WK 3000 lumen light upgrade! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > WK 3000 lumen light upgrade!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 12-09-2012, 02:26 PM   #1
RMC_xj
2007 WK
Update at bottom of post
Seeing as there's no actual thread that details/documents A) what to buy and B) how to install this, I figured I put this here.
I came from owning a 98 XJ, where the headlights sucked, but the upgrade was easy enough with a new wiring harness, new H4 eCode lamps, and Hella H4 bulbs. It was straightforward and easy to install. And that's what I was expecting with the WK.
NOPE!
Lets be fair, the low beams on the WK suck. Thankfully you can get some Philips 9011 series 3000 lumen bulbs that are easy to modify to fit in the WK.
Tools needed:
-a flathead screw driver or knife for the plastic rivets (or a plastic rivet remover, which I highly suggest)
-ratchet
-10mm socket
1) Buy the bulbs. I used rallylights.com (Susquhanna Motorsports) for these bulbs. Warning: If you're in Canada/international, Susquehanna uses UPS, so you'll have to wear a $40-$50 brokerage/duties charge. Make sure you ask for USPS, it's almost a guarantee that there'll be no charge. It'll just take longer to get the package. Update Jan 2015: Susquehanna now offers USPS in their check-out, you no longer to specify it. When I ordered, I bought 4 bulbs to lower the average cost when including shipping and duty/taxes. For my 4 bulbs, I paid around $15 in taxes/duty.
2) Modify the new bulbs. The red area is what you need to remove. I used an 8" metal file.
Update 2015: If you are only replacing low or high bulbs, you may skip steps 3, 4, and 5. It's a tight fit, but if you're careful, and you contort your hand you can remove and re-install the new bulbs without much of a fight. However if you plan on removing the headlight unit proper, you'll need to remove the bumper as there is a plastic tab that prevents easy removal of the headlight unit.
3) Open your hood. Pull the plastic rivets holding the grill. Pull the bumper. There's, IIRC, 6 metal screws (1 on top, 1 on either side in the wheel wells, and 3 below the bumper attached to the plastic skid) and several plastic rivets. This'll take some time, but if you're careful, it'll be okay. I tried using the Factory Service Manual, but that only told me where the headlight unit screws were.
4) Pull the black "skeleton" bracket that's behind the bumper. It's secured by 2 screws.
5) Unscrew the 3 screws holding in the headlight unit. You'll need to jimmy the light out.
6) Twist out the old low beam (Lows are on the outboard side above the turn signal)
7) Install new lights. On the left is the new Philips bulb, with the old grey bulb on the left. The old ones (on the left) and the new Philps bulbs use rails inside the light to slot into the headlight plug. The new ones, because they use 2 rails instead of the stock single rail, will need some force to fit onto the plug. Rest assured they DO fit.
8) Enjoy brighter lights! With the greater light input, you can really see how sharp the cut-off is from the lamp unit itself.
Update Jan 2015:
The bulbs burned out on me, about a week apart from one another. So I got just over 2 years of usage out of them. I also discovered that removing the bumper was made exceptionally more difficult by having the 4XG front skid. To get at the 3 bottom bolts on the bumper, you have to snake a wrench through the opening slats. When I saw this, I figured I'd give it another go with contorting my hand to change the bulbs, as per several users who very politely ( ) suggested that there was absolutely no need to remove the bumper, if you could contort your hands.
So, to change the high or low bulbs, there is no requirement to remove the bumper! However, if you want to get access to the headlight unit proper - to remove it - my experience is that bumper removal is still required.
My DIY walkthrough is still pertinent (up to step 2) as I show a comparison of the bulbs, and which bit of plastic needs removal for successful installation in our WKs.
This is an easy upgrade, one that I would very highly recommend to all WK owners.
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
RMC_xj is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 02:46 PM   #2
gamma500
2005 WK
You have to remove the bumper on a 07 WK to gain access to the low beam bulb..?.. I can get to my 05 bulbs without all this, just a bit of hand contortions.
gamma500 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 03:02 PM   #3
RMC_xj
2007 WK
I tried that route, but I couldn't contort my hands to get the bulb out. I tried just pulling the headlight unit itself, but there's a plastic tab at the bottom that the unit hooks into, preventing any sort of easy removal.
96 XJ
Unread 12-09-2012, 03:13 PM   #4
hxdrummerxc
hxdrummerxc's Avatar
2008 WK
I changed all the bulbs on my 08 like a month ago, no special bulbs or anything, just some newer higher output, I don't remember what.
But It was hard to get to some of the bulbs, especially the side markers, even with the little door under the wheel well, it was almost impossible to get to. I just pull both headlight assemblies out without removing the bumper.
But this is a nice little write-up.... Thanks
08' Limited 5.7L QTII | Hemi Club #76 | RC lift | Custom painted headlights with Oracle LED Halos | Bwoody 4" Short Ram Velocity Intake | Flowmaster Super 44 & resonator delete | Superchips Vivid |
hxdrummerxc is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 03:23 PM   #5
Kolak
Vendor
Kolak's Avatar
Consider adding a headlamp relay harness to route power directly to the bulbs from the battery. I have those available if you're interested - send me a PM for more information.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 03:26 PM   #6
imthehink
2005 WK
Cheaper here:http://www.amazon.com/Philips-HIR1-9...words=9011+hir
imthehink is offline   Reply With Quote Quick reply to this message
Unread 12-09-2012, 04:02 PM   #7
SSF556
SSF556's Avatar
2008 WK
Guys these are the best light upgrade out there for the WK and really blow almost all aftermarket LEGAL lights out of the water. I was also running some H4 Cibie lights and removed them since they get washed out with the highbeams on.
Hilldweller who is probably one of the most famous internet light guys out there has tested my WK with these lights.....you can see his response at the links below....
It is imperative that you make sure your lights are adjusted because if you are pointing high you will get a lot of flashes from on coming traffic.
http://www.candlepowerforums.com/vb/...kee-CRD-Lights
ETA...OP there is no need for you to take off the front bumper to remove and replace bulbs....
ETA2...I also run a plug and play harness as well....Ray at Susqehanna Motorsports (Rally Lights) made mine for me.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2012, 09:55 PM   #8
blizzboy283
2005 WK
Correct me if I'm wrong but aren't the 9011 bulbs compatible to our 9005 high beam bulbs? If so then you would not only need to modify the tab as shown in your photo but you would have to notch down one of the tabs on the actual plug as well.
I used to put high beam bulbs in my old wj by doing this, but only with some silverstars. I have 9012 hir in my lows now, but now I'm thinking about putting the 9011 in both the high, low, and fogs.
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2012, 10:09 PM   #9
jjt250
2007 WK
Sorry but I'm getting a bit confused now....
This one is for highs?
And this one is for lows?
http://www.amazon.com/Philips-HIR2-S...gy_auto_text_y
Right? Also, is a relay harness necessary or not?
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2012, 08:14 AM   #10
SSF556
SSF556's Avatar
2008 WK
Correct on the bulbs...
To maximize the light output of the bulbs a harness would be beneficial, but is not necessary.
2008 CRD QT2
Unread 12-19-2012, 12:10 PM   #11
blizzboy283
2005 WK
How is this possible? They run off the same amount of power as the stock ones.
Correct me if I'm wrong but people run harnesses with Hids because they don't draw enough power.
Unread 12-19-2012, 01:43 PM   #12
Kolak
Vendor
Kolak's Avatar
There's typically a significant voltage drop through the stock wiring, even with the stock bulbs. The relay harness will route power directly from the battery when you turn on the lamps, nearly eliminating the voltage drop.
Unread 12-19-2012, 01:56 PM   #13
trax95008
2006 XK Commander
Larger gauge wire has less resistance. Smaller wire can potentially "choke" the amount of current that can pass through. While its true that the voltage will always measure the same, the larger wire can allow the light to shine more brilliant. Of course you will only see a difference if the stock wiring happens to be small enough to start "choking" the amount of current that the light bulb would like to draw. About 10 years ago I installed a wiring harness in my Toyota corolla. I hooked the low and high beam up to the harness on one side and left the other side hooked to the stock wiring for a comparison. I parked in front of my garage door at night. The difference it made was unbelievable
trax95008 is offline   Reply With Quote Quick reply to this message
Unread 12-19-2012, 04:42 PM   #14
blizzboy283
2005 WK
So basically harnesses will make any bulb shine brighter? That's pretty cool.
Kolak, I assume these harnesses would work with hids as well? Can you pm me a price for two to 19148.
Unread 12-19-2012, 05:49 PM   #15
thedude411
2008 WK
You should be able to buy relay wiring kits from theretrofitsource.com
thedude411 is offline   Reply With Quote Quick reply to this message
