WK 5.7 Hemi Crank position Sensor Failure - JeepForum.com
post #1 of 15 Old 07-28-2009, 05:34 PM Thread Starter
bmill
I just thought I would share my experience for others to learn from.
Yesterday, I drove the jeep 35mins home from work. Then 30 mins later, I jumped back in for a couple of errands and that's when trouble started. The jeep under throttle was bucking heavily and stalling out after ~3 seconds of bucking and then threw a CEL. I decided to park it and grab some tools and an OBDII scanner. Tried turning it off and back on a few times with no change. Pulled a P0330 Random cylinder misfire code from the computer. Decided to unplug the battery and reset everything and try again...After 15 mins, hooked everything back up and went to fire the beast up....nothing but cranking for 15 seconds. The jeep then threw another code and went into limp mode...Next try the jeep fired up. The new code was a P0335 Crank Position Sensor Circuit malfunction code. The jeep ran smooth just didn't have any power so I ended up limping it back to a dealer here in Indy.
The dealer then confirmed both codes stored in memory and recommended changing the cam sensor along with the crank position sensor "because they share the same reference signal". I ended up just having the crank position sensor replaced and every seems to be running fine. I'll report back in a week or so to see if it's still gone. Total cost from the dealer was $205. Would have done it myself, but I'm just too busy lately and need my Jeep working.
I have had some random long cranking starts but besides that have had no problems. Yet to see if the two were related.
'98 ZJ 5.9L Limited w/ 134k |Spectre Carb Intake| Poly Swaybar & End Links| Tune up in progress...|
bmill is offline
post #2 of 15 Old 09-16-2009, 04:57 PM
icecreamman
2005 WK
Does anybody know where is the sensor located? I can't find any diagrams or references to its loacation in the factory service manual. I'm having the exact same problem and bought the sensor.
If you can explain the easiest method to change on a QDII HEMI that would be even more helpful.
Thanks in advance
icecreamman is offline
post #3 of 15 Old 09-07-2011, 07:04 PM
fajita123
2005 WK
Sorry to bring this back from the dead, but I'm having the same issue. Can anyone provide some guidance on both the crank and camshaft sensor locations? How difficult would they be to replace at home?
Thanks!
fajita123 is offline
post #4 of 15 Old 09-07-2011, 07:08 PM
tjkj2002
2002 KJ Liberty
Thanks!
Crank sensor is located on the passenger side of the block towards the back of the engine.The cam sensor is located underneath the AC compressor,just right of the EGR valve(as your looking at the front of the engine).Just a hint,you want a totally cold engine for changing the cam sensor as the back of your hand tends to rest on the EGR valve when changing it out.
tjkj2002 is offline
post #5 of 15 Old 09-07-2011, 07:09 PM
I8AHUMR
The crankshaft position sensor is on the passenger side underneath. Near the mid to rear on the bottom of the motor.
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #6 of 15 Old 09-07-2011, 07:40 PM
fajita123
2005 WK
Thanks so much guys!
post #7 of 15 Old 09-07-2011, 07:51 PM
thisisrediculus
2005 WK
i changed the crankshaft sensor myself and its fairly easy. i removed the engine skid plate for easy access, unplug it, and theres only one bolt holdin it in. i picked the sensor up at the dealer for like 45 bucks. i think i got robbed cause ive heard of someone gettin it for like 20 bucks but i saved by changin it myself so no big deal.... theres another sensor a little higher and closer to the center of the block i was thinkin that was the camshaft sensor but maybe im wrong
05 wk 5.7L_quadra-drive II_HD ome lift_superchips tuner_CAI_cat back exhaust_spidertrac 1.5" spacers with stock wheels_255/75 bfg mud terrain
thisisrediculus is offline
post #8 of 15 Old 09-07-2011, 08:15 PM
tjkj2002
2002 KJ Liberty
That other sensor was the knock sensor.From 15 years worth of experiance Chryslers only really like OEM sensors,yeah they cost a little more but it's worth it in the long run.
tjkj2002 is offline
post #9 of 15 Old 09-12-2011, 06:33 PM
fajita123
2005 WK
Just thought I'd share - for me it turned out the PCM needed to be flashed with a cam-related TSB. Stealership took care of this (for a fee) and all good now.
post #10 of 15 Old 10-12-2011, 09:25 PM
ddk1
2005 WK
Hi all,
I just had this happen to me tonight. On the way home from dinner, the jeep started to buck, and the check engine light began to flash. So I pulled over and plugged in my superchips and sure enough, crank shaft position sensor threw a code, causing cylinder misfires.
The jeep had been programmed with the economy 87 tune, so I re-flashed it to stock tune and cleared the DTC's. Sure enough, she fired right up and I drove the rest of the way home with no issue, no bucking, etc.
Am I out of the clear? Should I change the sensor anyways? The Jeep has 72,XXX miles on it, is it about the time this sensor typically fails?
ddk1 is offline
post #11 of 15 Old 10-13-2011, 10:37 AM
fajita123
2005 WK
I was able to clear mine as well. After clearing the code, most times it would drive fine but the odd trip it would "buck" or "surge" (almost felt like it was missing for a second) at random times. I changed out the part ($45 at the dealership) and it hasn't happened since. It probably wouldn't hurt for you to wait and see what happens, but it's an easy fix if the problem persists.
post #12 of 15 Old 10-13-2011, 06:51 PM
SampsonSimpson
2006 WK
I had this same problem about 3 weeks ago. I had 2 codes that pointed to the crankshaft sensor. I just bought one from Autozone for like 16 bucks. And its really easy to change, one bolt and one plug, it is in kind of crappy spot. Underneath the passenger side, and it is possible to change with the skid plate on.
SampsonSimpson is offline
post #13 of 15 Old 10-13-2011, 10:34 PM
90grandoneer
90grandoneer's Avatar
2006 WK
I bought both (cam and crank) sensors for my Hemi when I changed the cam. In the end I decided not to change them though, since they're relatively easy to change. I will carry them in my vehicle "emergency kit" though, in case I have a problem on the road. Cheap insurance, both for ~$65 from the stealer. My DashHawk has a built in code reader, as does either the DS or SC tuner, so it would be easy to diagnose. I also carry a listing of all the Diagnostic Trouble Codes and what they mean.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #14 of 15 Old 09-05-2016, 10:34 AM
JoeDaddy1971
So I had the same problem Bucking no power and die. Then would not start just turned over. In the past, it would idle rough CEL would come on and I would get the crank sensor code. rest and would smooth itself out.
This time, the code was p0300 random misfire. Replaced the cam and crank sensors but now can't get the thing to start. Really don't want to take it to the dealer to be robbed.
About 18 months ago I sent the TIPM to AR Speedometer to get the fuel relay done. Everything was fine So this isn't the issue.
Any ideas????
Thanks in advance
JoeDaddy1971 is offline
post #15 of 15 Old 09-05-2016, 03:54 PM
Montreal300
Montreal300's Avatar
Did you install OE parts? The 5.7 is finicky about parts.
Montreal300 is offline
Crank Position Sensor dirt rider ZJ Grand Cherokee Forum 6 04-29-2012 06:12 PM
where is the crank position sensor? 5.2L jeepheller98 ZJ Grand Cherokee Forum 8 04-28-2009 07:48 PM
Crank Position Sensor? BliZZard911 ZJ Grand Cherokee Forum 8 01-12-2008 06:56 AM
Crank Position Sensor YJinMN ZJ Grand Cherokee Forum 18 07-02-2007 08:32 AM
Crank position sensor Othoni ZJ Grand Cherokee Forum 10 05-19-2007 10:14 PM
