 12:20 PM Thread Starter
Quinny
2006 WK
Just thought it'd put this one to bed...
Blown 10a fuse under the steering column..... Not sure what number, but I was going through them 1 at a time...and there it was... So all courtesy lights now working, lock push button on door working, and radio now staying on chosen station after switch off and back on...
Still no auto lock of doors at 15 mph feature.... Maybe it's not enabled on my car
Quinny is offline
