Wk abs and traction control light on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Wk abs and traction control light on
USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4TJ 5.25" Speaker Adapters - NalinMFGStainless Steel Door Hinge Pins
Unread 07-19-2014, 07:02 AM   #1
JustJeep247
Junior Member
JustJeep247's Avatar
2010 WK
Kay so I've had a problem for several months where when accelerating the delights will flash and my acceleration goes in and out. Then when turning off the jeep the key gets stuck in the ignition.( I have the key that looks like a block) I eventually figured out that disconnecting the battery for 10 minutes then reconnecting fixes this for a few days. Is it safe for me to be driving with these two lights on? I'm on the road already and have about 6 hours to go. Any advice would be appreciated
JustJeep247 is offline   Reply With Quote
