Wk 4.7 QT11 in the snow - JeepForum.com
post #1 of 11 Old 02-22-2008, 08:52 AM Thread Starter
Passatglx
My last vehicle was a 05 land rover LR3 which basically drove through snow and had perfect control. My jeep slides all over the place and the traction control doesn't compare to the landrover's capabilities. That and the lr3 was a 1000 lbs heavier. I wonder if quadra drive 2 makes a big diffrence over QT11 in the snow?
Passatglx is offline
post #2 of 11 Old 02-22-2008, 12:23 PM
KingPrat
My father has a similar setup and loves QTII. Maybe you should lay off the skinny pedal?
Or check the level of the fluid in the transfercase. Seems weird that you would be sliding that much more than a LR...
New: Steel Blue 2001 Laredo 4.7, QD, Exhaust
Nokian Vatiiva tires: 235/65-17
Previous:1997 ZJ TSi 4.0. Some stuff added
Western New England College '08
Golden Bear Lacrosse #13
Week 11 USILA Rank: #15
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #3 of 11 Old 02-22-2008, 12:40 PM
SSF556
2008 WK
Did both vehicles have the exact same tires? Tires make a huge difference.
SSF556 is offline
post #4 of 11 Old 02-22-2008, 12:41 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Agreed.
The tires that come stock on the Grand Cherokee are junk.
Texas WJ is offline
post #5 of 11 Old 02-22-2008, 01:39 PM
tbm5690
Different 4WD systems operate in different ways. If you are in a slide give the Jeep gas so that the front wheels can begin to spin and give you traction. I don't know what kind of a system is on the LR3, but 1,000 lbs. of weight makes a difference and x2 on the tires.
2001 Grand Cherokee Laredo S/A package 4.7L V8
K&N high-flow filter, Airaid MIT, Flowmaster 50 catback
tbm5690 is offline
post #6 of 11 Old 02-22-2008, 03:25 PM
AferVentus
Do you have ESP? That, as well as tires, can make a huge difference.
AferVentus is offline
post #7 of 11 Old 02-22-2008, 03:48 PM
mrfWKJeep
2006 WK
I think it must be your tires, I will tell you my WK with Bridgestone Revo's is a different Jeep to drive than when it had the factory Goodyear HP's on it.
2006 Black WK, 4.7 Laredo, 2" Rocky Road Lift, 265 Revo's, XM, TomTom NAV, Hardwired Escort Radar, Bilstien Rear Shocks, 4xGaurd HC Front Gaurd, 4xGaurd HC Rear Gaurd, Yakima Cargo Basket -- "Have Fun Out There"
mrfWKJeep is offline
post #8 of 11 Old 02-22-2008, 05:46 PM
WKJeepKDO
WKJeepKDO's Avatar
2006 WK
My stockers sucked in the snow but the ATs are great.
2006 Grand Cherokee Laredo 4.7
Dark Khaki, Firestone Destinations 245/70/17
WKJeepKDO is offline
post #9 of 11 Old 02-22-2008, 07:21 PM
KingPrat
Just thinkin about a few things:
Land Rovers have a selectable "Terrain Response" system, where you can flip a switch for different road conditions: Rain/Snow, mud, rocks, etc. This system changes vehicle dynamics so that you maintain maximum traction for different conditions.
This is probably why your LR was "superior" in that aspect. The transfercase and ESP systems were prepped for slippage, etc. so the vehicle was safer in the slick conditions. It doesn't need slippage to react.
The mechanical system on Jeeps: QT-II, reacts to slippage and transfers torque and brake pressure to counteract the slippage. This is why you'll feel it more than an LR3.
I guess you just have to get used to a mechanical system. I went from a selectable 4wd blazer to the full-time Jeep when I bought my ZJ and it took a while to figure out the system and be comfortable with it.
Just give it some time. And if you still have those SR-As or HPs on there, get a good AT tire and you'll notice a significant difference.
You can lift the LR3 with the flick of a switch....unreal. My head is spinning after looking through all of the electrical systems that control those things. I'd hate to wrench on one, or own one for that matter, I'll tell ya that much......
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
post #10 of 11 Old 02-23-2008, 03:22 PM
tbm5690
Just a correction for KingPrat...in the WKs the 4WD systems are now electronic, not mechanical like the ZJs and WJs
tbm5690 is offline
post #11 of 11 Old 02-24-2008, 05:05 PM
KingPrat
Only Quadra-Drive II has electrical components incorporated into the 4wd system.(ELSDs) Quadra-Trac II is still mechanical.
Shifting to 4Lo is electrical now on all of them, yes.
2008: 16-5
NCAA Elite 8
TCCC Champions
KingPrat is offline
Snow! (Worthless if your region sees a lot of snow ha) ABerry ZJ Grand Cherokee Forum 62 03-10-2009 08:10 PM
Snow thething ZJ Grand Cherokee Forum 31 12-21-2008 09:27 PM
2wd in the snow? Floof WK Grand Cherokee & XK Commander Forum 31 12-11-2008 03:41 PM
Snow nodkaGSR ZJ Grand Cherokee Forum 5 12-02-2004 05:38 PM
First snow jwilson54 WJ Grand Cherokee Forum 5 12-19-2003 11:12 AM
